Jeg er på jakt etter et script som kan pinge en adresse og logge dette in en tekstfil. Søkte litt og fant to script som jeg limt litt sammen.
Det jeg plages med er at resultatet lagres i en tabel, men når dette skal skrives til tekstfilen er det kun de to første linjene som blir logget.
Dim strHost, strOutputPath, strOutputFileName, strPingOutput, arrPingOutput, intLatency, WSHShell, Message, Title
Message = "Skriv inn adresse til siden, f.eks www.vg.no"
Title = "Ping tester"
Text1 = "Sorry, user input was canceled"
Text2 = "I got the input:" + vbCRLF
Set WSHShell = WScript.CreateObject("WScript.Shell")
result = InputBox(Message,Title,"www.vg.no", 100, 100)
strHost= result
strOutputPath="c:\temp"
strOutputFileName="outputfilename.txt"
strPingOutput = PingHost(strHost)
arrPingOutput = StringToArray(strPingOutput)
intLatency =  GetLatency(arrPingOutput(3))
Call WriteMRTGFile(intLatency,intLatency,strHost,"Unknown", strOutputPath, strOutputFileName)
Function PingHost(input)
''starts a dos box and pings the host, returning the full output of the ping command
Dim strCommand, objShell, objExec
strCommand = "%comspec% /c ping -n 10 " & input
Set objShell = CreateObject("WScript.Shell")
Set objExec = objShell.Exec(strCommand)
PingHost = objExec.StdOut.ReadAll
End Function
Function StringToArray(input)
''converts the multiline ping output to an array so that it can be parsed line by line
StringToArray = Split(input,vbCrLf)
End Function
Function GetLatency(input)
''cuts the preceeding & succeeding text, leaving just the latency (integer) remaining
Dim strLatencyTrimedLeft
  strLatencyTrimedLeft = mid(input,(InStr(input,"time")+1))
GetLatency = mid(strLatencyTrimedLeft,1,(InStr(strLatencyTrimedLeft,"ms")-1))
End Function
Sub WriteMRTGFile(var1,var2,HostName,SysUpTime,path,file)
''write results to file in MRTG format
Dim oFSO, oFile
Set oFSO = CreateObject("Scripting.FileSystemObject")
Set oFile = oFSO.CreateTextFile(oFSO.BuildPath(path,file))
oFile.Write var1 & vbCrLf
oFile.Write var2 & vbCrLf
oFile.Write HostName & vbCrLf
oFile.Write SysUpTime & vbCrLf
oFile.Close : Set oFile = Nothing
Set oFSO = Nothing
Set oFile = Nothing
End Sub
Skal bruke dette ute hos en kunde som har under gjennomsnittlig kunnskap på alt annet enn fag applikasjoner. Derfor skal han starter scriptet, det skal komme opp en rute hvor han skriver inn en adresse, scriptet pinger adresse og skriver dette til en log.
Fant uansett ut av det :)
Endret av phoen|x
Skal du lagre hele pingresultatet eller bare deler av det? Iallfall, her har du et eksempel på at du får lagret og sett hele resultatet av ping www.vg.no.
result = pinghost("www.vg.no")
save(result)
show
End Function
sub save(input)
Set fso = CreateObject("Scripting.FileSystemObject")
Set f = fso.OpenTextFile("c:\pingResult.txt", 2, True)
f.Write input
f.close
end sub
sub show
Set WshShell = WScript.CreateObject("WScript.Shell")
WshShell.Run ("notepad.exe c:\pingResult.txt")
end sub
