(K)Ubuntu server howto
Del
eth0 Link encap:Ethernet HWaddr 00:50:8d:50:e2:1a
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:5
TX packets:35 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 B) TX bytes:5759 (5.6 KB)
Interrupt:23 Base address:0xe000
eth1 Link encap:Ethernet HWaddr 00:04:75:d4:f9:fe
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
Interrupt:19 Base address:0xc000
eth2 Link encap:Ethernet HWaddr 00:10:a7:0a:f1:f0
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
TX packets:100 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:16742 (16.3 KB)
Interrupt:17 Base address:0xb000
eth2:avahi Link encap:Ethernet HWaddr 00:10:a7:0a:f1:f0
inet addr:169.254.9.241 Bcast:169.254.255.255 Mask:255.255.0.0
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:16436 Metric:1
RX packets:64 errors:0 dropped:0 overruns:0 frame:0
TX packets:64 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:4520 (4.4 KB) TX bytes:4520 (4.4 KB)
*-network:0
description: Ethernet interface
product: RTL-8139/8139C/8139C+
vendor: Realtek Semiconductor Co., Ltd.
physical id: 9
bus info: pci@0000:00:09.0
logical name: eth2
version: 10
serial: 00:10:a7:0a:f1:f0
width: 32 bits
clock: 33MHz
capabilities: bus_master cap_list ethernet physical
configuration: broadcast=yes driver=8139too driverversion=0.9.28 latency=32 maxlatency=64 mingnt=32 module=8139too multicast=yes
*-network:1
product: 3c905C-TX/TX-M [Tornado]
vendor: 3Com Corporation
physical id: b
bus info: pci@0000:00:0b.0
logical name: eth1
version: 78
serial: 00:04:75:d4:f9:fe
width: 32 bits
clock: 33MHz
configuration: broadcast=yes driver=3c59x latency=32 maxlatency=10 mingnt=10 module=3c59x multicast=yes
*-network:2
product: VT6102 [Rhine-II]
vendor: VIA Technologies, Inc.
physical id: 12
bus info: pci@0000:00:12.0
logical name: eth0
version: 78
serial: 00:50:8d:50:e2:1a
width: 32 bits
clock: 33MHz
configuration: broadcast=yes driver=via-rhine driverversion=1.4.3 latency=32 maxlatency=8 mingnt=3 module=via_rhine multicast=yes
Da har jeg et spørsmål igjen :)
Jeg har kjøpt meg et nytt kabinett idag (Yeong Yang Server Cube) og skal flytte serveren min over i denne. Serveren kjører Ubuntu 7.10 med bl.a 5 x 500gb sw raid5.
Når jeg nå skal flytte disse diskene over i nytt kabinett, MÅ de kobles på samme satakanaler for at ikke noe av data'en skal gå tapt? Jeg har ikke tenkt å reinstallere Ubuntu.
Og en liten ting til: Jeg har idag en AMD 3500+ (AM2) enkeltkjerne CPU. Dersom jeg kjøper en dobbelkjerne, må jeg da reinstallere noe ? Jeg leste noe om at man måtte legge inn chipset/cpu drivere på nytt, stemmer det?
Spørs om de må legges inn i fstab på nytt, men bare prøv å flytte dem over i samme rekkefølge og se hva som skjer. Du vil ikke miste noe data på det.
Nei, ikke på linux. Bare plugg inn, all hardware probes ved boot, og nye drivere lastes automatisk inn, de ligger alle klare i kjerna. Jeg byttet nylig om fra Opteron 165 med Nforce4 brikkesett og Nvidia 6800GT til Phenom Black Edition og 780G brikkesettet fra AMD med ATI grafikk integrert. Jeg flyttet bare over disken og den bootet rett opp, riktignok til terminal siden skjermkort driveren jeg brukte var den proprietære fra nvidia, men det var fort gjort å skifte den. Alle dagens kjerner har innebygget støtte for flerkjerneprosessorer. Du kan sjekke hvilke CPU'er som detekteres med
cat /proc/cpuinfo
Slik ser det ut til meg nå :)
Klikk for å se/fjerne innholdet nedenfor
cat /proc/cpuinfo
processor : 0
vendor_id : AuthenticAMD
cpu family : 16
model : 2
model name : AMD Phenom 9850 Quad-Core Processor
stepping : 3
cpu MHz : 2506.519
cache size : 512 KB
physical id : 0
siblings : 4
core id : 0
cpu cores : 4
fpu : yes
fpu_exception : yes
cpuid level : 5
wp : yes
flags : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush mmx fxsr sse sse2 ht syscall nx mmxext fxsr_opt pdpe1gb rdtscp lm 3dnowext 3dnow constant_tsc rep_good pni cx16 popcnt lahf_lm cmp_legacy svm extapic cr8_legacy abm sse4a misalignsse 3dnowprefetch osvw ibs
bogomips : 5016.44
TLB size : 1024 4K pages
clflush size : 64
cache_alignment : 64
address sizes : 48 bits physical, 48 bits virtual
power management: ts ttp tm stc 100mhzsteps hwpstate
processor : 1
cpu family : 16
model : 2
stepping : 3
cpu MHz : 2506.519
cache size : 512 KB
physical id : 0
siblings : 4
core id : 1
cpu cores : 4
fpu : yes
fpu_exception : yes
cpuid level : 5
wp : yes
bogomips : 5013.10
clflush size : 64
processor : 2
cpu family : 16
model : 2
stepping : 3
cpu MHz : 2506.519
cache size : 512 KB
physical id : 0
siblings : 4
core id : 2
cpu cores : 4
fpu : yes
fpu_exception : yes
cpuid level : 5
wp : yes
bogomips : 5013.11
clflush size : 64
processor : 3
cpu family : 16
model : 2
stepping : 3
cpu MHz : 2506.519
cache size : 512 KB
physical id : 0
siblings : 4
core id : 3
cpu cores : 4
fpu : yes
fpu_exception : yes
cpuid level : 5
wp : yes
bogomips : 5013.10
clflush size : 64
Står det noko om oppsett av Torrentflux eller liknande ein plass? Visst ikkje, vurdert å slenge det med? :)
Godt poeng, web-interfacer er en gullgruve som går mange hus forbi. Nå har jeg nevnt KTorrent, og den har alt, også en kapabel web-interface.
