Hva er galt med PC'n min??
Hei!
Når jeg skal kjøre spillet "Quake 3 Arena"
så får jeg en feilmelding:
Q3 1.11 win-x86 Nov 24 1999
----- FS_Startup -----
Current search path:
C:ProgramfilerQuake lllbaseq3pak1.pk3 (7 files)
C:ProgramfilerQuake lllbaseq3PAK0.PK3 (3543 files)
C:ProgramfilerQuake lll/baseq3
execing default.cfg
execing q3config.cfg
couldn't exec autoexec.cfg
...detecting CPU, found Intel Pentium III
------- Input Initialization -------
Initializing DirectInput...
Couldn't set DI coop level
Falling back to Win32 mouse support...
Joystick is not active.
----- Client Initialization -----
----- Initializing Renderer ----
----- Client Initialization Complete -----
--- Common Initialization Complete ---
Winsock Initialized
Opening IP socket: localhost:27960
Hostname: powerline
IP: 193.217.176.242
Working directory: C:ProgramfilerQuake lll
----- R_Init -----
Initializing OpenGL subsystem
...initializing QGL
...calling LoadLibrary( 'C:WINDOWSSYSTEMopengl32.dll' ): succeeded
...setting mode 3: 640 480 W
...registered window class
...created window@3,22 (646x505)
Initializing OpenGL driver
...getting DC: succeeded
...GLW_ChoosePFD( 32, 24, 8 )
...23 PFDs found
...GLW_ChoosePFD failed
...GLW_ChoosePFD( 16, 24, 0 )
...23 PFDs found
...failed to find an appropriate PIXELFORMAT
...WARNING: could not set the given mode (3)
...setting mode 3: 640 480 FS
...using colorsbits of 16
...calling CDS: ok
...created window@0,0 (640x480)
...GLW_ChoosePFD( 16, 24, 8 )
...23 PFDs found
...23 PFDs found
...restoring display settings
...shutting down QGL
...unloading OpenGL DLL
...assuming '3dfxvgl' is a standalone driver
...initializing QGL
...WARNING: missing Glide installation, assuming no 3Dfx available
----- CL_Shutdown -----
RE_Shutdown( 1 )
GLW_StartOpenGL() - could not load OpenGL subsystem
Hva er dette?
og hvordan får jeg det til og funke?
jeg skjønner at det er noe med 3dfx, men det burde funke.. har et "ATI 3d Rage Pro (atir3)" 3D kort...
hva er OpenGL?
Takk på forhånd...
Hilsen en "lurer" på pc...
