3dagers lotro cdkeys
fikk noen jeg å..
If none of your real-life friends are playing LOTRO right now,here’s five, three-day trial keys for you to forward on to them!
IMPORTANT: The following keys will not be eligible for activation after September 13th 2007, so make sure you activate them before this date!
Key 1: MNQMC-NXM0W-X41FH-2NYYG-4GHG6
Key 2: 2AQJ1-6Y943-8GG69-FGCU8-1HJ1C
Key 3: NXU5X-6XL1M-B4CNQ-0N0JB-9G13F
Key 4: X09YH-MHCKM-AVJBC-WQ86E-664GG
Key 5: MCPL5-VY38P-GGFM7-TLD1A-6QF6G
TIP: Make sure you forward them the instructions as well!
PS! vist du bruker noen keys, legg igjen hvilken du brukte så andre slipper og få feilmelding
Endret av alleibruk
fikk noen jeg å..
9101590[/snapback]
Jeg prøvde alle kodene, men det står at de er invalide..
Noen som har noen som funker? PM hvis du har ;)
