Morsomheter fra de offisielle WoW forumene!
Tenkte lage en samletråd med alle de flotte postene man finner på dette forumet, slik at folk får noe å le av en gang i blant. For at denne tråden ikke skal dø ut så lett trenger jeg innlegg fra andre som de føler skal være med - Kommer til å legge til teksten på de som ikke er så uhyre lange.
- The warlock he is badly something with... (Warlock)
hello types and girls. something is wrong with warlock. they have HP 2 and mólto healthstone in order to recover the car. you can satisfy the difficulty? I cannot strike the warlocks because they have a health cargo and cannot break off it through the wall of pants. thanks
- Whats wrong with the ''Crusader+Lifestealing' ? (Hunter)
What is so wrong with ''Crusader and Lifestealing''? if you got a Warrior on you, and you got a Hammersting on you, and you used the PvP Trinket and u cannot go ranged, then you must go melee.. if Warior got low health you maybe be lucky and get him down because if Crusader popup it heals + 100Strength and Lifestealing heals sometimes to.. So whats wrong with that Enchants for Hunters?
- Lvl 11 hunter's guide to taking down lvl 14 (Hunter)
what u do is get a PLAIN nightsaber from azuremyst isle and then teach it growl lvl 2. then find a enemy lvl 14-13 that u would normaly get pwned by. send ur nightsaber to attack it and have it use growl to distract the enemy. while the enemy is attacking your nightsaber, step back, and unload every ranged ability u have, concusive shot and other slowing abilitys should be used first.
using this method i took down lvl 14 corrupted treants and other lvl 14 enemys
Arena Gear (Paladin)
The programmers have ripped off the Paladin again, the PvP swords GM swiftblade and GM quickblade (Paladin favorites) were always "one hand". swing speed 1.80.
Gladiater quickblade the only 1.80 upgrade has been made "off hand". Making sure that non duelwielders can't use it.
Thank You Blizzard for adding one more nerf to the Paladin!
A Question about Damage over time spells (Warlock)
Ive always use this DoT sequence. Curse of recklessness..Curse of weakness..Corruption..Curse of agony on bosses in instances. I see the CoR and CoW icon disappear when I put up CoA and corruption. My question is that it says that CoR and CoW lasts for 5 min and that they diminish the armor and attack power of the target, but do they continue to do so after CoA and Corruption have been cast. Am I just wasting mana casting all 4 only for CoR and CoW to be cancelled out by CoA and Corruption?
Andre godbiter:
Mage:
How to own other classes useing FROST!!
Warlock:
New, cant play because of succubus and parents
Succubus and parents UPDATE
Din tur: Ting som må være med:
[ url=... ]navn på tråden[ /url ]
[ quote= Original Poster ] første post i tråden [ /quote ]
[forum = forumets undertittel, som f.ex paladin discussion eller warlock discussion ]
Endret av Per-Stian
