gammalerik Skrevet 23. august 2007 Del Skrevet 23. august 2007 (endret) Da var endelig patch 1.0004 til stalker ute:) Har bl.a. ytelsesforbedringer som dual-core optimalisering. Standalone server + masse snacks http://www.fileplanet.com/180142/180000/fi...%5BWorldWide%5D http://www.fileshack.com/file.x/11028/S.T....+Patch+-+Non-US Endret 23. august 2007 av gammalerik Lenke til kommentar
Scortech Skrevet 23. august 2007 Del Skrevet 23. august 2007 (endret) Jepp..Her er den komplette listen -= 1.0004 =- Saved games. Saved games from 1.0003 version will work with 1.0004 version. Connectivity. Connecting to the server will be possible only if the host's version of the game is the same as yours. Patch 1.0004 changes and fixes: Optimization: 1. Calculating detailed objects was moved to the second CPU stream. 2. Engine optimization, which resulted in FPS 10-15% gain. 3. Shaders optimization. MP features: 1. Implemented the standalone dedicated server. 2. Retail version now works correctly with the standalone dedicated server. 3. Added remote control for the dedicated server. 4. Max ping disconnect option implemented. 5. Self-correcting network packets wrapper was implemented. This resulted in better ping values and traffic reduction by 50-100%. 6. Artifacts counter is not shown in the statistics. 7. Checking available maps without disconnecting the current game is now possible. 8. The list of the players is not dropped to the beginning upon the attempt to scroll it. Now it became easier to put the players on ban voting. 9. Fixed some bugs with defining the cause of death. 10. The exploded grenade does not continue lying on the ground after the detonation. 11. Fixed the artifact activation and the spawned anomalous zone functioning algorithm. MP crash fix: Fixed all known crashes. SP fixes: 1. Fixed the bug with shooting from the grenade launcher. The grenade is fired with the first shot now. 2. Fixed the disappearing weapons when crouching for a long time. 3. Fixed the game crash on Pripyat location, when the player approached any of the monolithians' camps. 4. Fixed Voronin's tasks to eliminate the bandit Poker. 5. Fixed the random quests at the Wild Territory. 6. Fixed the random task to destroy the bandits' camp at the Cordon. 7. Fixed the random Barkeep's task to clear the snorks lair at the Dark Valley. 8. Fixed the bug with the automatic task to defend the camp when switching location or saving/loading the game. 9. Fixed the random quest to destroy the mutants lair when pseudo dogs are nearby. 10. Fixed the task to destroy the mutants lair. 11. Fixed the random tasks with the raids of characters' camps. 12. Fixed the choice of goods at Barkeep and Petrenko after completing the random tasks. 13. The wounded do not run away from the grenade now. 14. The zombies at Yantar do not run from the grenade now. 15. Fixed the crash caused by the patrol route at Yantar. 16. Fixed the crash caused by the patrol route at Agroprom Research Institute. 17. Fixed the task with getting rid of the Duty group in the village at the Military Warehouses level. 18. Fixed the bug with repeating the scene of the Duty group ambush at the beginning of the Military Warehouses level. 19. Fixed the bug with camera fly-through on the stadium at Pripyat. 20. Fixed the bug with Bes character, when the latter couldn't be healed. Endret 23. august 2007 av Scortech Lenke til kommentar
LarZen Skrevet 23. august 2007 Del Skrevet 23. august 2007 (endret) Ser ut som denne patchen fikset mitt problem, som var at når jeg trykkte Esc for å lagre så ble jeg kastet ut i Windows. Endret 23. august 2007 av _LarZen_ Lenke til kommentar
DeviantFractal Skrevet 24. august 2007 Del Skrevet 24. august 2007 Endelig, denne har jeg ventet lenge på Lenke til kommentar
zeox Skrevet 24. august 2007 Del Skrevet 24. august 2007 gi meg free-roaming patchen! Lenke til kommentar
EviLEddiE Skrevet 24. august 2007 Del Skrevet 24. august 2007 (endret) Ser ut som at 1.004 ikke er kompatibel med eksisterende mods til spillet: if you expect that mods with "unofficial" freplay are working ... then bad news -- all mods using v.1.0003 altered spawn file are not working with 1.0004. .... more bad news (especially in the light that SP SDK is not here yet) is that the only spawn modding tool (xrSpawner) is also incompatible with the new 1.0004 spawn file. So to rework all these mods to be compatible with 1.0004 ... it will take lots of time Og jeg som spilte med Faiakes modden...forhåpentligvis tar det ikke så lang tid for en oppdatering, i motsetning til det som det var hintet til i denne kommentaren. Endret 24. august 2007 av EviLEddiE Lenke til kommentar
