Er dette RAID-1 eller ?
Lindsay
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
dual:~# fdisk -l
Disk /dev/sda: 200.0 GB, 200049647616 bytes
255 heads, 63 sectors/track, 24321 cylinders
Units = cylinders of 16065 * 512 = 8225280 bytes
Device Boot Start End Blocks Id System
/dev/sda1 * 1 31 248976 83 Linux
/dev/sda2 32 24321 195109425 5 Extended
/dev/sda5 32 24321 195109393+ 8e Linux LVM
Disk /dev/sdb: 200.0 GB, 200049647616 bytes
/dev/sdb1 * 1 13 104391 fd Linux raid autodetect
/dev/sdb2 14 24321 195254010 fd Linux raid autodetect
Disk /dev/dm-0: 197.0 GB, 197010653184 bytes
255 heads, 63 sectors/track, 23951 cylinders
Disk /dev/dm-0 doesn't contain a valid partition table
Disk /dev/dm-1: 2780 MB, 2780823552 bytes
255 heads, 63 sectors/track, 338 cylinders
Disk /dev/dm-1 doesn't contain a valid partition table
  • 1 måned senere...
Ser ut som det bare er en disk i RAID1-opsettet ditt i følge mdstat, noe som blir et svært dårlig RAID-opsett. ;)
Skal vel liste opp alle diskene slik som dette (4 disker i RAID5):
Personalities : [linear] [multipath] [raid0] [raid1] [raid6] [raid5] [raid4] [raid10]
md0 : active raid5 sdb1[0] sde1[3] sdd1[2] sdc1[1]
  2197715712 blocks level 5, 64k chunk, algorithm 2 [4/4] [UUUU]
unused devices: <none>
