Ny Software til Nokia 6610
:D
Til informasjon. Det er i disse dager ny sw til Nokia 6610. Den som nå er på telefonen heter 3.09, den nye heter etter det jeg forstod 4.18.
Den siste softwaren fixer en bugs. bl.a at telefonen plutselig skrur seg av samt at man slipper feilmelding av det står på displayet Simkort Låst.
Leverte min telefon inn i dag, så hvis det er noen som allerede har levert inn sin for oppdateringer er vi sikkert veldig interessert i erfaringer.
Er det noen som har hørt om hva tid Nokia 6100 vil komme på markede?
Og eventuelt hva med denne kontra Siemens S55???
Personlig synes jeg Nokia 6100 ser helt rå ut designmessig.
Hvis noen er interessert, så er dette changeloggen:
MCU SW Changes & Improvements from v 3.09 to 4.18
Changes and improvements:
Call and network management
? Automatic redials can be made, when fixed dialling numbers are activated
? New calls can be made without new limits after deactivation of Call cost limit
? Menu functions ?Activate? and ?Cancel? are available in Call waiting application when ALS is active
? Calling name presentation feature added
MESSAGING
MMS
o Message size has been increased from 30 kB to 45 kB
o Menu item: save image added to MMS saved items folder to save images to Gallery
o Images file lists are sorted same way than in Gallery
o Received messages font size depends on the used font settings
o Font size stays same regardless of place where the message is read
o Reply option is possible only for received messages
o Image file list is displayed also after changing the language
o Name of message sender is shown also when phone memory is in use
o Received PNG files can be attached to messages
o In memory full situation SMS tone is played even when only first part of concatenated SMS is received
o Message time stamp is always updated when the other parts of concatenated message are received
o Header text is shown in the topics of info messages
o Fixed dialling number support added
o Alert tone can be selected from Gallery
? Help text has been added to ?GPRS connection? menu choice item
? When running MIDlet that is interacting with the network, first press of the end key ends GPRS connection and second
press of end key quits the MIDlet
? Note ?Always online not available? is displayed on the screen, when end user tries to select Always online option in
NMO3+PCCCH/PBCCH cell
? Improvement to GPRS attach/detach collision handling
? Changed page mode handling in case of downlink immediate assignment where IA Rest Octects are not present
? Improvements to GPRS detach procedure. Combined detach type is now always used when needed.
? Improvement to Extended Paging handling in non-DRX mode
? Improvements to Location Services
? Improvement to handling Routing Area Update Reject cause #14
? The name of the activated WAP service setting can be displayed in the WAP service text notification, when connection is
done to WAP service
? Item Home in the Service menu can be replaced with the ?name? of the active service setting
Browser WAP
? Default value of session mode has been changed to permanent
? Browsing can be continued normally without any action after receiving MMS
? Pressing end key while downloading quits the download
? Pages with 256 color images can be opened
? Pages without any titles can be book marked
? Information note is displayed, when trying to send too long bookmark as a text message
? Wap over CSD connection stays on after MMS sending
Games
? Bounce version is now 1.8
o General improvements in level 6 (Ball handling, trampoline improvement)
o A wandering spike improvement in level 8
o Jump improvement in level 9
o Improvement of the interaction between the ball and the screen in level 10
? Wrapper class can be used in MIDlets, for example to renewal of license. Now wrapper class waits for the user response (OK or
cancel) and after selecting ok, charging is done and application is executed.
