Ny pc! noen endringer!
Cpu:
Intel Pentium4 - 2.53Ghz Socket PGA478
Info: Krever hovedkort med Socket 478 og 533Mhz FSB. Passer IKKE på FCPGA hovedkort!
The Intel® Pentium® 4 processor, Intels most advanced, most powerful processor, is based on the new Intel® NetBurst micro-architecture. The Intel® Pentium® 4 processor is designed to deliver performance across applications and usages where end users can truly appreciate and experience the performance. These applications include Internet audio and streaming video, image processing, video content creation, speech, 3D, CAD, games, multi-media, and multi-tasking user environments. The Intel® Pentium® 4 processor delivers this world-class performance for consumer enthusiast and business professional desktop users as well as for entry-level workstation users.
Minne: Standard 512MB PC2700 DDR SDRAM
Info: ikke noe tiljengelig!
HovedKort:
Asus P4G8X Delux/GD Socket 478
Info:The P4G8X, leveraging Intel®s latest E7205 chipset
The P4G8X, leveraging Intel®s latest E7205 chipset, supports Intel®s Hyper-Threading Technology and processing power of 3.06GHz and beyond to bridge you to a new dimension of computing experience. With dual-channel DDR up to 4GB, the P4G8X provides the bandwidth for the most memory-intensive applications. The ASUS motherboard, of course, also throws in industry-leading technologies such as AGP 8X, Serial ATA and Broadcom Gbit LAN (on P4G8X Deluxe model) for revolutionary performance.
3GHz+ CPU and Intel® Hyper-Threading Technology support
Leveraging the Intel® E7205 chipset to support 3GHz+ P4 CPUs on 533MHz FSB, DDR333 memory, Intel Hyper-Threading Technology and a full-range of advanced features, the P4G8X Deluxe delivers a full-value, high-performance solution for todays most demanding tasks.
Dual-Channel DDR
Dual-channel DDR technology doubles the bandwidth of your system memory and hence boost the system performance to out perform any memory existing solutions in the market. The P4G8X allows you to hancle memory-intensive tasks with ease.
C.P.R. (CPU Parameter Recall)
When the system hangs due to overclocking failure, there is no need to open the case to clear CMOS data. Simply restart the system and the BIOS will automatically restore the CPU default setting for each parameter.
AGP 8X Technology
AGP8X (AGP 3.0) is the next generation VGA interface specification that enables enhanced graphics performance with high bandwidth speeds up to 2.12GB/s. With a bus of 533MHz, AGP8X is twice as fast as AGP4X.
Multi-language BIOS
ASUS provides friendly localized BIOS setup menu to help you configure your system as easy as possible.
** For multi-language BIOS, please visit the ASUS website for supported languages information.
Fan Technology
ASUS Q-Fan technology intelligently adjusts fan speeds according to system loading to ensure quiet, cool and efficient operation.
ASUS® EZ Flash
With ASUS EZ Flash, you can update BIOS before entering operating system. No more DOS-based flash utility and bootable diskette required.
Extreme Overclocking
ASUS P4G8X offers robust overclocking options to maximize your system performance.
Flexible CPU Core Voltage Adjustments in 0.025V increments over defaults
SFS (Stepless Frequency Selection) from 100Mhz up to 200MHz at 1MHz increments
Fixed AGP/PCI frequencies
ASUS propritary C.P.R.(CPU Parameter Recall)
AGP Warning LED
ASUS has designed into this motherboard an AGP Warning LED. The AGP Warning LED automatically stops you from turning on your system with incompatible voltage AGP (3.3V) cards, and protects from permanently damaging your motherboard.
ASUS EZ Plug
The ASUS EZ Plug power connector lets you use your existing power supply and eliminates the need to buy a special ATX 12V power supply to support your Pentium 4 CPU.
AGP Warning LED
ASUS Reliability
All ASUS motherboards are designed and tested to meet the highest quality standards. Responsive customer support and frequent BIOS and driver updates ensure that youre getting the fastest, most reliable performance - all the time. All ASUS motherboards are also backed by a 3-year limited warranty.
Comprehensive Software Bundle
All ASUS motherboards include a valuable software bundle of popular third party programs that enable you to enjoy the full capabilities of your ASUS product:
Trend® Micro PC-cillin 2002 anti-virus program
InterVideo® WinCinema bundled (Gold version only)
ASUS® PC Probe for system monitoring
Grafikk Kort: Sapphire Radeon 9700 Atlantis PRO
Info: Embrace the Next Evolutionary Step in Graphics
Embark on a quest to attain the pinnacle in performance with the RADEON 9700 ATLANTIS PRO. With full support for DirectX® 9.0 and OpenGL, immerse yourself in world’s erupting with life rendered in real-time and devoid of jagged edges.
Features:
128MB DDR memory accelerates the latest 3D games
256-bit memory interface removes hardware performance bottleneck and provides end users with faster 3D graphics
Industrys first 8-pixel pipeline architecture, providing twice the rendering power of any currently competing product.
