Hvordan laste ned 1.6b fra Steam?
hvis du går inn på websiden www.counter-strike.net og ser heeelt øverst, så står det noe sånt som:
The Counter-Strike and Team Fortress communities have maxed out the Steam 2.0 beta servers, resulting in the temporarily suspension of admission to the beta as more content servers are put online. The current Steam content servers offer over 500 megabits of bandwidth, all of which the community is consuming right now.
med andre ord, du kan ikke.
Gjest
