frostbitten Skrevet 27. juli 2007 Del Skrevet 27. juli 2007 Klikk for å se/fjerne innholdet nedenfor Questions were answered by Daves [NT-DEVELOPER] Sound Engineer over at NinjaTheory Forums.http://www.ninjatheory.com/forums/sh...t=1381&page=28 Question 1 There were a few problems with it that I would like to point out. - First when you do super styles that abrupt music change is very odd. The volume increases and it just seems a little out of place. The music cut out every so often and there was even one part right at the beginning of the demo that the music was actually crackling.. it was strange. Some bodies float as well. But I had so much fun with the demo and I played through it about 12 times so far. Answer 1 The volume increase was because they were 'super styles', however, I did nock them back a bit and do some balancing just a day or so ago. The audio (music cutting out) glitches during the Ninja Sequence are also fixed. FYI the demo was locked down ages ago, plenty of spit n polish has been done since then right. Question 2 HELLO?? is blocking is automatic? Answer 2 It's not completely automatic, in that you need to be in the right stance to block the incoming move (or evade for unblockables). For a NinjaChallenge - try completing the demo ONLY using counter-attacks Question 3 Please tell me the hard mode is available without having to play through once to unlock it? Answer 3 HELL mode is available right off the bat, yes. Bare in mind, that what you're playing now is a level early on in the story, you can scrape through it just by mashing buttons - try that in the later chapters and you'll get your (gorgeous) ass handed to you on a plate... Question 4 Please tell me the hard mode is available without having to play through once to unlock it? Answer 4 I heard today that we had to prove to Sony that the game could be completed in Hell Mode... a couple of ninja's managed it I believe. Seems the testers didn't! Hehe. Question 5 also, does anyone else notice the brightness of the game fading in and out? I keep thinking its my TV, but i'm curious... Answer 5 Naa, that'll be the sun going behind the clouds. Noticable points - the demo is an old build probably from last years demo since its exactally the same level - the game has improved significantly from the demos build - many glitches are fixed - sound issuses have also been fixed Kilde. Nå ble jeg enda litt mer hypa på dette spillet. Lenke til kommentar
Mala Skrevet 27. juli 2007 Del Skrevet 27. juli 2007 Hehe eg lo litt av alle disse likene som låg og flaut omkring i lufta, såg litt merkelig ut Lenke til kommentar
SirKenneth89 Skrevet 27. juli 2007 Del Skrevet 27. juli 2007 Har litt trua på dette spillet, men demoen var ikke fantastisk bra. Full-versjonen må ha variasjon og lengde... Lenke til kommentar
frostbitten Skrevet 27. juli 2007 Forfatter Del Skrevet 27. juli 2007 Disse flytende likene har jeg ikke sett noe til ennå. Videre gameplay fra demoen i dårlig kvalitet. Jeg valgte å ikke se den. Lenke til kommentar
Mala Skrevet 27. juli 2007 Del Skrevet 27. juli 2007 Spill igjennom noen ganger og du er døm til å se eit par. Begge gangene eg spillte igjennom på rad i starten hadde minst 2 flygende lik pr. platform. Men flott å se ting bli fikset, da dette var ein rimelig gammel build. Lenke til kommentar
frostbitten Skrevet 27. juli 2007 Forfatter Del Skrevet 27. juli 2007 Har da spilt gjennom minst 12 ganger no. Kanskje synet som er dårlig? Lenke til kommentar
Mala Skrevet 27. juli 2007 Del Skrevet 27. juli 2007 Tror heller det er snakk om tilfeldigheter. Eg har ihvertfall lagt merke til at disse artigheten ostår på lik som lander nær kanter etc. Lenke til kommentar
Imsdalo Skrevet 28. juli 2007 Del Skrevet 28. juli 2007 Trur nok release versjonen kommer til å være mye bedre enn det vi har spelt. Lenke til kommentar
Triiiip Skrevet 28. juli 2007 Del Skrevet 28. juli 2007 Og den kommer 12.september Ikke lenge til heller! Lenke til kommentar
Imsdalo Skrevet 28. juli 2007 Del Skrevet 28. juli 2007 hehe september .. ei stønn til ennå Lenke til kommentar
KongRudi Skrevet 28. juli 2007 Del Skrevet 28. juli 2007 (endret) http://www.gamevideos.com/video/id/13496 1up-show... 27/7-07 Nesten ett rent PS3 1up-show. Vi får vite endel om historien i Heavenly Sword, også se noen av kongens generaler, og må si jeg likte hvordan de beskrev Kai (Nariko's søster), i tillegg var det kjekt å vite at man blir opplært på komboer o.l. i første level. Også aftertouch'en virker stilig.. I tillegg til masse ny Heavenly Sword-info digg, får vi Ratchet & Clank impressions (av den viste demoen), og i tillegg Metal Gear Solid 4 impressions av gameplayet som ble vist på Playstation Premiere, og masse nyheter om Metal Gear Solid Online som er ett stand-alone product, virker det som, og det var faktisk kanonkuule ideer i det, som hackingen o.l. Endret 28. juli 2007 av KongRudi Lenke til kommentar
dekar24k Skrevet 28. juli 2007 Del Skrevet 28. juli 2007 Jeg håper spillet vil få høyere FPS enn hva demoen har.. Ikke akkurat smooth gameplay som i Ninja Gaiden Sigma f.eks. Lenke til kommentar
Imsdalo Skrevet 28. juli 2007 Del Skrevet 28. juli 2007 Jeg håper spillet vil få høyere FPS enn hva demoen har.. Ikke akkurat smooth gameplay som i Ninja Gaiden Sigma f.eks. 9159304[/snapback] Vil nok det .. Dette var en gammel build med endel fixes, så antagelig kommer release versjonen ikke bare til og se bedre ut.. men og være mye glattere Lenke til kommentar
