Problemer med Quake 3 - OpenGL
PC'en er en helt annen enn den jeg spilte med sist.. :p
Here goes nothing:
Q3 1.11 win-x86 Nov 24 1999
----- FS_Startup -----
Current search path:
D:\Quake 3\baseq3\pak0.pk3 (3539 files)
D:\Quake 3/baseq3
execing default.cfg
execing q3config.cfg
couldn't exec autoexec.cfg
...detecting CPU, found AMD w/ 3DNow!
------- Input Initialization -------
Initializing DirectInput...
Couldn't set DI coop level
Falling back to Win32 mouse support...
Joystick is not active.
----- Client Initialization -----
----- Initializing Renderer ----
----- Client Initialization Complete -----
--- Common Initialization Complete ---
Winsock Initialized
Opening IP socket: localhost:27960
Hostname: rb26det
IP: 10.0.0.1
Working directory: D:\Quake 3
----- R_Init -----
Initializing OpenGL subsystem
...initializing QGL
...calling LoadLibrary( 'C:\WINDOWS\system32\opengl32.dll' ): succeeded
...setting mode 9: 1600 1200 FS
...using colorsbits of 32
...calling CDS: failed, bad mode
...trying next higher resolution: failed, bad mode
...restoring display settings
...registered window class
...created window@3,22 (1606x1225)
Initializing OpenGL driver
...getting DC: succeeded
...GLW_ChoosePFD( 32, 24, 0 )
...101 PFDs found
...hardware acceleration found
...PIXELFORMAT 7 selected
...creating GL context: succeeded
...making context current: succeeded
...WARNING: fullscreen unavailable in this mode
...using colorsbits of 16
...window already present, CreateWindowEx skipped
...shutting down QGL
...unloading OpenGL DLL
...assuming '3dfxvgl' is a standalone driver
...initializing QGL
...WARNING: missing Glide installation, assuming no 3Dfx available
----- CL_Shutdown -----
RE_Shutdown( 1 )
GLW_StartOpenGL() - could not load OpenGL subsystem
Endret av Keltern
Kan du si åssen grafikk kort du har? prøv og instalere nyeste skjermdriver. For om du bare bruker Driveren som følger med Windows så har du ikke OpenGL instalert..
Men om du instalerer Skjermkort driver fra produsent får du nok med OpenGL i driverene om du ikke har et veldig veldig gammalt kort
BTW
Trur problemet ditt er at på den pcen det ble spilt sist så har noen brukt oppløsning 1600x1200 og det støtter kanskje ikke skjermen din?
Løsning på det er og gå i Quake3 mappa og BASEQ3 mappa og slette filen Q3CONFIG.CFG
Så skal spille starte med default settings.
Endret av Handl3vogn
BTW
9071107[/snapback]
Jeg har et XFX 6800GS, med siste driverpakken fra nvidia.. :)
Men det du nevner om spill brukt på høyere oppløsning enn det skjermen min takler, så kan det faktisk være problemet! Uten at jeg har tenkt over det før nå.. :)
Jeg skal prøve å slette configen, så får vi se om det fungerer! :)
Har ingenting med piratkopiering å gjøre uansett. OpenGL er en grafikkmotor-standard som er utgått for mange år siden. Du må laste ned og legge inn drivere som emulererer OpenGL for å få det til å funke på nye grafikkort.
Men det er jo litt rart, siden Quake3-baserte spill som Wolfenstein: Enemy territory, eller SW Jedi Knight III funker finfint på XP.
Kanskje disse har noe OpenGL-wrap innebygd.
Endret av Bitex
Ehmm.. Ser ut til at et av mine innlegg ble sletta her, etter at jeg meldte fra om at jeg fikk spillet til å fungere!
Og hvem bryr seg om jeg laster ned spillet, når jeg er eier av spillet!? Jeg har antageligvis kasta cd'en ved en feiltagelse, da noen hundre cd'er gikk i søpla i vinter.. :ermm:
Det er jo i praksis ikke piratkopiering, bortsett fra at jeg ikke bruker egen key. Eneste som er kjipt er at jeg ikke får spilt online. Får vel se å få kjøpt igjen noen av de gamle spillene jeg har mista cd'ene til... :)
