Hrundi V. Bakshi Skrevet 9. september 2007 Rapporter Del Skrevet 9. september 2007 (endret) Jeg skal ha en ny ferdigbygd PC, hovedsaklig en skikkelig gaming PC men også til vanlig bruk ellers. Har konfigurert 2 forskjellige, en fra Komplett og en fra Netshop. Hvilken av disse er best? Komplett: -Cooler Master Stacker 831 Sort, 2x12cm -Asus P5K Premium/WIFI-AP, P35, DDR2 -Intel Core 2 Duo E6850 3.0GHz 1333Mhz -Fortron/Source Epsilon 700W, Blå Vifte, -Corsair TWIN2X 6400C4 DDR2, 2048MB CL4, -Corsair TWIN2X 6400C4 DDR2, 2048MB CL4, -Gainward GeForce 8800GTX 768MB GDDR3, -Seagate Barracuda 7200.10 500GB SATA2 -Seagate Barracuda 7200.10 500GB SATA2 -Creative SB X-Fi Gamer, Bulk -USB2 multikortleser 3.5" sort, -Samsung DVD-brenner SH-S183A SATA -Samsung DVD-spiller SH-162C -MS XP Pro SP2 Norsk -Logitech G15 Gaming Keyboard, -Samsung 22" LCD Syncmaster 226BW TCO99 -Logitech X-530 Høyttaler 5.1 Pris: 22 467,- Netshop: -1 stk. Lian Li Miditower, Aluminium, Sort PC6070BSCANDV2 u/powersupply -1 stk. GIGABYTE ODIN Pro_800W m/Kabler Støysvak, 14cm vifte, viftestyring, SLI -1 stk. Asus P5K PREMIUM/WIFI-AP Black Pearl 775 P35 DDR2, eSATA, ATX, 2xGbLAN, 2xPCI-Ex - stk. Intel Core 2 Duo E6850 3.0GHz Socket775 4MB, BOXED m/vifte -1 stk. Mushkin DDR2 4096MB enhanced Memory EM2-6400 4x1024MB 800MHz. (5-5-5-12) -1 stk. Western Digital 500GB S-ATA II 7200 RPM Caviar Special Edition 16MB cache -1 stk. Western Digital 500GB S-ATA II 7200 RPM Caviar Special Edition 16MB cache -1 stk. Asus GeForce 8800GTX 768MB GDDR3 HDCP,PCI-Express, 2xDVI-I, Tv-Out,384bit -1 stk. Optiarc / NEC DVD-brenner AD-7170S sort SATA,DVD±RW (±R DL)/DVD-RAM-stasjon bulk -1 stk. Logitech X-230 Høyttaler 2.1 2 satelitter og subwoofer 32W RMS -1 stk. Logitech G15 Gaming Keyboard USB, LCD, Lys i knapper (svensk layout) -1 stk. Microsoft Windows XP Professional OEM ENGELSK versjon m/SP2b -1 stk. ASUS 22"W LCD 2MS 300CD 1680x1050, 2000:1, DVI-D+VGA -1 stk. Multikortleser 3.5" USB2 sort CF I/II,SM,MMC/SD,MS,xD (bulk) Pris: 21 110,- Ganske like oppsett, men forskjellige merker på ting og tang. Så, hvilken er best? Kan jeg få noe lignende andre steder ferdigbygd? Er på smertegrensa rundt 22-23 tusen. Det som er spikra, er følgende: -E6850 -8800 GTX 768MB -4GB minne -22" skjerm -2x500GB disker Endret 19. september 2007 av mjau Lenke til kommentar
Rulator Skrevet 9. september 2007 Rapporter Del Skrevet 9. september 2007 hehe tror jeg ville valgt den fra netshop, men uansett mye billigere å bygge selv. så har du noen erfaring? Lenke til kommentar
Dragavon Skrevet 9. september 2007 Rapporter Del Skrevet 9. september 2007 Kan jeg få noe lignende andre steder ferdigbygd? Er på smertegrensa rundt 22-23 tusen. Det som er spikra, er følgende: -E6850 -8800 GTX 768MB -4GB minne -22" skjerm -2x500GB disker 9456165[/snapback] Så lenge du har bestemt deg for dette, så kjøper du der det er billigst. Med mindre du har spesielle preferanser, og det virker det ikkje som om du har, så kommer du aldri til å merke noen som helst forskjell. Kjøp det kabinettet og den skjermen du liker best, ellers kan du nesten velge ett hvilket som helst merke. Lenke til kommentar
