hvordan komme seg online på ps3
KeyanZa
Once I had set my router up, the rest was as easy as installing a new program on a PC. Going into the menu using the normal PS3 controller, I selected the 'Settings' option. This is as easy as pressing the X button to confirm, just like you'd use it as the action button in most of the games for the machine. Once in 'Settings', you should see an option that says 'Network Settings'. This is where you need to go next.
When you click the X button and enter the 'Network Settings' menu, you should see a whole bunch of other options too, but the one that you need to go for is the 'Internet Connection Settings' (see, I told you it was easy to follow!). This is where you'll be setting up the router to work your PS3, so again just hit the X button. That'll take you to a black screen with grey-silver writing that says 'Wired Connection' or 'Wireless'. You need to be selecting the wireless one, so click on that. From here, it's really easy, as the on-screen wizard will guide you.
http://www.ps3l33t.com/ps3-console/setting...t-up-guide.html
Det er passordet som er stilt inn på routeren din for at andre trådløse enheter skal få "slippe inn".
Om den pc-en du sitter ved nå er på samme nettverk har det blitt tastet inn et passord på denne, og da kan du jo høre med den som gjorde det, om det ikke var deg selv, hva passordet er.
Ellers kan du gå inn i routeren din og sette passordet selv, og da henviser jeg til manualen på din router;)
