Trådløs gitar bekreftet til Rockband på Ps3
UrgeLoL
Harmonix CEO confirms Rock Band's Xbox 360 bundle guitar is wired
50 Comments
by Alexander Sliwinski Sep 8th 2007 1:11PM
Filed under: Sony PlayStation 3, Microsoft Xbox 360, Rhythm
In the latest OXM Podcast, Harmonix CEO Alex Rigopulos confirms that the Xbox 360 guitars for Rock Band are wired in the bundles. There will be wired and wireless versions available for the Xbox 360, but once again, the retail bundles will come with a wired guitar. The PS3 guitars are all wireless. The Xbox 360 bundle will also come with a USB hub for all the peripherals to plug into. On both the Xbox 360 and PS3 version the microphone and drum kit will be wired. Rigopulos says, "The cost of wireless technology on the Microsoft side is higher and to be able to offer those bundles at a price point that would be reasonable for consumers it was necessary ... on the 360 side we are also bundling a hub."
And no, there is no official price yet. It's starting to look like the $20 difference between the Xbox 360 wired and wireless guitar we reported after receiving an internal Game Crazy memo is holding up. So, that's that, the Xbox 360 bundle of Rock Band has a wired guitar and you'll get a little hub to plug everything in. Now comes the question if Microsoft will loosen their grip on the cost of licensing the proprietary wireless tech if the PS3 version of Rock Band sells stronger (comparatively given its lower install base) due to its wireless advantage. In the end, we don't blame Harmonix/EA/MTV for this wired issue -- although it was shady of them to hide it this long -- we're more upset that the consumer is going to get an inferior product due to an obnoxious licensing issue. It's deja vu all over again.
Kilde
Guitar Hero 3 kommer jo med trådløs gitar til begge så jeg fatter ikke hvorfor de ikke klarer det med Rock Band.
Dessuten; både trommene og mikrofonen er jo med kabel på begge versjoner så da blir det jo mengder av kabler uansett. Kjøper man bare guitar så får man jo trådløs til både 360 og PS3.
Gjest Slettet-t9DveYkZ
Nå fikk jeg omsider en grunn til å vurdere en PS3. Jeg fatter ikke at Microsoft er så gniene på sin trådløse teknologi når det er en såpass essensiell funksjon.
[EDIT: Bilde lagt i spoilertag.]
Endret av Slettet-t9DveYkZ
9470464[/snapback]
Hva mente du med den setningen der? Skal du spille rockband så trur jeg du må ha 10 strengs gitaren.
9470464[/snapback]
9472907[/snapback]
Det jeg mente var at hvis man ikke er interessert i å kjøpe hele pakken så får man kjøpt trådløs gitar både til PS3 og 360 versjonen av Rock Band.
