Problem med skjermbilde i Debian
Gjest Slettet+9871234
post din /etc/X11/xorg.conf
skriv detta i konsole:
kate /etc/X11/xorg.conf
om du ikkje får lest den så sett sudo først. :)
edit: terminal i KDE heite konsole :whistle:
Endret av Slettet+9871234
9148006[/snapback]
Hei igjen, Her er infoen som kom opp da, er SS30G2 barebone heta, skreiv feil ista. Så er vel SIS istede for Intel skjermkort.
# /etc/X11/xorg.conf (xorg X Window System server configuration file)
# This file was generated by dexconf, the Debian X Configuration tool, using
# values from the debconf database.
# Edit this file with caution, and see the /etc/X11/xorg.conf manual page.
# (Type "man /etc/X11/xorg.conf" at the shell prompt.)
# This file is automatically updated on xserver-xorg package upgrades *only*
# if it has not been modified since the last upgrade of the xserver-xorg
# package.
# If you have edited this file but would like it to be automatically updated
# again, run the following command:
# sudo dpkg-reconfigure -phigh xserver-xorg
Section "Files"
FontPath "/usr/share/fonts/X11/misc"
FontPath "/usr/X11R6/lib/X11/fonts/misc"
FontPath "/usr/share/fonts/X11/cyrillic"
FontPath "/usr/X11R6/lib/X11/fonts/cyrillic"
FontPath "/usr/share/fonts/X11/100dpi/:unscaled"
FontPath "/usr/X11R6/lib/X11/fonts/100dpi/:unscaled"
FontPath "/usr/share/fonts/X11/75dpi/:unscaled"
FontPath "/usr/X11R6/lib/X11/fonts/75dpi/:unscaled"
FontPath "/usr/share/fonts/X11/Type1"
FontPath "/usr/X11R6/lib/X11/fonts/Type1"
FontPath "/usr/share/fonts/X11/100dpi"
FontPath "/usr/X11R6/lib/X11/fonts/100dpi"
FontPath "/usr/share/fonts/X11/75dpi"
FontPath "/usr/X11R6/lib/X11/fonts/75dpi"
# path to defoma fonts
FontPath "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType"
EndSection
Section "Module"
Load "i2c"
Load "bitmap"
Load "ddc"
Load "dri"
Load "extmod"
Load "freetype"
Load "glx"
Load "int10"
Load "vbe"
EndSection
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "kbd"
Option "CoreKeyboard"
Option "XkbRules" "xorg"
Option "XkbModel" "pc105"
Option "XkbLayout" "no"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
Option "CorePointer"
Option "Device" "/dev/input/mice"
Option "Protocol" "ImPS/2"
Option "Emulate3Buttons" "true"
EndSection
Section "Device"
Identifier "Silicon Integrated Systems [siS] 661/741/760 PCI/AGP or 662/761Gx PCIE VGA Display Adapter"
Driver "sis"
BusID "PCI:1:0:0"
EndSection
Section "Monitor"
Identifier "BenQ FP71G+"
Option "DPMS"
EndSection
Section "Screen"
Identifier "Default Screen"
Device "Silicon Integrated Systems [siS] 661/741/760 PCI/AGP or 662/761Gx PCIE VGA Display Adapter"
Monitor "BenQ FP71G+"
DefaultDepth 24
SubSection "Display"
Depth 1
Modes "1280x1024" "1152x864" "1024x768" "832x624" "800x600" "720x400" "640x480" "640x350"
EndSubSection
Depth 4
EndSubSection
Depth 8
EndSubSection
Depth 15
EndSubSection
Depth 16
EndSubSection
Depth 24
EndSubSection
EndSection
Section "ServerLayout"
Identifier "Default Layout"
Screen "Default Screen"
InputDevice "Generic Keyboard"
InputDevice "Configured Mouse"
EndSection
Section "DRI"
Mode 0666
EndSection
Endret av siripiri
Prøv å installere en pakke som heter 915resolution. Og deretter trykk Ctrl - alt - bckspace for å restarte x-server.
Er litt usikker på om du må reboote eller ikke  :hmm:
9149354[/snapback]
Hei
Er helt grønn på linux generelt. Hvor finner jeg denne pakken?
I pakkebehandleren.
I menyen : System > administrasjon > synaptic programpakkebehandler.
Der kan du søke etter 915resolution. Men først må du kanskje oppdatere pakkelageret med å trykke les inn på nytt.
Alternativt kan du åpne en terminal og først skrive for å bli rot bruker :
su
Og skrive rot passordet du valgte under innstallasjon.
Så kan du skrive :
apt-get update
og deretter :
apt-get install 915resolution
915resolution er vel et (bom)skudd i blinde når det er snakk om en SiS-chip?
9149926[/snapback]
Hei, jeg vet ikke, får prøve det i morgen. Vet ikke ellers hva det kan være som gjør slik at skjermen oppfører seg slik
