Ny Opera Kestrel build (9523)
geil
Kom ny build av Opera Kestrel i dag for de som ikke har fått det med seg. Absolutt interessant å teste ved siden av annen Operabuild/browser.
Post-Alpha Opera 9.5 Release
By minch. Friday, 14. September 2007, 15:19:22 ALPHA, KESTREL
Just when you thought the Alpha was exciting, here's the first post-alpha release!
Previously the term weekly has been used to describe our "weekly" releases. As most of you know they don't always appear at the end of every week, therfore we will be endeavouring to deliver a steady stream of builds as they are ready. So be prepared, the next release may come on a Tuesday or any other day of the week.
So what have we been doing?
We have been working hard on performance and fixing bugs, so go and grab the build and help us make Opera 9.5 even better!
Known issues:
Wand doesn't save anymore.
Yahoo mail beta might crash Opera.
Some UNIX packages are missing.
Won't work on win98/95
Changelog
[272376] Cursor in source viewer positioned at the end
[277681] Some order lists are displayed as unordered lists
[279302] Line wrapping does not work correctly in some cases, causing overly long lines of text and horizontal scrollbars; often seen at Wikipedia
[280678] Files are often saved with the incorrect file extension
[281550] Setting an external source viewer does not work
[267842] View bar is available in the customization dialog again
[274676] Original text color (inside tables) not reverted when closing content blocker dialog
[267859] Numbers (and borders) not shown in configured speed dial entries
[273030] Text squished/mashed together after removing thumbnail
[273822] Link focused by inline find cannot be activated (Enter doesn't work after spatnav)
[281879] Show cached images randomly breaks
[282003] Lots of unread messages and drafts after upgrade
APNG 1.0 support added. Will work as animated gifs on webpages and skins
Select custom application when downloading files
add multithreading to mail for improved performanced
Added x button on notifiers
Fixed IE bookmark folder import
General stability fixes
Tons of layout/js fixes
Windows specific
Greatly improved performance with alpha transparency (animations, scrolling)
Mac specific:
Further tweaking of tabs in native skin
Removed page loading spinner from Address bar
Rounded edges on many dialog Title bars
Fixed application window focus/activation problems
Fixed problems with Flash problems with wmode=opaque and CSS hover
Prevent some start-up freezes
Pulsing progress bar
Download:
Windows
Windows Classic
Macintosh
Unix
Link til blog
Endret av switch1
