Drivere til Geforce Go 7600
Gjest Slettet-CkrM7QVpfE
Hvor kan jeg oppdatere drivere til dette skjermkortet? De finnes ikke på nvidias sider. Det er et skjermkort i en HP bærbar.
9097539[/snapback]
Her tror jeg
9097943[/snapback]
Klikk for å se/fjerne innholdet nedenfor
GeForce2 MX , GeForce2 MX 100 , GeForce2 MX 200 , GeForce2 MX 400 , GeForce3 , GeForce3 Ti 200 , GeForce3 Ti 500 , GeForce4 MX 420 , GeForce4 MX 440 , GeForce4 MX 440-SE , GeForce4 MX 440 with AGP8X , GeForce4 MX440SE with AGP8X , GeForce4 MX 460 , GeForce2 MX Integrated graphics , GeForce4 MX Integrated graphics , GeForce4 MX 4000 , GeForce4 Ti 4200 , GeForce4 TI 4200 with AGP8X , GeForce4 Ti 4400 , GeForce4 Ti 4600 , GeForce4 Ti 4800 , GeForce4 Ti 4800 SE , GeForce FX 5100 , GeForce FX 5200 , GeForce FX 5200LE , GeForce FX 5200 Ultra , GeForce FX 5500 , GeForce FX 5600 , GeForce FX 5600 Ultra , GeForce FX 5600SE , GeForce FX 5600XT , GeForce FX 5700 , GeForce FX 5700VE , GeForce FX 5700 Ultra , GeForce FX 5700LE , GeForce FX 5800 , GeForce FX 5800 Ultra , GeForce FX 5900 , GeForce FX 5900 Ultra , GeForce FX 5900XT , GeForce FX 5900ZT , GeForce FX 5950 Ultra , GeForce PCX 5300 , GeForce PCX 5750 , GeForce PCX 5900 , GeForce 6100 nForce 400 , GeForce 6100 nForce 405 , GeForce 6100 nForce 420 , GeForce 6100 , GeForce 6150 LE , GeForce 6150 , GeForce 6200 , GeForce 6200 LE , GeForce 6200 with TurboCache , GeForce 6200SE with TurboCache , GeForce 6500 , GeForce 6600 , GeForce 6600 LE , GeForce 6600 VE , GeForce 6600 GT , GeForce 6610 XL , GeForce 6700 XL , GeForce 6800 , GeForce 6800 LE , GeForce 6800 XE , GeForce 6800 XT , GeForce 6800 GS , GeForce 6800 GT , GeForce 6800 Ultra , GeForce 6800 Ultra , GeForce 7100 GS , GeForce 7200 GS , GeForce 7300 LE , GeForce 7300 SE , GeForce 7300 GS , GeForce 7300 GT , GeForce 7500 LE , GeForce 7600 GS , GeForce 7600 GT , GeForce 7800 GS , GeForce 7800 GT , GeForce 7800 GTX , GeForce 7800 GTX 512 , GeForce 7900 GS , GeForce 7900 GTO , GeForce 7900 GT , GeForce 7900 GTX , GeForce 7950 GX2 , Quadro2 MXR , Quadro DCC , Quadro4 200 NVS , Quadro4 400 NVS , Quadro4 380 XGL , Quadro4 500 XGL , Quadro4 550 XGL , Quadro4 580 XGL , Quadro4 700 XGL , Quadro4 750 XGL , Quadro4 780 XGL , Quadro4 900 XGL , Quadro4 980 XGL , Quadro FX 330 , Quadro FX 350 , Quadro FX 500 , Quadro FX 540 , Quadro FX 550 , Quadro FX 560 , Quadro FX 600 , Quadro FX 700 , Quadro FX 1000 , Quadro FX 1100 , Quadro FX 1300 , Quadro FX 1400 , Quadro FX 1500 , Quadro FX 2000 , Quadro FX 3000 , Quadro FX 3000G , Quadro FX 3400 , Quadro FX 3450 , Quadro FX 3500 , Quadro FX 4000 SDI , Quadro FX 4400 , Quadro FX 4400G , Quadro FX 4500 , Quadro FX 4500 SDI , Quadro FX 4500 X2 , Quadro FX 5500 , Quadro FX 5500 SDI , Quadro NVS , Quadro NVS with AGP8X , Quadro NVS 200 , Quadro NVS 210s , Quadro NVS 280 , Quadro NVS 280 SD , Quadro NVS 400 , Quadro NVS 440 , Quadro NVS 280 PCI , Quadro NVS 285
nView User Guide
New Control Panel User Guide
Classic Control Panel User Guide
nei GO 7600 står ikke lista der.
9097539[/snapback]
Her tror jeg
9097943[/snapback]
nView User Guide
9098548[/snapback]
hmm, mener jeg brukte de driverne til mitt go7600. Har du prøvd de driverne?
Som syar2003 nevner tidligere i denne tråden publiserer ikke Nvidia egne drivere for integrert grafikk i bærbare maskiner, det er det originalutstyrsprodusenten som må ta seg av. Dette betyr i ditt tilfelle at drivere for din aktuelle maskin er å finne på supportsidene til HP. Ulempen med dette er at driverene skjeden eller aldri blir oppdatert, noe som gjør at du ofte blir sittende med utdaterte drivere. Løsningen på dette problemet finner du på laptopvideo2go, som er en side som hoster drivere og modifiserte inf-filer til skjermkort fra Nvidia. Kort fortalt går denne metoden ut på å modifisere en såkalt .inf fil slik at du kan installere aktuelle ForceWare-drivere på en laptop med GeForce Go grafikk. For en kjapp innføring i hvordan du skal gå frem for å benytte deg av den overnevnte metoden kan du lese noen av guidene på det aktuelle forumet. Hva du velger må du bestemme selv, men dersom driverene fra HP fungerer fint ville jeg holdt meg til disse i første omgang. :)
