Nokia E65! Diskuter den her!
Hmm, hva gjør jeg feil når jeg får beskjed fra NSU at: Det foreligger ingen programoppdateringer for denne telefon.
Da har du en operatørlåst produktkode.
Denne kan du forandre til en åpen en, for deretter kjøre NSU.
Hvordan gå frem på dette finnes her.
Her kan dere se forbedringer i siste firmware.
E65 (RM-208) 2.0633.65.01 Firmware Changelog
New supported features
* VoIP Release 2.1
* Secure VoIP support
* Emergency call extensions: location information and WLAN support
* WCDMA VoIP improvements: when terminal is in WCDMA coverage with VoIP capability, VoIP readiness indicator is visible
* Intellisync Call Connect for Cisco v1.1 support
* Intellisync Call Connect for Alcatel v2.0 support
* Usability improvements:
* Possibility added for end user to call from Phonebook Internet telephony field (number based address) to CS B party
* Improved handling of #,* and other characters in username part, e.g. if the user wants to use temporary CLIP or CLIR by dialing *31# or 31#
* Long caller address will be shown in two lines
* Support for pause (p) and wait (w) characters added
* Phone is more stable during VoIP call when walking out of WLAN coverage and returning to coverage area
* Start media port default value and default end media value changed.
* SIP Registration improvements in bad WLAN coverage
* The user can use hidden WLAN networks from EasyVoIP without making the access point first somewhere else
* If user selects a hidden WLAN network (from options or from a plug- in which requires an IAP), user is asked for:
1. Network name
2. Select secure mode: "Open network, WEP, WPA/WPA2"
3. "WEP key for WLAN" (if WEP chosen), or "Pre-shared key for WLAN", in case of WPA/WPA2
* Domain address handling improved:
* Domain part of VoIP address is not stored / visible in call logs if terminal parameter for this functionality is active. Removing of domain address part in MT case will be done only, if user part contains only numbers (i.e. E.164) or if URI parameter user=phone exists. Provisioning parameter has been added to define the logic.
* Call back (i.e. recall) from call logs is possible to either VoIP or CS number based address. For MO VoIP calls terminal will add automatically domain address, which is a default domain address
for that specific VoIP profile.
Easy VoIP improvements
* Possibility to connect shared mode networks using Easy VoIP
General VoIP functionality improvements
* Call can be cancelled if the user calls to wrong address
* Call transfer improvements
* DTMF handling improvements
* Call Hold handling improvements
* OMA DM: VoIP codec management improvements
* OMA CP improvements
* Improvements in NAT traversal
* VoIP calls using Contact formatted numbers improved
* IOP improvements
WLAN
* Number of APs is increased on the WLAN scan list
* vBlank page was opened on first time usage of WLAN access point.
* Wlan scan API change from read only to read-writable
* Number of WLAN scan/roam retry attempts increased
* WLAN scan stability improved
* Changes to WLAN channel usage
* Functionality improved in situation when switching APN from 3G to WIFI during streaming
* Usage of WPA with Netgear wireless router improved
* WLAN connection reliability improvement
* WLAN Wizard functionality improvements
Device management
* Added interoperability with Pointsec application
* DM: Workspace buffer size increased for SyncML messages
* Device lock activated after boot
* Device Management performance and stability improvements
* Security improvements
The following new requirements have been included
* OMA DRM v1.0 (Full support)
* Priority change for Intellisync active idle plugin
* Folder shortcut enabler
* Blackberry disconnect icon update
* New Theme variations added
Bluetooth
* Improvement to echo cancellation
* Improved interoperability with BMW Bluetooth carkit
Messaging
* Email connection closing/disconnecting improved
* DRM content handling in Attachments improved
* When all PDP contexts are used in MMS, queries are shown
* SMSC is re-read from SIM after switch on if IMSI has been changed
* Email roaming in offline mode modified
* 4 digit port numbering enabled
* SMS flowing functionality improved
* SMS Time Stamp functionality improved
* Improvements to Instant messaging functionality
Calendar / PIM
* Improvement of recurring meeting updates
* On Domino, non-standard recurrences show up correctly on the device
Office tools
* Enhancement of Message reader to match message sender name in the phonebook
Backup & restore
* Backup/restore functionality of BB client idle plugin updated
Performance
* Standby (idle) functionality improvement
Telephony
* Improved functionality of Team Suite (When the user wants to drop one participant during conference call, UI remains in-call view and not going to Team Suite)
* Alcatel Voice Client ‘Options’ in In-Call menu changed to beginning of In-Call menu.
