Crysis demoen er UTE NÅ!
må man ha Vista for å kjøre demoen?
9375860[/snapback]
Nei, det vil derimot krevet et Directx 9 -kort eller DX10. Hvilken Shader Model som kreves er jeg ikke sikker på. Tror det er SM2.0
stemmer det...
Her er midlertidige systemkrav og andre opplysninger
Crysis System Requirements
The Crysis system requirements have not yet been released, though here's some general guidelines:
- You will need a DirectX 9/Shader Model 2.0 (or higher) compatible graphics card.
- Crysis will be backwards compatible with 2 to 3 year old PCs.
- What framerate is acceptable depends a lot on personal preference. Some people can play well with around 20fps and others will not go below 50fps. Obviously those who can't stand "low" frame rates need better hardware or they will have to sacrifice image quality for performance by lowering graphics settings.
- The only DirectX 10 compatible cards available now are the NVIDIA Geforce 8800 Series, GeForce 8600 Series, GeForce 8500 Series, GeForce 8400 Series, ATi Radeon HD 2900 Series, Radeon HD 2600 Series and Radeon HD 2400 Series. There will be more available before Crysis is released. "Vista ready" is simply a clever marketing trick used on the previous generation cards. A card with this badging is not necessarily compatible with DirectX 10.
- SLI and Crossfire multi-GPU technologies are supported (this only works if you actually have two graphics cards connected with one another).
- Single core, Dual core, Multi-core and multi-threaded/hyperthreading processors are supported in both 32-bit and 64-bit modes. We do not know how much processor power is needed, though in a recent PC Gamer UK magazine preview Cevat Yerli said an Intel Core 2 Duo E6600, 2GB RAM, and an NVIDIA GeForce 8800 card could run the game at "ultra detail" settings.
- You do NOT need a DirectX 10 card or Vista to run Crysis.
- You CANNOT run DirectX 10 on XP. A DirectX 10 card does work on XP but only in DirectX 9 mode.
- Special Vista/DirectX 10 effects and optimizations cannot be enabled with Windows XP/DirectX 9 card.
- Optimizations and features specific to Shader Model 4.0 can only be run with cards that support it. The same is true where optimizations and features specific to Shader Model 3.0 are concerned - this includes true HDR.
- Almost all the older media you've seen has been rendered in DirectX 9, which means that Crysis will look absolutely awesome in DirectX 9 as well as DirectX 10. Many of the features included in DirectX 10 are possible in DirectX 9 also.
- Crysis takes advantage of 64-bit processors although only by using a 64-bit operating system such as Windows XP Pro 64-bit edition or Windows Vista 64-bit edition.
- CryENGINE 2 is multi-threaded and Crysis thus takes full advantage of dual/quad-core processors.
- DVD drive is required.
- Crysis will only run on Windows XP or Windows Vista. There will be a dedicated server package for Linux, however.
- There will be two types of multiplayer server, DirectX 10 servers and DirectX 9 servers. This makes online play fairer, due to features used in DirectX 10 which aren't supported in DirectX 9. You probably can play on a DX9 server even if you have a DX10 card and Windows Vista.
- In order to play the game Crysis, the DVD must be in the DVD player.
9375860[/snapback]
Nope :D
Here is a list of confirmed information...
* Crysis will run on both DX9 & DX10 as well as Windows XP and Windows Vista.
* A graphics card that supports Shader Model 2 or higher is required.
* CryEngine2 is estimated to scale back 2 years, and scale ahead 1.5 years.
* A single 7800GTX will run the game quite well on fairly high settings according to Crysis Art Director, Michael Khaimzon.
* Jack Mamais of Crytek said in an exclusive Crysis-Online interview that his X1900XT runs the game very well at reasonably high settings ( still unoptmized ).
* Crysis will dynamically utilize all processing threads available. Meaning quad-core processors will be supported.
dette er ikke "confirmed":
Minimum Requirements
CPU: Athlon 64 3000+/Intel 2.8ghz
Graphics: Nvidia 6600/X800GTO (SM 2.0)
RAM: 768Mb/1Gb on Windows Vista
HDD: 6GB
Internet: 256k+
Optical Drive: DVD
Software: DX9.0c with Windows XP
Recommended Requirements
CPU: Dual-core CPU (Athlon X2/Pentium D)
Graphics: Nvidia 7800GTX/ATI X1800XT (SM 3.0) or DX10 equivalent
RAM: 1.5Gb
HDD: 6GB
Internet: 512k+ (128k+ upstream)
Optical Drive: DVD
Software: DX10 with Windows Vista
går det ann å slette post ? skrev jo samtidig som han over :p
Endret av andy89
Tror jeg ikke kan ha demoen på low engang, må sikkert oppgradere pcen fra 2000kr til 10000kr noe som jeg synes er svinaktigt dyrt
Har desse krava:
Amd Athlon 64 3800+ 2.4Ghz
DDR 2048mb
Geforce 7650 GS 256/512mb
9374763[/snapback]
Da tar du grundig feil. I et intervju med Gamespot sa Cevat hos Crytek at kravene blir langt lavere enn mange tror. I løpet en uke eller to vil vi få de endelige kravene.
