Dark Signs(DS) og Dark Signs Online(DSO
DS:
Overview
Simply, Dark Signs is a game which simulates a network environment. It allows you to play as a computer systems hacker or cracker. Dark Signs has many advanced modes and features which place it above others.
D-SCRIPT
Dark Signs includes its own scripting language, codenamed D-SCRIPT. It has full support for the console interface, and supports advanced programming commands such as IF...ELSE...ENDIF, LOOPS, PAUSE, VARIABLES, and much, much more. This alone gives Dark Signs an amazing amount of flexibility.
GRAPHICAL USER INTERFACE
Dark Signs features a fully customizable icon based GUI system.
COMMANDS
Dark Signs is much, much, more than CONNECT, CRACK, DISCONNECT. Already, the console features over 60 unique commands, and over 30 function commands which can be used in combination with D-SCRIPT.
CUSTOMIZE
Edit your in game system files... just the way you want. Change your startup script, make it do what you want when the game starts. You can even make it start playing music files automatically.
DIRECTORY STRUCTURE
Dark Signs features its own unique directory structure to use in the console. This means it has seperate directories where you can store files. It allows you to create new folders and files, and move them around.
MORE
There is too much in this game to write it all on this page. As we continue to develop the game, we will keep you updated, just stay tuned to www.darksigns.com.
WANT MORE INFORMATION?
We would love to hear from you on the DARK SIGNS FORUMS. You will find a wealth of information.
At this time, the game is stil in development, and is expected early in 2003. Keep your eye on us, you will not regret it.
DSO:
Check the first screenshot... shows one of the basic design, more shots and details coming soon.
http://www.darksigns.com/dso1.gif
Dark Signs Online is the first Client based multiplayer hacking simulator. There is a *lot* to this game. Check the website and forums and the end of this post for more information.
We are developing a new in game language for DSO (Dark Signs Online), currently named ESSENCE (which we started today, but it is amazingly simple to code and learn). There will be a free essence editor available for windows within the next 48 - 72 hours. This language allows you to develop full GUI systems for the game. You can totally and *easily* develop your own GUI people will see when they connect to your system in the game. No limits. Well, at least not many.
We are starting beta testing on the 1st of February. You can always join after it starts, but there is a $6 cost to join (to help server costs, and otherwise we would have way to many requests to join so we want people who are serious.). Dark Signs is being developed by Terminal Zero (a registered company), and we will do our best to be fair if anything happens. We can refund your money if their is any problem.
If you would like to beta test this game you can get more information here
http://www.darksigns.com/forums/viewforum.php?f=33
You can join us if you have questions on IRC
IRC.UPLINKCORP.NET
#darksigns
Hope to see you there
Other Questions - [email protected] or reply here so everyone can benefit from the response.
Ta dere en tur og titt litt. For de intreserte kan jeg si at dette ser veldig lovende ut. :)
  • 10 år senere...
