Hvordan forandre videofil?
Hei!
Jeg fant ikke et passende forum for dette spørsmålet, så tenkte jeg kunne spørre her!
Hvordan forandrer man en videofil? Skulle gjerne endret en "OGM-fil" til noe mere passende (Feks: avi eller wma)
Då må du endre på innstillingane for codecen du bruker, eventuelt bruke ein annan codec. Som det står på den sida:
The size of the AVI file depend a lot on the chosen video compressor. Microsoft ships some standard codecs with Windows, including MJPEG, Microsoft Video 1 and Cinepak. Those are old codecs and are not very efficient. It is not uncommon that your AVI files will be 10x to 50x bigger than your original files if you are converting from DIVX, MOV, MPEG, WMV or anything encoded with a MPEG based codec.