I følge intervjuet skal en high end PC som er ca. 2 år gammel kunne kjøre Crysis På hvilke instillinger er uklart.
Link: http://www.gamespot.com/video/931665/61774...sis-interview-6
9375711[/snapback]
Si hvis jeg klarer det på LOW så kommer det til å lagge som ett svin, har HL2 Doom3 og Farcry klarer kun high på dem 3 spillene der
Game Information
Number of Players: 1 Player
DirectX Version: v9.0c
Operating System: Windows XP/Vista
Minimum System Requirements
System: Intel Pentium IV 2.4 GHz or equivalent
RAM: 1024 MB
Video Memory: 128 MB
Hard Drive Space: 8000 MB
Recommended System Requirements
System: Intel Core 2 Duo or equivalent
RAM: 2048 MB
Video Memory: 512 MB
Dette gjeler Bioshock sine krav, da hadde jeg hatt Bioshock på ultra low/low
Da har jeg ikke sjangs i havet med å dra Crysis på Low
Krava er som sagt:
Amd Ahtlon 64 3800+ 2.4ghz
DDRAM 2048mb
9376460[/snapback]
Nå har jeg ikke så stor kunnskap rundt skjermkort lenger.. men et Geforce 7650 GS burde kunne kjøre ganske nye spill uten problemer. Sikker på at det ikke er noe galt med din PC? Ser på tester at det får opp til 70 fps i Far Cry på 1280x1024 osv.
Tror du vil kunne kjøre Crysis ganske greit på low, kanskje også på medium. i 1024x768. Men vi får se.
De tar sikte på at det skal fungere greit med 3-4 år gamle maskiner ifølge Eurogamer, så Shader Model 2.0 er nok.
Spillet vil ganske sikkert ligge på nivå med Bioshock med tanke på ytelse. Med andre ord kjører man Bioshock greit, kjører man dette greit.
Gjest medlem-105082
Hvis jeg har :
en XFX 8800gtx (overclocked fra butikken)
en Core2Duo e6600.
2 gig ddr2 pc6400 ram......
dette er mid-high-Ultra high?
9377004[/snapback]
Så, ja :)
Endret av medlem-105082
Hvis jeg har :
en Core2Duo e6600.
9377004[/snapback]
Så, ja :)
9377352[/snapback]
ooooh, nytt "slapskinndregings" materialet!
Nå gleder jeg meg ennå mer en jeg gjorde før :dribble:
ååååå, jeg kommer til å spille demoen igjennom iallefall 40ganger :love:
9376460[/snapback]
9376828[/snapback]
Helt splitter ny pc, ingen virus eller noe slikt
Klarer jo bare FarCry på high med 2xAA men ikke mer
Har lasta ned alle drivere osv men ingenting hjelper
Prøvde engang for tull å kjøre alt på fullt da lagga det som en vekkerklokke med dårlige batterier
Jeg kjører vel bare 1024x728 eller hva det var
9377698[/snapback]
Rart! Jeg har et 6600GT og jeg kjører 1152x854 med alle instillinger på very high og full HDR uten tegn til lag! :)
Samme med min 2-3 årige PC. Kunne kjøre Far Cry på alt på fullt med 2/4x FSAA og 2xAF på 1024x768.
Specs.
AMD Barton 2800+
Geforce 6600GT
1GB RAM
Så noe må være galt med PC-en. Om ikke noen med samme skjermkort kan bekrefte at det ikke er så godt.
Jeg har Pentium D Dual-Core 3.0Ghz, 2 x 1.0 Gb DDRII 667hz RAM og et GeForce 7600GS 512mb skjermkort og jeg har fullført Bioshock på High settings. Det gikk stort sett veldig greit. Eneste som jeg slet litt med var lyden men jeg regner med og få kjørt de nyeste spilla. Jeg tror det er en ganske god blanding av komponenter og ingen flaskehalser.
Det er mulig jeg trenger et nytt skjermkort etterhvert og kanskje et lydkort. Det jeg har nå er et M-Audio FastTrack Pro usb-lydkort som er egentlig laget for musikkinspilling og ikke dataspill men lyden har vært fin på alt annet enn Bioshock. Jeg får se når Crysis kommer.
Gjest