Supports the new AGP 8X standard, providing a high-speed link between the graphics board and the rest of the PC (2.0 GB/sec)
First to fully support DirectX® 9.0 and the latest OpenGL® functionality
New SMARTSHADER 2.0 technology allows users to experience complex, movie-quality effects in next-generation 3D games and applications
SMOOTHVISION 2.0 technology enhances image quality by removing jagged edges and bringing out fine texture detail, without compromising performance
128-bit floating-point color precision allows for a greater range of colors and brightness
Unique VIDEOSHADER engine uses programmable pixel shaders to accelerate video processing and provide better-looking visuals
ATIs new FULLSTREAM technology removes blocky artifacts from Streaming and Internet video and provides sharper image quality
ADDITIONAL POWER CONNECTION REQUIREMENTS
The Radeon 9700Pro must be connected to the computers power supply to meet its performance and high-speed memory requirements. In order to supply the ATI Graphics Accelerator card with the necessary power, we have included the Power Extension Cable. Use the Power Extension Cable to connect the Radeon 9700Pro to the computer? hard Drive power connector.
1. Remove the power cable from the hard drive.
2. Connect the 4-pin connector of the Power Extension Cable to the Radeon 9700Pro power connector.
3. Connect the Power Extension Cable to the power supply connector.
4. Connect the Power Extension Cable to the Hard Drive connector.
Kabinett: AOpen H600B Midi Tower kabinett SORT - 350W power, ATX/microATX/AT hovedkort
Info: AOpen H600B Midi Tower kabinett SORT
ATX/microATX/Full AT Super Middle Housing
Front USB & Audio: 2 USB / Ear phone / Mic. In / 1394
High expansion capacity -7 slots and 9 drive bays
Bend-in edges ensure safe assembly and installation
Smart slide-in back bracket with no screws needed
Compact design saves space
Equipped with 350W ATX 12V high efficiency switching power supply
P4 ready
Complies with FCC Class B, DoC,and CE
Slide-in/out, Slide board for easy assembly
Support 5 x 2nd 8mm fan.
Side open for top cover
Specifications
Housing Material: Metal
Housing Type: Super Middle-tower
Main Board Size: ATX/microATX/Full AT/flexATX, 305mm x 244mm)ATX M.B.
Front USB & Audio: 2 USB / Ear phone / Mic. In / 6pin or 4pin 1394 (Optional)
Disk Drive Bays: 5.25" x 4/0, 3.5" x 2/1 (external/internal), 3.5" HDD cage x 2 (option)
Dimensions: 460mm(D)x200mm(W)x457mm(H)
Power Supply: 300W ATX 12V, UL/CSA/CE/VDE/S/D/N/ FI/FCC /DoC certified
Ventilation: 8cm Optional DC fan x 5 (1 installed, 4 option)
FCC, CE and Novell: Ready
Net Weight: 9.1kg
Gross Weight: 9.8 kg
ja hva syns dere nå? passer alt sammen her? vis jeg kjøper dette det blir vel en rå maskin eller hva? dette koster: 8700 Kr cirka og er fra MPX vedlig billig! kom igjen og hjelp meg litt mere! :D
Det må jo snart finnes 100-vis med slike innlegg. Hvorfor i all verden ikke sjekke ut de andre innlegga, for maskinene er nesten uten unntak like, enten det dreier seg om intel eller amd løsning.
Begynner å bli lei alle disse innlegga :-?
Og helt enig med Thunstad, innlegget kan godt gjøres vesentlig kortere slik at folk gidder å lese det.
[*]Cpu: Intel Pentium4 - 2.53Ghz Socket PGA478
[*]Minne: Standard 512MB PC2700 DDR SDRAM
[*]HovedKort: Asus P4G8X Delux/GD Socket 478
[*]Grafikk Kort: Sapphire Radeon 9700 Atlantis PRO
[*]Kabinett: AOpen H600B Midi Tower kabinett SORT - 350W power, ATX/microATX/AT hovedkort
[*]Power Supply: 300W ATX 12V, UL/CSA/CE/VDE/S/D/N/ FI/FCC /DoC certified
[*]TOTALT:8700 Kr cirka og er fra MPX vedlig billig! kom igjen og hjelp meg litt mere! :D
Ser greit ut, men PSU burde kanskje være litt større.
en lite oppsumering: bytta ut Kabinettet med et bedre!
E7205,S-ATA,ATX,DualDDR,FW,GLAN
Pris: 1 910,00
8X AGP, 128MB DDR, DVI, TV
Pris: 3 027,00
184pins 333Mhz
Pris: 850,00
CPU: Intel Pentium4 - 2.53Ghz Socket PGA478
PC533, 512KB cache, Boxed inkl. vifte
Pris: 2 288,00
Kabinett: Chieftec Dragon Midi Tower kabinett SØLV
Med dør, 360W power, ATX hovedkort
Pris: 850,00
Sum: 8925 Norske Kroner kommer dette på! se på alt dette nå! er dette bedre? passer alt det er vel ikke noe jeg bør ha bedre av da eller? kom igjen å svar takk! :D
En H600B fra Aopen har da allerede ett 350w PSU som jeg med mine ører nesten ikke kan antyde at vifta går . Litt værre den dere kabinettvifta som sitter der som standard men det kan da en Fanmate gjøre god jobb på .
Og hva er det med folk som gjør at alle må ha Chieftech kabinett , hvor praktisk er den døren foran drevene igrunn ?
!H600B Tips : Fiks hullet bak på kabinett vifta og se at temperaturen dropper 2 grader avlest i MotherboardMonitor på 100% load . Kutt vekk skrap metallet og la det være full blås .
