Får ikke installert språkpakke (Norsk)
Får denne beskjeden: Mislykket! Code 2
Hva er dette og hva kan jeg gjøre?
9280322[/snapback]
Fra MS support:
"Occasionally, language pack installation fails, and you receive error code 1 or error code 2. This behavior typically occurs when Windows Update has installed another update that has requested a restart. If you experience this issue, restart the computer, and then reinstall the language pack without selecting any other updates."
Endret av filthyhabits