Petaaar Skrevet 9. september 2007 Rapporter Del Skrevet 9. september 2007 hvorfor ikkekjøpe q6600 og klokke til 3ghz og spytte 6850 i trynet , det hadde jeg Lenke til kommentar
On1Musha Skrevet 9. september 2007 Rapporter Del Skrevet 9. september 2007 kjøpt fra netshop siden det tar 100 år å få send det fra komplett Lenke til kommentar
haalo Skrevet 9. september 2007 Rapporter Del Skrevet 9. september 2007 hvorfor ikkekjøpe q6600 og klokke til 3ghz og spytte 6850 i trynet , det hadde jeg 9457821[/snapback] Forskjellen på en 3 GHz dualcore en 3 GHz quadcore er ikke til stede i de fleste bruksområder. En q6600 bruker mye mer strøm enn en E6850, og krever derfor bedre kjøling. Og hvis du skal ta oveklokking med i sammenligningen (noe du gjør9, må du ta hensyn til at en E6850 sansynligvis kan nå mye høyere frekvenser enn en Q6600. Lenke til kommentar
Rulator Skrevet 9. september 2007 Rapporter Del Skrevet 9. september 2007 jaja kjøp fra netshop. slipper leverings pisset til komplått og du får lian li kabinett Lenke til kommentar
Hrundi V. Bakshi Skrevet 13. september 2007 Forfatter Rapporter Del Skrevet 13. september 2007 (endret) Ser ut som jeg dropper komplett... hadde ikke fått med meg at det var så store leveringsproblemer der, men har lest litt om det nå. Så, da blir det Netshop. Oppsettet jeg ser ut til å lande på, ser slik ut nå: -Lian Li Miditower, Aluminium, Sort PC7BSCANDV3 u/powersupply -GIGABYTE ODIN Pro_800W m/Kabler Støysvak, 14cm vifte, viftestyring, SLI -Asus P5K PREMIUM/WIFI-AP Black Pearl 775 P35 DDR2, eSATA, ATX, 2xGbLAN, 2xPCI-Ex -Intel Core 2 Duo E6850 3.0GHz Socket775 4MB, BOXED m/vifte -Mushkin DDR2 4096MB enhanced Memory EM2-6400 4x1024MB 800MHz. (5-5-5-12) -Western Digital 500GB S-ATA II 7200 RPM Caviar Special Edition 16MB cache -Western Digital 500GB S-ATA II 7200 RPM Caviar Special Edition 16MB cache -Club3D Geforce 8800GTX 768MB PCIe 384BIT,GDDR3, Dual DVI, TV-out -Optiarc / NEC DVD-brenner AD-7173 sort Duallayer,LabelFlash,Multirecorder bulk -Logitech X-230 Høyttaler 2.1 2 satelitter og subwoofer 32W RMS -Logitech G15 Gaming Keyboard USB, LCD, Lys i knapper (svensk layout) -Microsoft Windows XP Professional OEM ENGELSK versjon m/SP2b -Samsung 22" LCD 226BW Wide sort 1680x1050, 3000:1, 2ms, VGA/DVI -Multikortleser 3.5" USB2 sort CF I/II,SM,MMC/SD,MS,xD (bulk) -Norton AntiVirus 2007 Norsk Fullversjon Norsk, Retail Total sum for dette er 21 283,- Tok Club3D GTX kortet istedet for Asus, fordi Asuskortet ikke er på lager og ikke er bekreftet inn med det første. MEN... de har XFX 8800GTX 768 kortet på lager, og det koster ca 250 kroner mer enn Club3D. Er det på noen måte bedre enn Club3D (eller Asus)? Byttet også ut Asus skjermen med Samsung 226BW. Fant nesten ingen tester eller erfaringer med Asus 22", og Samsung'en har 3000:1 mot 2000:1 på Asus. Tror det er en bedre skjerm, eller er det noen som mener noe