Fakta om Hovedkortet X38
Hei!
Trenger litt informasjon angående den nye Hovedkort fronten.
Ser at flere produsenter begynner å introdusere den nye Brikek-settet X38.
- Støtter Hovedkortene både DDR2 og DDR3-minnebrikker? eller er det bare Gigabyte sitt hovedkort?
- Hvilket hovedkort er best akkurat nå, av de som har utgitt sine hovedkort?
- Hvorfor er dette brikkesettet bedre en 680i kort?
The Intel 3 Series Chipsets support DDR2 up to 800MHz, or DDR3 memory with data transfer speeds up to 1333 MHz, enabling speedy access to files and a more responsive PC. The chipsets also support PCI Express* 2.0, which doubles the available bandwidth for graphics cards and are engineered to support Intel® Turbo Memory which enables faster application loading and boot times.
Tar jeg ikke helt feil vil det komme X38-kort som støtter DDR2, kort som støtter DDR3, og en skal heller ikke se bort i fra at i hvertfall noen (om ikke alle) støtter begge deler, men det vil selvsagt ikke være mulig å bruke både DDR2 og DDR3 samtidig.
Fant litt info om ett kommende X38-kort fra Foxconn:
Like so many mainboard-makers, FOXCONN's COMPUTEX showing includes forthcoming product based on the Intel X38 chipset.
And, also like many rivals, FOXCONN's board, the X38A (pictured below) will be a combo design that's able to accept DDR2 or DDR3 memory.
But the X38A is no me-too mainboard. It will have one claimed stand-out feature - the ability to run multi-GPU configurations from either AMD or NVIDIA.
Better still, the company reckons that buyers won't have to make the tough choice between using NVIDIA SLI or AMD CrossFire, since the board will support both!
FOXCONN says the trick will be in the special drivers its planning to release for SLI and CrossFire.
However, it makes no mention of whether they'll be locked to a particular BIOS string that's unique to its own mainboards.
If it doesn't do that, then the drivers may end up being suitable for use with any and all P35/X38 boards! :-)
I følge denne kilden kan det virke som SLi skal fungere på enkelte kort ja. :cool:
Kilde: http://www.hexus.net/content/item.php?item=9017
Endret av _sindre_
  • 3 uker senere...