* Busy tone improvement when call is cancelled or number is busy
* DTMF performance improved
* Supplementary Service Activation denied when FDN Activated
* Corrections to call diverting functionality
* Improvement to Enhanced Line 2 functionality
Web browser
* General WEB Browser stability and interoperability improvements
* Browser memory handling improved
* Saving of downloaded images corrected
Wap browser
* General WAP Browser stability and interoperability improvements
* Page rendering corrections (e.g. in nokia.com business mobile page)
* Color codecs improvements
* A message popup informs user about the failure of packet switched connection failure
* Improvements to handle Java-midled installation from GoTo address field or from SMS
* SL push message handling updated
* Sending of WAP HTTP header information to web servers corrected
Networking
* Improved 3G cell reselection
* Socket stability improvement
* When Exit is pressed from browser data connection is also terminated immediately. Before fix browser was closed, but it took some time until connection was terminated. (RKAN-6VXJBP)
* Improvement in reconnecting to live video stream
* IAP group handling updated
* Live and MPEG4 streaming corrected
* 3G Homezone wildcarding correction
* Mobile VPN Client connection improvements
Diverses
* BMP download supported on DRM
* welcome application
* startup settings: access point database update
* Corrected interoperability problems with Intellisync Mobile Suite, MSN Messenger and Yahoo! Messenger applications
* Corrected stability issue with Download! Client
* Corrected usability issue in security lock / slide interoperability
* A case causing 'contact retailer' to be shown fixed
* Improvement to powerkey functionality in certain situations
* Improved call handling during streaming
* . -key fix in Bopomofo input method
* Audio beeps at certain situations at more convient level
* Czech characters added
* Localizations added
* Lights are turned on when USSD message is received
* Improvement to SMSC number handling with certain SIM cards
* Improvement for phone lock code handling
* Improvement for certificate management
* Menu option "Delete operator settings" made removable
* Interaction between Team Suite and Contacts enhanced
* A unique name given to Watcher plugin thread
* Java installer improvements
* SIM ATK refresh enhancement
* Chinese In Device Search improved
* Printing of documents and pictures improved with Quickoffice
* Key handling functionality with Java corrected
* Operator name list updated
* World clock changes
* Memory handling related improvements
* Improvement to co-operation of the device and F-Secure application
* Localization changes
* Automatic settings configuration updated
  • 2 uker senere...
Noen som har gjort dette via Nokia Software updater enda? Jeg skulle gjøre dette med min forrige N73 en gang i tiden og det resulterte i en død telefon som bare var å kassere da verksted påstod fuktskade. Så derfor er jeg litt skeptisk til å utføre denne oppgraderingen selv igjen :)
Jeg har oppdatert FW, som du ser i min signatur...
Skepsisen din er velbegrunnet forøvrig.
Datakabelen som medfølger E65 er den samme som fulgte med N73 (CA-53), så det er kun en ting å si om denne: Den er helt rævva!
Så FW-oppdatering rådes du til ikke å utføre med denne kabelen...
Jeg bruker derimot en eldre USB-kabel (DKU-2), og denne fungerer helt perfekt.
Endret av DTS
TAkk for info rundt kabel, da var min "usikkerhet" vel berettiget. Vet ikke om jeg skal gidde å oppdatere FW på min E65, har bestillt en N95 8gb, men denne kommer vel ikke før på nyåret. Vet du evt om hvilke telefoner den kabelen du benytter fulgte med, mulig noen bekjente har den liggende å slenge.
Er bortimot sikker på at denne ble levert med Nokia 6680.
Så sjekker du Nokia-telefoner som var nye, da denne var ny (kan også være Series40-telefoner), er jeg ganske sikker på at du treffer blink.
Ellers koster ikke denne kabelen, mer enn en liten hundrings ny heller da...
Denne får du kjøpt hos f.eks. cdon.no (som linket til i min forrige post), eller mytrendyphone.no.
Yup, DKU-5 blir en ikke-kompatibel kabel ja dessverre...