annet? Samsung'en koster bare 200 mer enn Asus. Er det forresten noen som vet om det går an og få montert inn deler som ikke står i konfigureringslista? Dette er Battleground Hybrid modellen. (Sendte mail angående dette til [email protected] i går kveld, men har ikke fått svar enda) Skulle hatt en DVD spiller, men eneste som dukker opp i valgene på CD/DVD 2 er brennere. De har forøvrig DVD spillere i vanlig sortiment. Vurderer også og sette inn ett Creative SB X-Fi XtremeGamer lydkort, samme sak der at det ikke står i konfigurasjonsmenyen men er i vanlig sortiment. Spørsmålet er om jeg trenger ett ekstra lydkort? Vil Creativekortet være mye bedre enn det innebygde i P5K Premium hovedkortet - tenker da først og fremst på spill. Eller vil jeg ikke merke noe på ett såpass "billig" lydsystem som det Logitech X-230 jeg skal ha med? Har dere noen innvendinger mot noen komponenter, tips eller andre tanker rundt oppsettet mitt så syng ut Bestiller vel ikveld eller i morgen Endret 13. september 2007 av mjau Lenke til kommentar
Rulator Skrevet 13. september 2007 Rapporter Del Skrevet 13. september 2007 Samme kortet forskjellig klistremærke:D hehe tenkte på gpu Lenke til kommentar
Dragavon Skrevet 13. september 2007 Rapporter Del Skrevet 13. september 2007 Tok Club3D GTX kortet istedet for Asus, fordi Asuskortet ikke er på lager og ikke er bekreftet inn med det første. MEN... de har XFX 8800GTX 768 kortet på lager, og det koster ca 250 kroner mer enn Club3D. Er det på noen måte bedre enn Club3D (eller Asus)? Vurderer også og sette inn ett Creative SB X-Fi XtremeGamer lydkort, samme sak der at det ikke står i konfigurasjonsmenyen men er i vanlig sortiment. Spørsmålet er om jeg trenger ett ekstra lydkort? Vil Creativekortet være mye bedre enn det innebygde i P5K Premium hovedkortet - tenker da først og fremst på spill. Eller vil jeg ikke merke noe på ett såpass "billig" lydsystem som det Logitech X-230 jeg skal ha med? 9486993[/snapback] Enkelte av XFX's kort er håndplukket for overklokking. Eg har sjølv ett slikt 7950GT, ferdig overklokket med passiv kjøler fra XFX. I utgangspunktet klokket kortet godt med den passive kjøleren fra XFX. Eg kunne klokke det en god del opp fra innstillingene XFX hadde satt. Men når eg satte på vannkjøler ble det virkelig fart i sakene så eg er meget godt fornøyd og kjøper gjerne XFX igjen. Kortet klokker godt over snittet for 7950GT. Creative X-Fi vil nok være litt bedre lyd på enn det integrerte. Men det viktigste for meg er at Creative sine kort sluker mye mindre prosessorkraft en integrerte lydkort gjør. Når man kjøper kjøleløsninger til flere tusen kr for å overklokke så tillater man da for pokker ikkje ett integrert lydkort å sluke dyrebare FPS Lenke til kommentar
Ragal Skrevet 13. september 2007 Rapporter Del Skrevet 13. september 2007 Skulle hatt en DVD spiller, men eneste som dukker opp i valgene på CD/DVD 2 er brennere. De har forøvrig DVD spillere i vanlig sortiment. Jeg skulle tro at du her får en "alt i ett" rom. Dvs en som fungerer som cd spiller, dvd spiller, cd brenner og dvd brenner.. Med mindre du da trenger en ekstra dvd spiller, så tror jeg ikke dette er problem. Lenke til kommentar
