Alt mulig pc, spilling & musikk osv. Tips? 9000,-
Har satt sammen noen deler, men vet ikke om de passer sammen eller om de er dårlige/gammle!?
Asus P5K SE, P35, Socket-775, DDR2, ATX, GbLAN, PCI-Ex16 899,-
Intel Core 2 Duo E6850 3.0GHz 1333Mhz Socket LGA775, 4MB 2295,-
Samsung SpinPoint T166 500GB SATA2 16MB 7200RPM 950,-
Corsair TWIN2X 6400 DDR2, 2048MB
CL5 Kit w/two matched CM2X1024A-6400 Dimm's 749,-
LG DVD-brenner GSA-H54L IDE Black OEM LightScribe 349,-
Gigabyte Poseidon GZ-XA1CA-STB Black Aluminium Front 729,-
Creative SB Audigy SE PCI, 7.1 Surround, 24-bit/96KHz, Retail 330,-
Hiper Strømforsyning ATX 580W Sort, 18dB 120mm Vifte,
4xSATA, 2XPCI-E, 20/24pin 749,-
XFX GeForce 8600GTS 675M 256MB GDDR3,
PCI-Express, 2xDVI/HDCP, 675/2000Mhz 1649,-
Sum: 8.599,-
Noe jeg mangler?
Er dette et bra oppsett for pengene, vil ikke bruke stort mer!(maks 9000,-)
Er det noe som kan byttes mot noen andre deler? til ca. samme pris?
Har tenkt å kjøre Vista på den.(premium 32-bit)
takker for svar!
edit: alt er fra komplett.no btw.
Endret av TheValue
XFX GeForce 8600GT 540M 256MB GDDR3,
PCI-Express, 2xDVI, 540/1400Mhz 1149,-
MSI P35 NEO-F, P35, Socket-775, DDR2,
1333FSB, ATX, GbLAN, PCI-Ex16 795,-
Bytte til disse, smart eller?
Endret av TheValue
Er dette smartere? 7.588,-
Asus P5N-E SLI, nForce-650i SLI, ATX, Socket-775, GbLAN, DDR2, 2xPCI-Ex16
Corsair TWIN2X 6400 DDR2, 2048MB CL5 Kit w/two matched CM2X1024A-6400 Dimm's
LG DVD-brenner GSA-H54N IDE Black OEM
APLUS Case CS-188AF, ATX, Black, 250mm Blue Fan
XFX GeForce 8600GT 540M 256MB GDDR3, PCI-Express, 2xDVI, 540/1400Mhz
Hiper Strømforsyning ATX 580W Sort, 18dB 120mm Vifte, 4xSATA, 2XPCI-E, 20/24pin
CNet Wireless-G PCI 54 Mbps 802.11g, WPA/AES/WPA2, RP-SMA kontakt
Intel Core 2 Quad Q6600 2.4GHz Socket LGA775, 8MB, BOXED m/vifte
Endret av TheValue
