Trådløst nettverk kobler ut
Hei!
Har en D-Link DIR-635 trådløs ruter som jeg nettopp har koblet opp.
Den kobler ut og inn fra nettet hvert 5 sek... og mister stadig signalet til tross for at jeg får Excellent som signalkvalitet.
Her er utdrag fra logen på ruteren:
[iNFO] Sun Feb 01 09:03:40 2004 Log viewed by IP address 192.168.0.100
[iNFO] Sun Feb 01 09:03:31 2004 Latest firmware version retrieved from the server was 1.9
[iNFO] Sun Feb 01 09:03:30 2004 Allowed configuration authentication by IP address 192.168.0.100
[iNFO] Sun Feb 01 09:03:15 2004 Wireless system with MAC address 0019D202DAB1 associated
[iNFO] Sun Feb 01 09:03:10 2004 Wireless system with MAC address 0019D202DAB1 disconnected for reason: Received Deauthentication.
[iNFO] Sun Feb 01 09:03:03 2004 Wireless system with MAC address 0019D202DAB1 associated
[iNFO] Sun Feb 01 09:02:58 2004 Wireless system with MAC address 0019D202DAB1 disconnected for reason: Received Deauthentication.
[iNFO] Sun Feb 01 09:02:55 2004 Wireless system with MAC address 0019D202DAB1 associated
[iNFO] Sun Feb 01 09:02:50 2004 Wireless system with MAC address 0019D202DAB1 disconnected for reason: Received Deauthentication.
[iNFO] Sun Feb 01 09:02:48 2004 Wireless system with MAC address 0019D202DAB1 associated
[iNFO] Sun Feb 01 09:02:48 2004 Wireless system with MAC address 0019D202DAB1 disconnected for reason: Received Deauthentication.
[iNFO] Sun Feb 01 09:02:43 2004 Wireless system with MAC address 0019D202DAB1 associated
[iNFO] Sun Feb 01 09:02:41 2004 Wireless system with MAC address 0019D202DAB1 disconnected for reason: Received Deauthentication.
[iNFO] Sun Feb 01 09:02:36 2004 Wireless system with MAC address 0019D202DAB1 associated
[iNFO] Sun Feb 01 09:02:36 2004 Wireless system with MAC address 0019D202DAB1 disconnected for reason: Received Deauthentication.
[iNFO] Sun Feb 01 09:02:35 2004 Wireless system with MAC address 0019D202DAB1 associated
[iNFO] Sun Feb 01 09:02:34 2004 Wireless system with MAC address 0019D202DAB1 disconnected for reason: Received Deauthentication.
[iNFO] Sun Feb 01 09:02:28 2004 Wireless system with MAC address 0019D202DAB1 associated
[iNFO] Sun Feb 01 09:02:28 2004 Wireless system with MAC address 0019D202DAB1 disconnected for reason: Received Deauthentication.
[iNFO] Sun Feb 01 09:02:27 2004 Wireless system with MAC address 0019D202DAB1 associated
[iNFO] Sun Feb 01 09:02:27 2004 Wireless system with MAC address 0019D202DAB1 disconnected for reason: Received Deauthentication.
[iNFO] Sun Feb 01 09:02:26 2004 Wireless system with MAC address 0019D202DAB1 associated
[iNFO] Sun Feb 01 09:02:25 2004 Wireless system with MAC address 0019D202DAB1 disconnected for reason: Received Deauthentication.
[iNFO] Sun Feb 01 09:02:23 2004 Wireless system with MAC address 0019D202DAB1 associated
[iNFO] Sun Feb 01 09:02:23 2004 Wireless system with MAC address 0019D202DAB1 disconnected for reason: Received Deauthentication.
[iNFO] Sun Feb 01 09:02:22 2004 Wireless system with MAC address 0019D202DAB1 associated
[iNFO] Sun Feb 01 09:02:21 2004 Wireless system with MAC address 0019D202DAB1 disconnected for reason: Received Deauthentication.
[iNFO] Sun Feb 01 09:02:19 2004 Wireless system with MAC address 0019D202DAB1 associated
[iNFO] Sun Feb 01 09:02:19 2004 Wireless system with MAC address 0019D202DAB1 disconnected for reason: Received Deauthentication.
