Ny info. angående HOME!
Mala
Currently, Home limits the number of users in a single room to 64. This seems to be a performance related issue as the frame rate dips significantly with 60+ players. This will surely be addressed before the product is released.
Based on some beta feedback, developers of Home have made travel between different zones in Home a lot more straightforward. The length of time it took to move from one place to the next became a major weakness in terms of usability. As a result, the different areas have been reduced in size, characters can now run as well as walk, and quick access to any area is available through the PSP interface.
There are people within both the developers of Home and the larger Sony organization who would very much like to see Home completely replace the XMB. They would like users to directly be put into Home when they boot up their console.
The version of Home to be released this fall won’t in any way resemble the final version of Home. Work on the primary features of Home is expected to continue for at least a year. Initial versions released to the public this fall will be quite incomplete.
Kilde
Håper ihvertfall at dette med at HOME skal erstatte XMB totalt er piss og vræl, eller ihvertfall at dette blir valgfritt. Er lite sugen på å valse rundt i HOME bestandig. Liker det elegante XMB veldig godt eg altså, enkelt og greitt, verken meir eller mindre.
Endret av Mala
Ikkje det at eg tviler når 3 stk. sier det samme rett etter hverandre, men kilde er alltid bra like vel :p
Uansett godt om dem beholder XMB for all tid. Home virker litt gimmick aktig ut for de av oss som liker det raskt og enkelt.
