Logic89 Skrevet 17. september 2007 Rapporter Del Skrevet 17. september 2007 RIP Colin Mcrae http://www.siste.no/sport/article2998535.ece Lenke til kommentar
Lakus Skrevet 17. september 2007 Rapporter Del Skrevet 17. september 2007 (endret) One of the big complaints about DiRT on the 360 and PC was that it simply didn't perform very well. The PC version looked choppy on a near-constant basis, and the 360 version had a tendency to tank pretty badly during multicar races. On the other hand, the PlayStation 3 version is nearly flawless in this regard. The game maintains a steady 30-frames-per-second rate for the vast bulk of the game, and the few scattered dips in performance are very brief and hardly noticeable. The extra time between releases seems to have benefited this version a great deal. De jeg kjenner som har spillet har aldri merket noe av dette Endret 17. september 2007 av Lakus Lenke til kommentar
Andyoid Skrevet 18. september 2007 Rapporter Del Skrevet 18. september 2007 Codemasters om Colin's bortgang: http://www.codemasters.co.uk/colinmcrae/ Lenke til kommentar
Spillorakelet Skrevet 18. september 2007 Rapporter Del Skrevet 18. september 2007 One of the big complaints about DiRT on the 360 and PC was that it simply didn't perform very well. The PC version looked choppy on a near-constant basis, and the 360 version had a tendency to tank pretty badly during multicar races. On the other hand, the PlayStation 3 version is nearly flawless in this regard. The game maintains a steady 30-frames-per-second rate for the vast bulk of the game, and the few scattered dips in performance are very brief and hardly noticeable. The extra time between releases seems to have benefited this version a great deal. De jeg kjenner som har spillet har aldri merket noe av dette 9513424[/snapback] Du merker dette veldig godt i Rallyløpene mot 7 andre biler, da hakker det fryktelig i svinger hvor mange biler er i skjermen samtidig. Lenke til kommentar
Lakus Skrevet 19. september 2007 Rapporter Del Skrevet 19. september 2007 Du merker dette veldig godt i Rallyløpene mot 7 andre biler, da hakker det fryktelig i svinger hvor mange biler er i skjermen samtidig. Kan godt hende, skal ikke uttale meg noe mer før jeg har spillet mellom hende selv. Lenke til kommentar
-iL- Skrevet 19. september 2007 Rapporter Del Skrevet 19. september 2007 noen forskjell i gameplay? Lenke til kommentar
Lomion Skrevet 20. september 2007 Rapporter Del Skrevet 20. september 2007 Kjapt spørsmål. Er det noen som helst form for offline multiplayer? Ikke nødvendigvis split-screen, men slik at man kjører mot hverandre sine tider gjennom et helt rally for eksempel? Lenke til kommentar
kake111 Skrevet 20. september 2007 Rapporter Del Skrevet 20. september 2007 tror ikkje det MEN spillet er UTROLIG Iriterendes når eg krasjer. Kontrollen dør jo nesten Lenke til kommentar
Matsibooy Skrevet 23. september 2007 Rapporter Del Skrevet 23. september 2007 (endret) Sykt fett spill, men jeg lurer på hva betyr tbc? på rankinga Edit: skrive feil Endret 23. september 2007 av pure-evil Lenke til kommentar
Bear^ Skrevet 23. september 2007 Rapporter Del Skrevet 23. september 2007 For min del har jeg aldri likt Collin serien, og etter noen timer med Dirt, spesielt ikke etter at jeg fikk Richard Burns Rally som er mye bedre enn Collin serien i mine øyne. Det som plagde meg mye var styringen som føltes alt for arkade, alt for god styring i forhold til underlaget f.eks, samt at skademodellene var bare overfladiske, det så ikke ut som motoren tok store doser skade om du da ikke dro inn i en stein med fronten først. Men understellet tåler vistnok alt i verden, selv en humpatur i bushen. Teknisk sett har jeg ikke opplevd noe mer prekært enn lang lastetid, irriterende stemme i hovedmenyen og over entusiatisk kartleser som kommer med noen fraser før start og når du har kommet i mål. Har ikke opplevd noe slowdowns på X360, grafiske glitcher eller andre problemer med den versjonen, så de som sier de har sett grafiske problemer med spillet må ha en feil med konsollen sin, eller så har jeg fått en overdimensjonert perfekt utgave av spillet. Lenke til kommentar
kake111 Skrevet 23. september 2007 Rapporter Del Skrevet 23. september 2007 For min del har jeg aldri likt Collin serien, og etter noen timer med Dirt, spesielt ikke etter at jeg fikk Richard Burns Rally som er mye bedre enn Collin serien i mine øyne. Det som plagde meg mye var styringen som føltes alt for arkade, alt for god styring i forhold til underlaget f.eks, samt at skademodellene var bare overfladiske, det så ikke ut som motoren tok store doser skade om du da ikke dro inn i en stein med fronten først. Men understellet tåler vistnok alt i verden, selv en humpatur i bushen. Teknisk sett har jeg ikke opplevd noe mer prekært enn lang lastetid, irriterende stemme i hovedmenyen og over entusiatisk kartleser som kommer med noen fraser før start og når du har kommet i mål. Har ikke opplevd noe slowdowns på X360, grafiske glitcher eller andre problemer med den versjonen, så de som sier de har sett grafiske problemer med spillet må ha en feil med konsollen sin, eller så har jeg fått en overdimensjonert perfekt utgave av spillet. 9554951[/snapback] Eg har på Pro spilling og når du går inn i skauen i en helvetes fart så knuses alt som er av motor, understelle, turbo, lufting. ALT Lenke til kommentar
