My2Cents Skrevet 14. august 2007 Del Skrevet 14. august 2007 (endret) Det er lite snakk om det spillet her. For min del gleder jeg meg som en liten unge til dette spillet kommer 01.09. Endelig et bra bilspill til PS3 og det er jaggu på tide. Begynner å bli litt smålei den ene banen i GT HD så det ska bli deilig å kjøre andre baner. Et bra Rally spill ville vært bra til konsollen, vi trenger det. Jeg var ikke så veldig fornøyd med Colin McRae: Dirt til Xbox 360, og spillestilen vil neppe forandre seg mye til PS3 når det kommer ut. Sega Rally virker som et lovende spill som kan bli skikkelig bra.¨ Her er litt info om Sega Rally The new Racing Studio has been formed by around 50 racing game veterans drawn from the likes of Codemasters, Rare, Criterion and Rockstar, which, to judge by the demo, provides a perfect balance. The finished game will include over 30 cars: four-wheel drive, two-wheel drive, classic cars, and some bonus cars. But each one will be available in various different liveries, and most will have different variants (set up for driving on tarmac, or gravel, or safari, for example). Detaljer fra en demo Taking place in a tropical idyll, it boasts swaying scenery, lush palm trees, lagoons with boats bobbing on the surface, and the occasional local villager cycling around. And the detail is staggering: the engine throb is the dictionary definition of throaty; all the environments and vehicles are self-shadowing; you can see the suspension of each wheel bouncing independently; and the dust haze and mud that splatters the cars matches the surfaces that they're driving through - which means they'll even wash off when you splash through puddles. Apart from the up to date visuals, the major innovation over the original game is in the persistent surface deformation - but this will surely bring it closer to what AM5 was trying to achieve all those years ago. What it basically means is that when you drive around on surfaces, they deform, pretty much as they would in real life. And they stay deformed, pretty much as they would in real life. In fact, they tested it by setting up six AI cars to drive around a track for 12 hours: they left behind a quarry. So when you drive through wet mud, you'll make thick trenches. Drive across more solid surfaces and you'll leave shallower skid marks. You can even go down to the water table, creating puddles that weren't there before Video Technical Demo Pt. 1 Technical Demo Pt. 2 Endret 14. august 2007 av My2Cents Lenke til kommentar
Mala Skrevet 14. august 2007 Del Skrevet 14. august 2007 Nja veit ikkje heilt ka denne tittelen angår. Det eg har sett av gameplay og bilder ser ikkje så imponerendes ut. Men for all del, eg vil gjerne prøve dette her før eg avskriver det. Lenke til kommentar
My2Cents Skrevet 14. august 2007 Forfatter Del Skrevet 14. august 2007 (endret) Sjekk ut video. La video link i først post Endret 14. august 2007 av My2Cents Lenke til kommentar
glenulv Skrevet 14. august 2007 Del Skrevet 14. august 2007 SEGA Rally Release Date: Oct 9, 2007 Lenke til kommentar
My2Cents Skrevet 14. august 2007 Forfatter Del Skrevet 14. august 2007 SEGA Rally Release Date: Oct 9, 2007 9275824[/snapback] Det var da dumt Lenke til kommentar
praystation Skrevet 14. august 2007 Del Skrevet 14. august 2007 Gleder meg mer til Dirt. Har ikke 360 så har ikke fått testet den ut ennå. Regner med det kommer en demo på PS3 også. Blir spennende å se hvor mye bedre PS3 versjonen blir enn 360 utgaven. I følge codemasters skal den være mye bedre... Sega Rally er vel mer arcade enn simulation, mens Dirt er en kombinasjon. Lenke til kommentar
Mala Skrevet 14. august 2007 Del Skrevet 14. august 2007 Nja veit vel ikkje kor mye meir arcade det kan bli enn DiRT. Men eg vil gjerne ha demo av begge. Lenke til kommentar
Mala Skrevet 14. august 2007 Del Skrevet 14. august 2007 Såg noen av disse tech-videoene. Blei litt meir overbevist no da. Lenke til kommentar
LucarioX Skrevet 14. august 2007 Del Skrevet 14. august 2007 Kommer ikke dette til X360 også da? Lenke til kommentar
_norse_ Skrevet 14. august 2007 Del Skrevet 14. august 2007 Kommer til 360 også ja. Sega Rally har aldri vært spesielt bra etter min mening. Dirt synes jeg var knallbra, siden jeg liker arkade bilspill bedre enn simulatorer. SR er nok også mer arkade aktig, men jeg tviler på om det har samme variasjon i kjøretøy og spillmoduser som Dirt. En ting jeg håper blir bedre er online delen. Uansett ser jeg mer fram imot PGR4 enn noe annet bilspill. Lenke til kommentar
M@R7!N Skrevet 14. august 2007 Del Skrevet 14. august 2007 Off, så farlig arcade ut ihvertfall. Ganske likt DiRT. Savner gode gamle vrally Lenke til kommentar
