Reeve Skrevet 15. august 2007 Rapporter Del Skrevet 15. august 2007 om dette skal prøves a!! asap!! edit: lurer på om CPU'en hadde blitt enda bedre kjølt om de hadde latt luft bolblene gå gjennom kjøleren 9281618[/snapback] Luftboblene er bare til hinder for nedkjølingen. De har lagt de til for syns skyld. 9284736[/snapback] Joda, men etterhvert må jo væsken bli varm, selv om den kan trekke ut veldig mye varme før den blir noe særlig varmere. Kalde luftbobler ville nok hjulpet litt på å kjøle ned væsken igjen tenker jeg, men ikke så mye. Lenke til kommentar
OverCaffeinatedFightrpilot Skrevet 15. august 2007 Rapporter Del Skrevet 15. august 2007 (endret) om dette skal prøves a!! asap!! edit: lurer på om CPU'en hadde blitt enda bedre kjølt om de hadde latt luft bolblene gå gjennom kjøleren 9281618[/snapback] Luftboblene er bare til hinder for nedkjølingen. De har lagt de til for syns skyld. 9284736[/snapback] Nei, ifølge deres tester sank tempen med 4 grader, fra 88 til 84... Did Bubbles Help? After we saw the high maximum temperature during load, we started to think about what would happen if we pumped bubbles into the system. Theoretically, since the air for the bubbles was bring drawn from the outside air (we placed the intake a few feet away from the tank), the cooler bubbles should pick up the heat, then rise and release it to the air above. The question was whether the effect would be enough to show a noticeable difference. As you can see in the video, we had quite a bit of bubbles going. After about 2 hours, the temperature settled at a new maximum of 84C on the CPU under load. So, the bubbles did have an effect, but not as much as we were hoping for. Interestingly, the bubbles also hurt the video card temperature, causing it to rise by a few degrees! It seems the bubbles also served to agitate all the contents of the aquarium, bringing everything to a more consistent temperature throughout. edit: så hvis de hadde latt boblene gå tvers gjennom CPU kjøleren, så lurer jeg på om CPU'en hadde blitt kaldere. Klikk for å se/fjerne innholdet nedenfor Endret 15. august 2007 av twintip Lenke til kommentar
Flimzes Skrevet 15. august 2007 Rapporter Del Skrevet 15. august 2007 Luft leder varme dårligere enn olje, så det hadde fått motsatt effekt av å ha pc'en i olje (om du skal kjøre luft gjennom kjøleren så er det liten vits i å dyppe den i olje ) Lenke til kommentar
OverCaffeinatedFightrpilot Skrevet 15. august 2007 Rapporter Del Skrevet 15. august 2007 Luft leder varme dårligere enn olje, så det hadde fått motsatt effekt av å ha pc'en i olje (om du skal kjøre luft gjennom kjøleren så er det liten vits i å dyppe den i olje ) 9286678[/snapback] heoretically, since the air for the bubbles was bring drawn from the outside air (we placed the intake a few feet away from the tank), the cooler bubbles should pick up the heat, then rise and release it to the air above. Lenke til kommentar
Flimzes Skrevet 15. august 2007 Rapporter Del Skrevet 15. august 2007 Samme effekt som å ha et luftrør inn fra siden av kabinettet rett over cpu-vifte... Lenke til kommentar
OverCaffeinatedFightrpilot Skrevet 15. august 2007 Rapporter Del Skrevet 15. august 2007 Samme effekt som å ha et luftrør inn fra siden av kabinettet rett over cpu-vifte... 9287052[/snapback] nå snakker vi ikke om en luftkjølt pc heller da.... Lenke til kommentar
Flimzes Skrevet 15. august 2007 Rapporter Del Skrevet 15. august 2007 Samme effekt som å ha et luftrør inn fra siden av kabinettet rett over cpu-vifte... 9287052[/snapback] nå snakker vi ikke om en luftkjølt pc heller da.... 9287529[/snapback] Nei, det er derfor jeg ikke ser poenget med å ta inn luft i den, for da blir det en luftkjølt pc igjen, og da kan man like gjerne holde oljen utenfor... Lenke til kommentar
OverCaffeinatedFightrpilot Skrevet 15. august 2007 Rapporter Del Skrevet 15. august 2007 Samme effekt som å ha et luftrør inn fra siden av kabinettet rett over cpu-vifte... 9287052[/snapback] nå snakker vi ikke om en luftkjølt pc heller da.... 9287529[/snapback] Nei, det er derfor jeg ikke ser poenget med å ta inn luft i den, for da blir det en luftkjølt pc igjen, og da kan man like gjerne holde oljen utenfor... 9288359[/snapback] nigga plz... Lenke til kommentar
