Hvilket hovedkort har jeg?
tmg
Dette er det jeg får av Dxdiag.
Klikk for å se/fjerne innholdet nedenfor
System Information
Time of this report: 7/2/2007, 21:12:00
Machine name: TOR-M
Operating System: Windows XP Home Edition (5.1, Build 2600) Service Pack 2 (2600.xpsp_sp2_gdr.070227-2254)
Language: Norwegian (Bokmål) (Regional Setting: Norwegian (Bokmål))
System Manufacturer: HP Pavilion 061
System Model: PN177AA-ABN t780.no
BIOS: BIOS Date: 11/12/04 10:43:35 Ver: 08.00.10
Processor: Intel® Pentium® 4 CPU 3.60GHz (2 CPUs)
Memory: 2048MB RAM
Page File: 491MB used, 3448MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.2180 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: RADEON X600 Series
Manufacturer: ATI Technologies Inc.
Chip type: RADEON X600 PRO (0x3E50)
DAC type: Internal DAC(400MHz)
Device Key: Enum\PCI\VEN_1002&DEV_3E50&SUBSYS_03281043&REV_00
Display Memory: 256.0 MB
Current Mode: 1280 x 1024 (32 bit) (75Hz)
Monitor: Plug and Play-skjerm
Monitor Max Res: 1600,1200
Driver Name: ati2dvag.dll
Driver Version: 6.14.0010.6458 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 6/25/2004 05:40:00, 207360 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: n/a
VDD: i/t
Mini VDD: ati2mtag.sys
Mini VDD Date: 6/25/2004 05:39:00, 747008 bytes
Device Identifier: {D7B71EE2-7D10-11CF-C96A-2223A1C2CB35}
Vendor ID: 0x1002
Device ID: 0x3E50
SubSys ID: 0x03281043
Revision ID: 0x0000
Revision ID: 0x0000
Video Accel: ModeMPEG2_C ModeMPEG2_D ModeWMV8_B ModeWMV9_A
Deinterlace Caps: {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{552C0DAD-CCBC-420B-83C8-74943CF9F1A6}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
Sound Devices
Description: SB Audigy 2 ZS Audio [E480]
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: PCI\VEN_1102&DEV_0004&SUBSYS_20051102&REV_05
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: ctaud2k.sys
Driver Version: 5.12.0001.0443 (English)
WHQL Logo'd: Yes
Date and Size: 2/6/2004 18:37:04, 366480 bytes
Other Files:
Driver Provider: Creative
HW Accel Level: Full
Cap Flags: 0xF5F
Min/Max Sample Rate: 4000, 192000
Static/Strm HW Mix Bufs: 64, 62
Static/Strm HW 3D Bufs: 64, 62
HW Memory: 0
Voice Management: Yes
EAX 2.0 Listen/Src: Yes, Yes
I3DL2 Listen/Src: No, No
Sensaura ZoomFX: No
Registry: OK
Sound Test Result: Not run
(Hvis dette er feil del av forumet, vennligst flytt posten)
Det er en PC kjøpt på Elkjøp for ca. 2 år siden.
Aner ikke hvilket hovedkort jeg har, men vil ha nytt kabinett og muligens skjermkort og kanskje DDR2 RAM istedenfor DDR som jeg har nå.
Derfor vil jeg vite hvilket hovedkort / sokkel jeg har så jeg kan vite hvilke komponenter som fungerer med det jeg har.
Problemet mitt er at skjermkortet(som ikke har egen vifte på seg) blir utrolig varmt fort og hele pcen drar igang med monster lyd på vifta, som overdøver alt, hvert 10. minutt når den yter en del (som når jeg spiller).
Endret av Tor-Gunnar