[iNFO] Sun Feb 01 09:02:18 2004 Wireless system with MAC address 0019D202DAB1 associated
[iNFO] Sun Feb 01 09:02:18 2004 Wireless system with MAC address 0019D202DAB1 disconnected for reason: Received Deauthentication.
[iNFO] Sun Feb 01 09:02:17 2004 Wireless system with MAC address 0019D202DAB1 associated
[iNFO] Sun Feb 01 09:02:16 2004 Wireless system with MAC address 0019D202DAB1 disconnected for reason: Received Deauthentication.
[iNFO] Sun Feb 01 09:02:12 2004 Wireless system with MAC address 0019D202DAB1 associated
[iNFO] Sun Feb 01 09:02:12 2004 Wireless system with MAC address 0019D202DAB1 disconnected for reason: Received Deauthentication.
[iNFO] Sun Feb 01 09:02:11 2004 Wireless system with MAC address 0019D202DAB1 associated
[iNFO] Sun Feb 01 09:02:11 2004 Wireless system with MAC address 0019D202DAB1 disconnected for reason: Received Deauthentication.
[iNFO] Sun Feb 01 09:02:10 2004 Wireless system with MAC address 0019D202DAB1 associated
[iNFO] Sun Feb 01 09:02:09 2004 Wireless system with MAC address 0019D202DAB1 disconnected for reason: Received Deauthentication.
[iNFO] Sun Feb 01 09:02:08 2004 Wireless system with MAC address 0019D202DAB1 associated
[iNFO] Sun Feb 01 09:02:07 2004 Wireless system with MAC address 0019D202DAB1 disconnected for reason: Received Deauthentication.
[iNFO] Sun Feb 01 09:02:00 2004 Blocked incoming TCP connection request from 195.0.218.122:3437 to 195.0.205.65:135
Noen som har en ide om problemet?
Har prøvd med og uten sikkerhetsinnstillinger.
Har prøvd så å si alle kanaler for å unngå interference med andre nettverk.
Det er totalt 8 nettverk inkl. mitt eget som er tilgjengelig hos meg, men mitt signal er det desidert sterkeste. Jeg valgte en kanal for mitt nettverk som ikke kolliderer med de andre (brukte nettstumbler for å finne ut kanalene de andre nettverkene gikk på).
Jeg har heller ikke 802.1x autentication påslått i XP som jeg vet kan føre til tilkoblingsfeil.
Jeg er helt rådvill her jeg, hva skal jeg gjøre?
Har en kompis i første etg. som også har trådløst nett, har lånt hans tilkobling for å teste. Dette går supersmooth til tross for at signalet er svakt... hvordan kan dette ha seg?
Takker for innspill!
Jon
Hmm, ingen som har noen ideer?
Jeg forsøkte i går å sette IP adressen statisk, det forbedret opplevelsen av hastigheten noe, men utkoblingen skjer likevel som før, men tilbakekoblingen går fortere.
Forsøkte å kjøre en massiv ping'ing av ruteren i går ved å la den stå på en god stund. Jeg ser da at svartidene ligger stort sett mellom 1 og 10 ms, mens det av og til hopper opp på 50-200 ms i noen sekunder, før det igjen legger seg tilbake på mellom 1 og 10 ms.
Innimellom timer det hele ut, dvs. "request timed out". Ca 10% av pakkene blir tapt når jeg kjører massiv ping i 10 minutter. Er dette akseptabelt?
Når jeg er tilkoblet kompisen min sitt nett i første etasje, så har jeg noe dårligere svartider (mellom 10ms og 100 ms), men denne forbindelsen mister jeg aldri... hvordan kan dette ha seg når hans ruter er "langt unna" i forhold til min...?
Jeg merker særlig problemer med streaming av video, på mitt nett funker det ikke (hakker), mens på kompisen min sitt nett går det smooth...
Mistenker derfor ruteren, koblet til med kabel til ruteren, og gjett hva !!
Det funker ikke med kabel heller!
Jeg koblet til med kabel direkte på modemet for å sjekke, og da gikk det smooth.... altså, det er ruteren som ikke takler streaming av video.....
Noen som aner hva jeg kan gjøre nå?
J.
  • 7 måneder senere...
Ut fra loggen ser det ut til å være et autentiseringsproblem.
Sjekk innstillinger for autentisering av MAC addresser og WPA eller WEP etter som hva du bruker.
Kanalane som ikke kolliderer med hverandre er 1,6 og 11.Det vil at hvis feks naboen kjører på 7 må du kjøre på 1 for å være helt uten påvirkning.
