TheClown Skrevet 7. september 2007 Del Skrevet 7. september 2007 Heisann, jeg får en fin feilmelding på scriptet mitt. Skjønner ikke hva jeg har gjort feil. Erroren er den klassiske: Parse error: syntax error, unexpected T_ELSE in /mounted-storage/home20a/sub001/sc20063-GJYD/ru.net/link/add.php on line 106 Klikk for å se/fjerne innholdet nedenfor 100. $sql3 = "INSERT INTO link (link_id, link_title, link_url, link_desc, link_posted, user_id, cat_id) VALUES ('$iddd','$name','$url','$desc','$now','$userID','1')"; 101. $result3 = mysql_query($sql3) or die(mysql_error()); 102. } 103. } 104. } 105. else 106. { 107. // Password is incorrect 108. header ( "Location: index.php"); <?php // SQL connection include "config.php"; // First; check if user is loged in or not. If loged in: feel free to add a link, else you will be located to the loginpage if ( $_SESSION['in'] == TRUE ) { $sql = "SELECT username FROM user WHERE username = '$_SESSION[username]'"; $result = mysql_query($sql) or die(mysql_error()); $num = mysql_num_rows($result); if ($num > 0 ) // login name was found { $sql2 = "SELECT username, user_password, FROM user WHERE username = '$_SESSION[username]' AND user_password = '$_SESSION[password]'"; $result2 = mysql_query($sql2) or die(mysql_error()); $num2 = mysql_num_rows($result2); if ($num2 > 0) // password is correct { // User is logged in. He can now add links to the database if (!isset($_POST['add'])) { echo "<table width='29%' border='0' align='center' >"; echo "<tr>"; echo "<td width='20%' height='25'>"; echo "<form action='add.php' method='post'>"; echo "Name: </td><td width='70%'><input type='text' name='name' value='" . $_POST['name'] . "'></td>"; echo "</tr>"; echo "<tr>"; echo "<td width='20%' height='25'>"; echo "URL: </td><td width='70%'><input type='text' name='url' value='" . $_POST['url'] . "'></td>"; echo "</tr>"; echo "<tr>"; echo "<td width='20%' height='25'>"; echo "Beskrivelse </td><td width='70%'><input type='text' name='desc' value='" . $_POST['desc'] . "'></td>"; echo "</tr>"; echo "<tr> <td width='20%' height='25'>"; echo "</td><td width='70%'>"; echo "<input type='submit' name='preview' value='Forhåndsvis'></td></form>"; echo "</tr>"; echo "</table>"; } else { // User has posted a link if ($_POST['name'] == '') { echo "Du må fylle ut en tittel"; unset ($_POST['add']); include "add.php"; } if ($_POST['url'] == '') { echo "Du må fylle ut en url"; unset ($_POST['add']); include "add.php"; } if ($_POST['desc'] == '') { echo "Du må fylle ut en beskrivelse"; unset ($_POST['add']); include "add.php"; } else { // All the fields is filled and the link will be stored in the database //Create the date $now = date("M d Y - H:s"); // Get the highest ID from the database $idget = "SELECT max(id) FROM link"; $resultt=mysql_query($idget) or die(mysql_error()); while ($roww=mysql_fetch_assoc($resultt)) { $idd = $roww['id']; } mysql_free_result($resultt); // Add one to get a new ID $iddd = $idd + 1; $getuserid = "SELECT username, user_id FROM user WHERE username = '$_SESSION[username]'"; $result4 = mysql_query($getuserid) or die(mysql_error()); while ($rowww=mysql_fetch_assoc($result4)) { $rowww['id'] = $userID; { mysql_free_result($result); // Getting the post info into normal vars for database use $_POST['name'] = $name; $_POST['url'] = $url; $_POST['desc'] = $desc; // Insert all the info into the database $sql3 = "INSERT INTO link (link_id, link_title, link_url, link_desc, link_posted, user_id, cat_id) VALUES ('$iddd','$name','$url','$desc','$now','$userID','1')"; $result3 = mysql_query($sql3) or die(mysql_error()); } } } else { // Password is incorrect header ( "Location: index.php"); } } else { // Username is incorrect header ( "Location: index.php"); } } else { // Not logged in at all header ( "Location: index.php"); } ?> Lenke til kommentar
Mats Danielsen Skrevet 7. september 2007 Del Skrevet 7. september 2007 (endret) Hvordan kan vi vite hva linje 106 er for deg? Legg gjerne koden din inn i pastebin! Endret 7. september 2007 av mats-dani Lenke til kommentar
Runar Skrevet 7. september 2007 Del Skrevet 7. september 2007 (endret) Jeg fant feilen. Rett denne delen, så skal det fungere: PHP <?phpwhile ($rowww=mysql_fetch_assoc($result4)) { $rowww['id'] = $userID; { ?> Du ser sikkert selv hva som er feil Endret 7. september 2007 av Runar Lenke til kommentar
Mats Danielsen Skrevet 7. september 2007 Del Skrevet 7. september 2007 (endret) Edit: På linje 89 her: http://pastebin.danielsenweb.net/?id=6 har du bare lagt inn en "{" det betyr start på en while, if etc. løkke. Du må bruke "}" ikke "{" Endret 7. september 2007 av mats-dani Lenke til kommentar
Martin A. Skrevet 7. september 2007 Del Skrevet 7. september 2007 Indentering er også kos. Gjerne med en editor som markerer hva en } avslutter, som feks Notepad++ Lenke til kommentar
TheClown Skrevet 7. september 2007 Forfatter Del Skrevet 7. september 2007 Hvordan kan vi vite hva linje 106 er for deg?Legg gjerne koden din inn i pastebin! 9448694[/snapback] Skjekk under spoileren du Siden feilen kom så langt ned har jeg ikke skjekka så lagt opp i scriptet som while loopen. Men jeg så feilen nå. Scriptet funker helt fint nå Takk Lenke til kommentar
