Er dette den endelige bekreftelsen på D300 og D3?
Hvis Nikon kommer med 300D allerede nå; er det vel et tegn på at de ikke var fornøyd med D200? Sensoren kanskje ?
9339884[/snapback]
Det er nok heller det motsatte. D200 har solgt sykt godt - langt over forventningene - og mange proffer liker den fordi den er robust og har proff betjening, samtidig som den er (relativt) liten og lett.
Om det for eksempel er slik at Nikon (eller Sony) har dratt en sinnsykt god, ny APS-C-brikke opp av hatten, så vil det ikke være unaurlig å hoppe over det tradisjonelle "hvileskjæret" med en D200s, og gå rett på D300...
Klippet fra et innlegg på dpreveiw:
A little more grabbed from Google...
from: popsci.typepad.com/popsci/2007/08/nikons-pro-came.html
It leads with the Deathstar of SLRs, the D3. The biggest change is, in fact, one of bigness. Nikon equipped the new camera with a 36x23.9-millimeter image sensor that’s nearly as large as an old 35-milimeter film frame. Previously only Canon made these “full-frame” sensors, which capture extreme wide-angle shots and have larger pixels to soak in more light.
A small step below the D3 is the new D300. Its 12.2-megapixel sensor is in the standard size of 24-by-16 millimeters, and sensitivity stops at a still-impressive ISO 3200 ... Otherwise, it’s virtually identical to the D3, and probably at a steep discount. The D200 it’s replacing currently costs about $1600.It will be going head-to-head with Canon’s other new camera, the 10.1-megapixel EOS 40D
which sells for $1300. I spent a few happy weeks with the D200 last summer and fell in love with its easy controls and spot-on color accuracy. My only gripe was with the low-light performance—an area where Canon dominates. If Nikon’s new focus on light-sensitivity pays off, we’re in for a real clash of the camera titans. August 22, 2007 in Computers & Electronics
JP Stoney var innom her. Han vet nok noe om dette...
9340211[/snapback]
Men han er offisiell, mao har han taushetsplikt.
9340224[/snapback]
Ja, men at han er inne og lusker tyder vell på noe også..?
9340253[/snapback]
Sikkert for å få seg en god latter av våre ville antagelser ;)