Aporopå torrent, jeg gikk glipp av Formel1 i Monaco så da fikk jeg en god anledning til å teste ut Ktorrent i praksis på serveren min. Har foretrukket uTorrent i Windows og takket være plugins syns jeg Ktorrent ser ut til å være et greit alternativ (uTrorrent kan også brukes, men det er litt mer knot å få i gang etter hva jeg har forstått)
Men en ting var litt rart med Ktorrent, jeg fikk tilsynelatende ikke begrenset upload og verdien jeg satt så ikke ut til å ha noen effekt, og dermed går det litt utover surfing på andre maskiner.
Er det fler som har oppleved dette, eller er det bare meg..? (Kubuntu 8.04)
Har aldri hatt noen problemer med å begrense upload i KTorrent, men har ikke hatt begrensning skrudd på på en stund, siden jeg har fiksa meg traffic shaping på boksen min.. (bruker debian-boksen som router i tillegg til alt annet..) Dette gir websurfing, ssh-tilgang, online-spill etc prioritet over torrents og ftpnedlastinger.
Traffic shaping var forøvrig ikke spesielt vanskelig å få til, så om det er av noens interesse kan jeg lage en liten "miniguide" som Del kan putte inn i denne tråden?
Fyr løs, det er helt sikkert interesse. Ellers oppfordrer howto'en til å bruke en ruter med OpenWrt, og der settes QoS opp enkelt via web-interfacen X-Wrt.
Hvis Ubuntu (eller du) har generert et unikt nummer for hver disk med vol_id, som ligger i /etc/fstab så skal man vel kunne flytte rundt på koblinger så mye man måtte ønske.
Sånn her ser fstab fila mi ut
# <file system> <mount point>   <type>  <options>	   <dump>  <pass>
proc			/proc		   proc	defaults		0	   0
# /dev/hdb1
UUID=33816007-2b3f-4362-aaeb-7e80e6aee621 /			   ext3	defaults,errors=remount-ro 0	   1
# /dev/hdb5
UUID=fc13afab-f1f7-4bdd-845c-b70ca345e420 none			swap	sw			  0	   0
/dev/hda		/media/cdrom0   udf,iso9660 user,noauto,exec 0	   0
/dev/fd0		/media/floppy0  auto	rw,user,noauto,exec 0	   0
/dev/md0		/media/storage  auto	defaults 0 3
/dev/md1		/media/downloads auto   defaults 0 3
/dev/sde1	   /media/serier   auto	defaults 0 3
Jeg har nå fått det nye kabinettet mitt og kunne tenkt meg å flytte over all HW til det nye kabinettet, men er VELDIG redd for å miste noe av dataen :(. Alle dokumenter osv har jeg seff backup av, men det er endel videoer osv der som jeg ikke har backup av og som jeg gjerne fortsatt skulle hatt etter flytting.
Jeg tror jeg kan klare å få alt over på 1TB ekstern disk, men har ikke så veldig lyst til å kjøpe en ekstern disk til bare for å flytte over dataen, mens jeg fikser kabler over i nytt kabinett.
Det kan jeg selvfølgelig, men det er en liten utfordring forbunnet med det :)
Som du ser på bildene i denne tråden så er alle HD'ene i et eget kammer og det er kun et lite hull i "skilleveggen" hvor ALLE sata/strømkabler går gjennom. Det å finne ut hvilke kabler som går til hvilke disker er en rimelig tidkrevende prosess vil jeg tro. En liten designfeil der :(
Derfor hadde jeg håpet at det var en annen smart måte å gjøre det på. Egentlig så begynner muligheten for å kjøre ut alt på disk å høres mer og mer fornuftig ut egentlig, selv om det innebærer at jeg må kjøpe meg en ny disk :(
