OCZ lanserer SPD omprogramerings verktøy
OCZ Technology denne uka åpnet public beta test av sin SPD-Z verktøy. Det SPD-Z verktøyet lar brukere omprogramere SPD-chipen på OCZ minne-moduler.
http://www.dailytech.com/article.aspx?newsid=8348
Og for de som ikke leste komentarene under, så komenterte en som er ansatt hos Ocz:
You are absolutely correct, the SPD tool is best used to further tweak parts, and is designed for enthusiasts. This may not be a tool for the casual user, but enthusiasts are always looking to get the most out of their products and we wanted to give more options and control to those interested in continually pushing the performance benchmarks. The ability to change or update the SPD based on your unique requirements is simply an added value.
The SPD-Z tool allows customers the ability to both tweak performance, and possibly even improve stability. If improvements are made to the SPD, or a particular platform changes or evolves, now there is an ability on the customer s side to address the change. For those seeking more management over their products the SPD-Z allows them to go ahead and update what was normally not accessible, without fear of voiding their warranty.
__________________
Endret av Fluesopp