Hrundi V. Bakshi Skrevet 13. september 2007 Forfatter Rapporter Del Skrevet 13. september 2007 Skal ha en DVD brenner som hovedvalg, men du kan velge en ekstra CD/DVD enhet. Jeg ser ikke poenget i og skulle ha 2 stk DVD-brennere, derfor skulle jeg hatt en vanlig DVD avspiller i tillegg. Virker som det kan være greit og ta ett XtremeGamer lydkort, og bruke det i stedet for det innebygde på hovedkortet. Lenke til kommentar
Hrundi V. Bakshi Skrevet 19. september 2007 Forfatter Rapporter Del Skrevet 19. september 2007 Ok, just to wrap things up... Da har jeg bestilt Takk for alle innspill, for de som måtte være interessert ble PC-en jeg bestilte slik; -Antec Performance One P182 Gun Metal ATX miditower u/PSU -Corsair strømforsyning 620W 20/24pin, ATX v2.2, 120mm vifte, 8x SATA -Asus P5K PREMIUM/WIFI-AP Black Pearl 775 -Intel Core 2 Duo E6850 3.0GHz Socket775 -Mushkin DDR2 4096MB enhanced Memory EM2-6400 4x1024MB 800MHz (5-5-5-12) -Western Digital Raptor X 150GB S-ATA 16MB cache 10000RPM -Western Digital 500GB S-ATA II 7200 RPM Caviar Special Edition 16MB cache -Western Digital 500GB S-ATA II 7200 RPM Caviar Special Edition 16MB cache -Asus GeForce 8800GTX 768MB GDDR3 ,HDCP,PCI-Express, 2xDVI-I, Tv-Out,384bit -Creative SB X-Fi XtremeGamer Retail PCI -Asus DVD±RW 16X DL SATA sort Duallayer, LightScribe, m/Nero -Samsung SH-D163A DVD-ROM 16X/48X SATA, Sort -Microsoft Windows XP Professional OEM ENGELSK versjon m/SP2b -Logitech G15 Gaming Keyboard USB, LCD, Lys i knapper (svensk layout) -Creative I-Trigue L3800 IR 2.1 -Multikortleser 3.5" USB2 sort -Samsung Syncmaster 226CW, 22" DeLuxe -Logitech Extreme 3D PRO Digital Joystick Når det gjelder kabinett og PSU, så falt valget på Antec P182 med en Corsair 620W etter veldig mye om og men. Tok også med en ekstra harddisk sett i forhold til mine første oppsett - valgte en WD Raptor X som systemdisk. Tok også den nye Samsung 22" 226CW istedet for 226BW. Vurderte også en 24", men tok tilslutt 22". Så, da er det bare og sette seg og vente på at herligheten skal bli levert (bygge om hjemmekontoret/nerdebula mi i mellomtiden) Lenke til kommentar
Bebeluv Skrevet 19. september 2007 Rapporter Del Skrevet 19. september 2007 Bygger Netshop for deg også? Hvor lang leveringstid er dette? orker ikke vente på Komplett viss jeg kan få det tidligere fra Netshop. Lenke til kommentar
Hrundi V. Bakshi Skrevet 19. september 2007 Forfatter Rapporter Del Skrevet 19. september 2007 Ja, Netshop bygger den. Vet ikke eksakt leveringstid, men i svaret jeg fikk fra Netshop når jeg spurte om jeg kunne få inn ekstra deler og hvor lang leveringstid, sto dette: Er alt på lager når du bestiller, så er det ikke mange dagers leveringstid på en slik pc. Pga. alt snakket om lang leveringstid fra Komplett og at de ikke kunne/ville bruke andre deler enn det som sto i konfigurasjonslisten valgte jeg Netshop. Har bare gode erfaringer med Netshop fra tidligere. (Svaret jeg fikk fra Komplett angående leveringstid var dette: "Vi har en leveringstid på ca 14 dager fra bestilling.") Lenke til kommentar
