joZa Skrevet 27. juli 2007 Del Skrevet 27. juli 2007 Jeg prøver å sette opp en openvpn server på fedora 7-boksen min for å kunne få tilgang til nettverket hjemme når jeg reiser og studerer, men jeg får ikke oppsettet mitt til å fungere. Server-config: ifconfig 192.168.1.201 255.255.255.0 port 1194 proto udp mode server tls-server dev tap ifconfig-pool 192.168.1.220 192.168.1.230 tun-mtu 1492 mssfix ca certs/vpn_ca.pem cert certs/server_cert.pem key certs/server_key.pem dh certs/dh1024.pem ifconfig-pool-persist ipp.txt keepalive 10 120 auth SHA1 cipher aes-256-cbc comp-lzo user nobody group nogroup persist-key persist-tun verb 0 Klient-config (windows vista): client dev tap proto udp remote 192.168.1.201 1194 resolv-retry infinite nobind persist-key persist-tun ca vpn_ca.crt cert user01_lan_cert.crt key user01_lan_key.key comp-lzo verb 3 cipher AES-256-CBC auth SHA1 Jeg får denne meldingen i openvpn på vista-klienten når jeg prøver å koble til: Thu Jul 12 16:08:25 2007 OpenVPN 2.1_beta7 Win32-MinGW [SSL] [LZO2] built on Nov 12 2005 Thu Jul 12 16:08:25 2007 WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info. Thu Jul 12 16:08:25 2007 LZO compression initialized Thu Jul 12 16:08:25 2007 Control Channel MTU parms [ L:1590 D:138 EF:38 EB:0 ET:0 EL:0 ] Thu Jul 12 16:08:25 2007 Data Channel MTU parms [ L:1590 D:1450 EF:58 EB:135 ET:32 EL:0 AF:3/1 ] Thu Jul 12 16:08:25 2007 Local Options hash (VER=V4): 'c6c7c21a' Thu Jul 12 16:08:25 2007 Expected Remote Options hash (VER=V4): '1a6d5c5d' Thu Jul 12 16:08:25 2007 Socket Buffers: R=[8192->8192] S=[8192->8192] Thu Jul 12 16:08:25 2007 UDPv4 link local: [undef] Thu Jul 12 16:08:25 2007 UDPv4 link remote: 192.168.1.201:1194 Thu Jul 12 16:09:25 2007 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity) Thu Jul 12 16:09:25 2007 TLS Error: TLS handshake failed Thu Jul 12 16:09:25 2007 TCP/UDP: Closing socket Thu Jul 12 16:09:25 2007 SIGUSR1[soft,tls-error] received, process restarting Thu Jul 12 16:09:25 2007 Restart pause, 2 second(s) Jeg regner med at det er noe feil med en (eller begge) konfigurasjonsfilene mine, men jeg finner ikke ut hva det er. Noen som kan hjelpe meg her? Lenke til kommentar
joZa Skrevet 28. juli 2007 Forfatter Del Skrevet 28. juli 2007 Noen som har peiling? Lenke til kommentar