WaterMarked Skrevet 5. september 2007 Del Skrevet 5. september 2007 (endret) Merket ikke nye økning i ytelsen når jeg installerte patchen. Spillet greide forsatt å kvele skjermkortet mitt når jeg spiller uten aa og alt annet på fult på 1280*1024... Spiller igjen med 1003 siden jeg synes spillet er litt dødt orginalt og bruker Faiakes modden. Men spillet var nokså stabilt etter den siste patchen, når jeg spiller med 1003 så klikker det av og til selv om jeg spiller uten HDR. Tidligere løste det problemet, men hjelper ikke nå... Spilte med noen andre mods første gangen, husker ikke hva de heter men de var bra. Mye mer liv i sonen, noe som gjør at spillet føles mer levende. Håper det kommer flere mods til den nyeste patchen slik at spillet blir mer stabilt. Endret 5. september 2007 av The_Free_Man Lenke til kommentar
Floyd_90 Skrevet 8. september 2007 Del Skrevet 8. september 2007 (endret) Jeg installerte patchen, og klarer igjen ikke å loade tilbake savene mine.. Kan en løsning være å ta vare på savene jeg har nå, installere stalker på nytt UTEN patch, og så legge savene inn igjen? Synes dette er en god plan, men finner ikke ut hvor savene til Stalker legger seg.. Noen som vet?? Takk for svar Endret 8. september 2007 av RagnaRock Lenke til kommentar
perpyro Skrevet 8. september 2007 Del Skrevet 8. september 2007 Float32 Alpha Build modden fungerer nå i iallefall med denne patchen. Lenke til kommentar
Floyd_90 Skrevet 8. september 2007 Del Skrevet 8. september 2007 (endret) Float32 Alpha Build modden fungerer nå i iallefall med denne patchen. 9451064[/snapback] hmm... Men det funker hvertfall ikke her Drittspill... Endret 8. september 2007 av RagnaRock Lenke til kommentar
perpyro Skrevet 8. september 2007 Del Skrevet 8. september 2007 Kan det ha noe med at jeg installerte spillet og patchet det med det samme før jeg testa med den modden? Har nettopp kjøpt Stalker nemlig. Lenke til kommentar
Floyd_90 Skrevet 8. september 2007 Del Skrevet 8. september 2007 (endret) Kan det ha noe med at jeg installerte spillet og patchet det med det samme før jeg testa med den modden?Har nettopp kjøpt Stalker nemlig. 9451359[/snapback] Ja det er grunnen, for dersom du saver i en patch, og installerer en ny, så klarer du ikke å åpne savene dine... Endret 8. september 2007 av RagnaRock Lenke til kommentar
Floyd_90 Skrevet 8. september 2007 Del Skrevet 8. september 2007 (endret) Men tilbake til mitt spørsmål; Er det noen som vet hvor savene lagrer seg på pcen?? Ellers blir jeg nødt til å begynne forfra igjen! Endret 8. september 2007 av RagnaRock Lenke til kommentar
EviLEddiE Skrevet 8. september 2007 Del Skrevet 8. september 2007 (endret) De lagres i C:\Users\Public\Documents\STALKER-SHOC\Savedgames Nå ser det også ut som at versjon 2.4 av Faiakes-modden (kompatibel med 1.0004) er på vei, forhåpentligvis blir den klar i løpet av kort tid. I mellomtiden spiller jeg nå med HeEr0's Mod Pack, som funker tålig greit denne også. Men ingenting slår Faiakes etter min mening Endret 8. september 2007 av EviLEddiE Lenke til kommentar
Scortech Skrevet 8. september 2007 Del Skrevet 8. september 2007 Det lagrer seg i "C:\Documents and Settings\All Users\Documents\STALKER-SHOC" mener du.. Lenke til kommentar
EviLEddiE Skrevet 8. september 2007 Del Skrevet 8. september 2007 Det lagrer seg i "C:\Documents and Settings\All Users\Documents\STALKER-SHOC" mener du.. 9452554[/snapback] Ja, hvis man har Windows XP. Men hvis man har Windows Vista derimot... Lenke til kommentar
Floyd_90 Skrevet 8. september 2007 Del Skrevet 8. september 2007 Det lagrer seg i "C:\Documents and Settings\All Users\Documents\STALKER-SHOC" mener du.. 9452554[/snapback] Ja, hvis man har Windows XP. Men hvis man har Windows Vista derimot... 9452675[/snapback] Det har jeg ikke (heldigvis) Takk for svar Lenke til kommentar
perpyro Skrevet 8. september 2007 Del Skrevet 8. september 2007 Hvilken fordeler får man ved å legge savegame i OSet istedenfor i selve spillmappen slik man gjør med alle andre spill?? Eller for å spørre litt enklere, hvorfor gjør man det på denne måten? Lenke til kommentar
