Løsning på Lset i .net
Hei. har et lite problem her.
Driver å oversetter noe vb6 kode til vb2005
    Structure Trans
       <VBFixedString(3), MarshalAs(UnmanagedType.ByValArray, SizeConst:=3)> Public TrType() As Char
       <VBFixedString(8), MarshalAs(UnmanagedType.ByValArray, SizeConst:=8)> Public LocSite() As Char
   End Structure
   Structure t44
       Dim Header As Trans
       <VBFixedString(3), MarshalAs(UnmanagedType.ByValArray, SizeConst:=3)> Public Cashier() As Char
       <VBFixedString(8), MarshalAs(UnmanagedType.ByValArray, SizeConst:=8)> Public Guestnr() As Char
       <VBFixedString(8), MarshalAs(UnmanagedType.ByValArray, SizeConst:=8)> Public Crdamnt() As Char
 end Structure
   Structure DataString
       <VBFixedString(512), MarshalAs(UnmanagedType.ByValArray, SizeConst:=512)> Public Data() As Char
   End Structure
I vb6 kan du gjøre slike
dim t as t44
dim data as datastring
... legger inn data...
lset data = t
Noen forslag på hvordan jeg kan løse dette i Visual Basic 2005?
Endret av don_Vito