? There is now 6 bookmarks for images, tones, games and applications services
? Separate bookmarks for games and applications services implemented
Phonebook
? Ringing tones from gallery can be set to different caller groups
? Sort order of special Chinese characters has been changed in Chinese phonebook
Data
? Images and applications can be transferred between phone and PC using Data cable DKU-5
SIM
? SIM Application Toolkit
o Layout changes in wait bar Improvement to PLMN search time and network refresh procedure
? The menu ?Confirm SIM service actions? can be now enabled or disabled for customer variants
Operator List
Mobile network code and displayed name (Updated list of operators)
New operator:
?MTS BY? (257/02)
?WTTCKy? (310/11)
?T-Mobile? (310/31)
?AT&T? (310/38)
?T-Mobile? (310/58)
?ARDGMC? (310/64)
?USA ONELINK? (310/460)
?W V W? (310/530)
?DobsonUS? (310/560)
?TUNISIANA? (605/03)
?AFRICELL? (607/02)
New country/operator:
?TELECOM BDA? (350/01) Bermuda ?BDA? GSM1900
?MOBILITY? (350/02) Bermuda ?BDA? GSM1900
?MR MATTEL? (609/01) Islamic Republic of Mauritania ?MR? GSM900/1800
Name changed:
?E VODAFONE? -> ?vodafone ES? (214/01)
?GSY-TEL? -> ?C&W? (234/55)
?PRONTO GSM? -> ?Manx Pronto? (234/58)
?INA AIRTEL? -> ?AirTel? (404/31)
?AIRTEL? -> ?AirTel? (404/45)
?AIRTEL? -> ?Airtel? (404/49)
?94 SYRIA? -> ?SYRIATEL? (417/02)
?SyriaTel? -> ?SYRIATEL? (417/93)
?Egy Vodafone? -> ?vodafone EG? (602/02)
?CELTEL RC? -> ?CELTEL CD? (629/01)
?CELTEL CD? -> ?CELTEL RC? (630/02)
?UTL_TELECAL? -> ?UTL Telecal? (641/11)
? Translation of 'Gallery' menu in Hungarian language changed to be Galéria
? Translation of ?Silence? in Hungarian language changed to be Némít
? Am/pm texts were changed to Latin in Hindi language
? Pressing ?0? will give horizontal line in Traditional Chinese language
? NOKIA 11 x 12 bitmap Chinese font has been replaced by standard 11 x 12 bitmap font
? Am/pm texts are displayed in idle in Creek language, when 12 hour time format is in use
Other changes
? Screen saver is activated normally when phone is in Full Car Kit CARK126
? White color in black and white operator logos is now transparent
? Handling of ringing tones and vibra are improved.
Et nokia-verksted burde gjøre det, men det koster penger.
Du får kun oppgradert gratis hvis du kan vise at det er bugg i den.
Er det noen som har en liste eller no sånt over hvor jeg kan finne et nokia verksted og hvor mye oppgraderingen koster?
oppdatering er gratis så lenge du er innenfor garanti-tid.. jeg har ihvertfall aldri betalt for det hos Nokia service sentre.. bug eller ikke.
oppdatering er gjort på en halvtime om de har tid til deg så det er mulig å vente mens de gjør jobben..
Dette er feil. Jeg var i kontakt med Nokia for ca. et år siden angående noe som viste seg å være en programvarefeil på telefonen (ble henvendt videre til Nokia av Telenor). Jeg fikk til svar at såfremt det fortsatt er garanti på telefonen er det gratis å få programvareoppdattering hos autoriserte Nokia verksteder.
Men sørg for at du finner et sted som har verksted og kan utføre oppgraderingen mens du venter. Mange forhandlere må sende telefonene inn til et autorisert verksted og da må du regne med å vente en uke eller to.
urk, vel Nokia Service Sentre finner du informasjon om på www.nokia.no (det kunne du fint funnet ut på egenhånd istedenfor å satse på at andre personer som meg er dumsnille nok til å bruke tid på det).
www.nokia.no -> mobiltelefoner -> service & support
(hm, jeg trenger hjelp med min telefon, hvor går jeg da tro??)
og til slutt:
-> Servicebutikker!
Alle menylinkene jeg refererer til er da på høyre side av skjermen. Beklager litt skarp post blir av og til lei av at folk ikke gidder å bruke 1 minutt av sin tid på å finne ut av det selvforklarende og logiske, slik at dumsnille personer som meg bruker 5 minutter av vår tid på å skrive et svar :-?
  • 3 uker senere...