Selv om man får inn en kanal som excellent så betyr det ikke at kvaliteten på signalet nødvendigvis er bra.Det kan komme reflekterte signaler som når samtidig med ditt direkte signal som ødlegger da du tar imot både det forsinkede og direkte signalet samtidig.
802.1x er er autentisering for RADIUS server som brukes av bedrifter så den kan du glemme hvis du skal koble deg opp hjemme.
Endret av Knopfix
Then you'll need to make the following changes to the Wireless Router Settings:
Under the Advanced Wireless Settings:
Change the Beacon interval from 100 to 50
Change the fragmentation threshold from 2346 to 2306
Change the RTS threshold from 2347 to 2304.
Dette har jeg prøvd tidligere, og det så ut til å fungere for min egen del, men derimot på min søsters pc ble forbindelsen forkastelig, hun slet med å få koblet seg til nettet, og når hun først klarte det, varte ikke forbindelsen lenger enn maks ti minutter...
Resatte routerens innstillinger til "Factory default" eller noe for en stund siden, og da ble nettet bra hos søsteren min, men jeg fikk igjen problemer med at jeg mistet nettet ganske ofte, og tilfeldig, når jeg spilte eller hørte på nettradio.. :/
Testet nå igjen, bare for sikkerhetsskyld, og jeg merket absolutt ingen forskjell. Mister forbindelsen like ofte. :/
Har også prøvd å forandre kanal, fra 6 til 1, og deretter fra 1 til 12. Uten hell. :(
Prøv med bare B eller G Only både på ruterens innstillinger og på det trådløse nettverkskortet (Windowstast+Pause/Break -> Avansert) til datamaskin.
Har gjort det i routeren, men må jeg gjøre det på maskinen også? Hvordan gjør jeg det?
Win-tast + Pause|Break -> Avansert, bringer meg bare hit:
Hva trykker nå? Har sett rundt på alle tre knappene, ingen som virker relevante? :o
  • 1 måned senere...
Følgende løste mitt problemet med stadig å bli frakoblet fra den trådløse ruteren DIR-655.
Fikk svar fra http://service.dlink.biz og deres forslag virket!!! Hadde da hatt ustabilt nett siden jeg kjøpte min DIR-655 ruteren 6 måter før og nå blir jeg ikke lenger frakoblet og feilmeldingen: ”disconnected for reason: Received Deauthentication” forekommer ikke lenger i log-en på ruteren.
Løsningen var å fjerne haken på "Advansed", "Wi-Fi Protected Setup" "Enable" Dobbeltsjekket ved å sette den på igjen og da kom feilmeldingen tilbake med en gang.
Et lite skår i gleden er at det bare fungerte for min nye DELL Latitudee med Intel® PRO/wireless 3945ABG Network Connection Driver: Intel: 11.5.0.32 driver date: 26.09.2007 men ikke for min gamle IBM laptop med INTEL®PROWIRELESS 2100 men den er så gammel at jeg har akseptert å koble den direkte på ruteren.
Feilen oppstod ”bare” når jeg benyttet WPA-PSK, TKIP. Det vil si jeg mått i flere måter kjørt helt åpent kun MAC-filter for i det hele tatt å kunne bruke ruteren.
Har nå også koblet opp en gammel stasjonær PC med 54Mbps Trådløs USB adapter - DWL-G122 og den virker også fint.
Ruter:
Model:DIR-655
S/N F38B277005441
P/N EIR655EEU....A2G
Firmware Version: 1.11EU, 2007/11/5 Hardware Version: A2
Netverkskort:
--Ruter innstillinger:
-Wireless Network Settings
Enable Wireless:Always
Wireless Network Name:xxx
802.11 Mode : Mixed 802.11g and 802.11b
Enable Auto Channel Scan:Yes
Wireless Channel:-
Transmission Rate:Best (automatic)
Visibility Status:Visible
Security Mode :WPA-Personal
WPA Mode:WPA Only
Cipher Type:TKIP
Group Key Update Interval:3600
-Advanced Wireless Settings
Transmit Power :High
Beacon Period : 80
RTS Threshold : 2100
Fragmentation Threshold :2000
DTIM Interval:3
802.11d Enable:No
WLAN Partition:No
WMM Enable:Yes
Short GI:Yes