Nokia datakabel, DKU-2. Passer til Nokia 3230, 3250, 3300, 5200, 5300, 5500, 6070, 6085, 6103, 6111, 6125, 6131, 6136, 6151, 6170, 6230, 6230i, 6233, 6234, 6260, 6270, 6280, 6288, 6630, 6650, 6670, 6680, 6681, 7270, 7370, 7373, 7390, 7600, 7610, 7700, 7710, 9300, 9300i, 9500, E50, E60, E61, E65, E70, N70, N71, N72, N73, N80, N90, N92.
Du har nok størst sjanse til å komme over en slik kabel, hvis du kjenner noen som har hatt en eldre Series60-telefon (ny før andre halvår av 2005), da Series40-telefoner på denne tiden somregel ikke ble levert med medfølgende datakabel i esken...
Endret av DTS
Har nettopp oppgradert firmware. Jeg har fått følgende problemer:
-Når jeg restarter telefonen prøver den å innstallere et program jeg hadde/har på minnekortet. Dette får den ikke til. Hvordan sletter jeg install-fila fra minnekortet? Jeg finner den ikke i utforsker, men den ligger på tlf under programbehandling som "ikke innstallert". Hvordan får jeg den ut av den lista?
-Jeg kommer ikke på mitt eget WLAN lenger, samme som jeg er på med PC nå. Jeg kan ikke innbille meg at MAC-adressen(dette er sikkerheten jeg bruker) har blitt forandret i telefonen? Hva kan problemet være?
Edit: slo av sikkerhet, og det hjalp ikke. Jeg skanner wlan, den finner det og jeg trykker "start websøk" det kommer "kobler til med *nettnavn*", så får jeg feilmelding "wlan ikke funnet".
Ang. programmet installert på minnekort, kan du prøve å reinstallere.
Hjelper ikke dette kobler du til telefonen i dataoverføringsmodus, åpner windows utforsker/min datamaskin, for deretter gå på minnekortet (som nå skal være dukket opp som en flyttbar disk G:/).
Så sjekker du mappen Private, etter programnavnet som står som ikke installert. Og sletter selvfølgelig dette når funnet...
Hva WLAN angår, så har jeg aldri hatt trøbbel, så dette begir jeg meg ikke ut på å svare på...
Endret av DTS
Takker for hjelp, men jeg ser ingen mappe som heter private? Ikke om jeg browser på tlf eller via pcsuite hvertfall.
En ting til dukket opp, i pc suite application innstaller kan jeg ikke se hva som er på tlf, det står "innholdet på gjeldende valgt telefonmodell kan ikke vises av dette programmet"..
Via Dataoverføringsmodus. Ikke PCSuite og PCSuitemodus...
Trekk ut USB-kabelen fra telefonen, plugg i, for deretter velge Dataoverføring på telefonen.
Får du ikke dette valget, går du på Datakabel i menyen på telefonen, og velger "Bekreft ved tilkobling" og deretter plugger kabelen i igjen.
Så skal du finne Private...
Dette lar seg dessverre ikke gjøre...
Ikke har Nokia gjort noe med dette i den siste FW heller.
Dette er en "bug" som følger nesten alle S60 3rd edition-telefonene tror jeg.
Ihvertfall er både min E65 og N73ME slik.
Eneste rådet jeg kan gi, blir da å utelate etternavn fra kontaktnavnet der det går...
Enten det, eller bytt om fornavn/etternavn i kontaktlisten, for deretter velge visning som etternavn/fornavn i denne...
Sistnevnte har jeg ikke testet selv, men går ut ifra at det fungerer.
Endret av DTS
  • 5 uker senere...
Jeg har hatt en E65 i noen uker nå og er i utgangspunktet fornøyd.
Problemet er at den veldig ofte slår seg av når jeg åpner den eller lukker den igjen (slideren). Det kans kje flere ganger i løpet av en dag, og er naturligvis irriterende.
Er dette et kjent problem på denne?
Kjøpte den på ELKJØP, og har ikke lyst til å være uten tlf i flere uker hvis den må inn på verksted. Trodde kanskje det bare var å flashe den (den har gammelt FW), og kunne kanskje tenkt å gjøre det selv med NSS, men hvis andre har erfaring med at dette er et problem som ikke lar seg løse med ny firmware så si ifra.
