Får ikke det vi betaler for! Ventelo 20Mbit linje.
TPTEST 5.0.2 logg:
TPTEST 5.0.2
2007-09-07 14:00:16
Home Edition (Build 6000)
TCP Window size: 8192
External IP Address: 193.71.107.134
Ethernet-kort Lokal tilkobling:
Tilkoblingsspesifikt DNS-suffiks : bluecom.no
Beskrivelse . . . . . . . . . . : VIA Networking Velocity Family Gigabit Ethernet Adapter
Fysisk adresse . . . . . . . . . : 00-50-8D-67-FD-72
DHCP aktivert . . . . . . . . . . : Ja
Automatisk konfigurasjon aktivert : Ja
IPv4-adresse. . . . . . . . . . . : 193.71.107.134(Foretrukket)
Aktive tilkoblinger
Prot. Lokal adresse Ekstern adresse Tilstand
TCP 0.0.0.0:135 0.0.0.0:0 LISTENING
TCP 0.0.0.0:49152 0.0.0.0:0 LISTENING
TCP 0.0.0.0:49153 0.0.0.0:0 LISTENING
TCP 0.0.0.0:49154 0.0.0.0:0 LISTENING
TCP 0.0.0.0:49155 0.0.0.0:0 LISTENING
TCP 0.0.0.0:49156 0.0.0.0:0 LISTENING
TCP 0.0.0.0:49157 0.0.0.0:0 LISTENING
TCP 193.71.107.134:139 0.0.0.0:0 LISTENING
TCP 193.71.107.134:49483 194.19.40.72:80 TIME_WAIT
TCP 193.71.107.134:49484 207.68.183.124:80 ESTABLISHED
TCP 193.71.107.134:49485 194.19.40.72:80 TIME_WAIT
TCP 193.71.107.134:49487 213.136.43.225:80 TIME_WAIT
TCP [::]:135 [::]:0 LISTENING
TCP [::]:445 [::]:0 LISTENING
TCP [::]:5357 [::]:0 LISTENING
TCP [::]:49152 [::]:0 LISTENING
TCP [::]:49153 [::]:0 LISTENING
TCP [::]:49154 [::]:0 LISTENING
TCP [::]:49155 [::]:0 LISTENING
TCP [::]:49156 [::]:0 LISTENING
TCP [::]:49157 [::]:0 LISTENING
UDP 0.0.0.0:123 *:*
UDP 0.0.0.0:500 *:*
UDP 0.0.0.0:3702 *:*
UDP 0.0.0.0:4500 *:*
UDP 0.0.0.0:5355 *:*
UDP 0.0.0.0:49154 *:*
UDP 127.0.0.1:1900 *:*
UDP 127.0.0.1:49171 *:*
UDP 127.0.0.1:49331 *:*
UDP 193.71.107.134:137 *:*
UDP 193.71.107.134:138 *:*
UDP 193.71.107.134:1900 *:*
UDP 193.71.107.134:49330 *:*
UDP [::]:123 *:*
UDP [::]:500 *:*
UDP [::]:3702 *:*
UDP [::]:3702 *:*
UDP [::]:49155 *:*
UDP [::1]:1900 *:*
UDP [::1]:49329 *:*
TCP nedströms : 670.37 kbit/s
TCP uppströms : 0 bit/s
UDP nedströms : 0 bit/s
UDP uppströms : 0 bit/s
----------- END --------------
Hva tror dere?
Jeg personlig hadde sagt opp linja på dagen hvis det er slik at du ikke får noen som helst form for hjelp av Ventelo når du har disse vanskelighetene og den ræva linja....
Btw...du har sjekket netverkskortet at det funker som det skal da...En kompis slet lenge med linja hos en eller annen isp og da viste det seg at det var netverkskortet som ikke funka som det skulle....
Ok, gjorde ikke det da..
Han jeg snakket med sa at det måtte være noe feil med sentralen eller noe sånt.
Han målte ca 11 Mbit/s til oss. Men det skulle vært mer sa han, jeg sa at jeg har hatt ca 15-16 Mbit/s en god stund før.
Han så at de ikke kunne gjøre noe mer før jeg har fått svar på mailen jeg sendte.
Får bare vente da.. :nei:
Her er svarene jeg sendte de:
Test 1
Tidspunkt: Ca klokken 16.00
TCP, sending: 871.13 kbis
TCP, mottaking: 2.06 Mbits
UDP, sending: 931.55 kbits
UDP, mottaking: 11.18 Mbit
Test 2
Tidspunkt: Ca klokken 18.00
TCP, sending: 871.13 kbits
TCP, mottaking: 1.99 Mbits
UDP, sending: 931.73 kbits
UDP, mottaking: 11.13 Mbits
Test 3
Tidspunkt: Ca klokken 20.00
TCP, sending: 884.24 kbits
TCP, mottaking: 1.54 kbits
UDP, sending: 946.96 kbits
UDP, mottaking: 11.20 Mbits
Dette stemmer dårlig, ikke sant?
9487962[/snapback]
Du må jo regne med å vente. Ikke alt løses helt magisk :)
9488910[/snapback]
Når det gjelder Ventelo og mail ville jeg ikke akkurat sittet ved pc`n og ventet på svar fra dem.... :whistle:
På support så ligger nok Ventelo enda på steinalder nivå iforhold til mange andre isp`re....Jeg personlig er så til de grader missfornøyd både med support og fart på linjen min fra dem...Supporten til Ventelo er kun folk som er tatt rett inn fra gata uten og ha fått noen som helst opplæring virker det som men det kan jo også bare være at de ikke kan bedre....Hvorfor jeg ikke bytter isp er kun for at vi får fiber til påske og jeg orker ikke bryet med oppsigelser og bytte problemer som fort kan oppstå....
Endret av Znoken
Slike forskjeller på TCP og UDP er typisk for dårlig (eller defekt) hardware.
Kan høres ut som om at modem (eller annet) hos deg eller kort i sentralen ikke fungerer normalt.
Har selv opplevd tilsvarende med et Billion routermodem som jeg brukte mot en nextgentellinje. Etter jeg slo av routerfunksjonen (=bridgemode) fungerte det helt fint, men med routing i routermodemet fikk jeg alt fra 10-60% av normal hastighet.
9498141[/snapback]
Tviler ikke et sekund på at noe er galt her nei.
Spm. er om Ventelo gidder å gjøre noe med det i nermeste fremtid :roll:
Mens jeg venter på svar fra de..
Hva er egentlig TCP og UDP?
Endret av LockNess
TCP er feilrettet data (som det du leser nå), mens UDP er en datastrøm uten noen korreksjon.  UDP brukes til å streame audio og video for at det er viktigere å få fram pakkene til rett tid enn at alle er OK.  TCP brukes til overføring av data som ikke tåler feil.
9504699[/snapback]
Ok, så UDP er på en måte "rå materialet"?
UDP er hastigheten modemet mottar, mens TCP er hastigheten på pakkene modemet sender til meg?
