Last ned Command & Conquer gratis
Slepper du å laste ned ;).
Follow the instructions below to install and play C&C GOLD
Preparing to Install
1. Insert either C&C disc into your CD drive
2. Open My Computer and explore the CD
3. Right click either the install.exe or setup.exe
4. select PROPERTIES
5. Select the COMPATIBILITY tab
6. Check the check box for "Run this program in compatibility mode for"
7. Select WINDOWS 95 from the drop down menu
8. Click APPLY then OK
9. Double click the .exe file you just modified to launch it
Installing the Game
1. When you're prompted to update DirectX, uncheck the check box so you won't install it. It is extremely important not to install this DirectX update
2. Follow the on-screen instructions to complete the installation
Note: Installing Westwood Chat is not required, it can be canceled if you desire
Installing the Patch
1. Visit ftp://ftp.westwood.com/pub/ccgold and download CCGOLDXPPATCH.ZIP
2. Unzip the files and copy thipx32.dll into the install directory of the game (default path is c:WESTWOODC&C95). You may overwrite the old version of the .dll file
Preparing to Run the Game
1. Go to the install directory of the game (default path is c:WESTWOODC&C95)
2. Right click C&C95.exe
3. Select PROPERTIES
4. Select the COMPATIBILITY tab
5. Check the check box for "Run this program in compatibility mode for"
6. Select Windows 95 from the drop down menu
7. Check the check box for "Disable visual themes"
8. Check the check box for "Turn off advanced text services for the program"
9. click APPLY then OK
Playing the Game
1. Select ?Start > All Programs > Westwood > Command & Conquer 95 > Command & Conquer Windows 95 Edition. Or double click C&C95.exe located in the install directory (default path is c:WESTWOODC&C95)
*Command & Conquer is not online compatible
Endret av Lakrits
Nå holder jeg på å laste ned, men det går jo bare i 10 kb/s. Kommer til å ta 16 timer!
Så jeg har noen spørsmål, siden jeg ikke gidder å vente 16 timer på et kjedelig spill...
Er dette det eldste C&C spillet?
Hvor morsomt er det?
Kan jeg spille det over lan?
Hvordan skal jeg innstallere det? Skjønte ikke helt det over her, ettersom det sto at man skulle sette inn cden.
OG, må jeg laste ned bådew GDI og NOD?
Jeg avbrøt nedlastingen, da jeg ikke orker å vente i 15 timer. Håper noen kan fikse det, så det går litt fortere.
Vanligvis når jeg skal laste ned noe er det jo oppe i 80 kb/s, men når gikk det på 10-15kb/s.
Og jeg hadde ingen ting annet oppe.
9410456[/snapback]
Om du leste hele tråden så kom Lakrits med noen meget gode linker. Ligger stabilt på 500 kb/s der :)
9410502[/snapback]
Jeg hadde litt problemer med å få i gang nedlastingen så lenge jeg valgte "new york" som public server, men når jeg valgte "Seattle" og "san jose" så gikk det så det suser... 250kbs her :)
Edit: Fileshack linkene jeg bruker btw... De andre linkene gir meg ca 10kbs
Endret av L4r5
Det skjedde aldri noe da jeg trykket på det, så jeg lagde meg en liten bruker. Har nå begynt å laste ned, men har allerede falt fra 80 kb/s til 70 kb/s. =\
EDIT: Lar den stå sånn mens jeg tar en liten joggetur, får se hvordan status er når jeg kommer tilbake. :)
Hvilken er fetest, GDI eller NOD?
EDIT 2: ÆSJ, nå har den sunket ned til 68 kb/s. 80 minutter igjen.
Endret av -Jungeldyret