Bebeluv Skrevet 19. september 2007 Rapporter Del Skrevet 19. september 2007 (endret) Hvor fant du Lian Li kabinett og sånt? Valgte du konfigurer en annen ferdig pc? elr startet du fra scratch? Forresten hvor mye kom PC-en din på Endret 19. september 2007 av Zaleeeek Lenke til kommentar
Hrundi V. Bakshi Skrevet 19. september 2007 Forfatter Rapporter Del Skrevet 19. september 2007 Står i nedtrekkslista over kabinetter. Begynte med å konfigurere en Battleground Hybrid, men endte opp med å konfigurere en Battleground Mayham. Den har flest valg totalt sett. Som sagt valgte jeg til slutt ett Antec P182 istedet for ett Lian Li. Likte løsningene i det bedre. Lenke til kommentar
Bebeluv Skrevet 19. september 2007 Rapporter Del Skrevet 19. september 2007 (endret) Dette ble billige greier, fikk valgt et billigere skjermkort og prisen ble litt over 9k, istede for 11k som jeg betalte hos komplett. Valgte Thermaltake Tsunami kabinettet, er det å anbefale? mjau: Sry at jeg låner topicen din, håper det går bra. Skulle forresten likt å funnet Twin Engine der, men ser litt dårlig ut. Endret 19. september 2007 av Zaleeeek Lenke til kommentar
Hrundi V. Bakshi Skrevet 19. september 2007 Forfatter Rapporter Del Skrevet 19. september 2007 mjau: Sry at jeg låner topicen din, håper det går bra. 9530525[/snapback] Hehe, går greit det. Jeg er forsåvidt ferdig med denne tråden jeg Spørs bare om du ikke er bedre tjent med å lage en ny tråd... vet ikke hvor mange som vil se på denne ettersom jeg har skrevet *bestilt* i emnet. Lykke til uansett Lenke til kommentar
Bebeluv Skrevet 19. september 2007 Rapporter Del Skrevet 19. september 2007 (endret) Fått bestilt ferdig jeg også Thermaltake Tsunami Aluminium Sølv VA3000SNA m/USB/FW/Audio u/powersupply 25590 Corsair strømforsyning 620W 20/24pin, ATX v2.2, 120mm vifte, 8x SATA 24678 Asus P5N32-E SLI Pluss nForce 650i S775 ATX, SATA RAID, 2xGbLAN, DDR2, 3xPCIe 24542 Intel Core 2 Quad Q6600 2.4GHz 8MB, BOXED m/vifte Socket 775 25010 Geil 2GB DDR2 PC6400 800MHz Ultra 4-4-4-12 Metallic-Orange Aluminum Retail 24912 Western Digital 500GB S-ATA II 7200 RPM Caviar Special Edition 16MB cache 27100 FOX+ GeForce 8400GS 128MB 450MHz, DVI + HDTV-Out+ VGA 27742 Asus DVD±RW 16X DL SATA sort Duallayer, LightScribe, m/Nero 24302 Microsoft Windows Vista Home Premium OEM Norsk versjon 32-bit DVD-versjon Veit ikke hvor lang tid dette tar, men er best for dem at det tar kortere tid enn Komplett for det var hovedgrunnen til at jeg byttet over Så sendte jeg dem mail og spurte om dem kunne bytte ut stock cpu kjølern til en litt bedre enn, håper det går bra. mjau: hvor sendte du mail til dem? [email protected] - [email protected] - [email protected]? jeg tok salg å håper det var riktig Hvor lang tid tok det før du fikk svar? Endret 19. september 2007 av Zaleeeek Lenke til kommentar
