ny cpu, svar fort!plz thx :)
Celeron 266 ALL ALL
Celeron 300 ALL ALL
Celeron 300A ALL ALL
Celeron 333 ALL ALL
Celeron 366 ALL ALL
Celeron 400 ALL ALL
Celeron 433 ALL ALL
Celeron 466 ALL ALL
Celeron 500 ALL ALL
Celeron 533 ALL ALL
Celeron 533A (socket370 with S370-DL) 1.04 1008.001
Celeron 566 (socket370 with S370-DL) 1.04 1008.001
Celeron 600 (socket370 with S370-DL) 1.04 1008.001
Celeron 633 (socket370 with S370-DL) 1.04 1008.001
Celeron 667 (socket370 with S370-DL) 1.04 1008.001
Celeron 700 (socket370 with S370-DL) 1.04 1008.001
Celeron 733 (socket370 with S370-DL) 1.04 1008.001
Celeron 766 (socket370 with S370-DL) 1.04 1008.001
Celeron 800 (socket370 with S370-DL) 1.04 1008.001
Celeron 850 (socket370 with S370-DL) 1.04 1008.004
Celeron 900 (socket370 with S370-DL) 1.04 1008.004
Celeron 950 (socket370 with S370-DL) 1.04 1008.004
Celeron 1000 (socket370 with S370-DL) 1.04 1008.004
Celeron 1100 (socket370 with S370-DL) 1.04 1008.004
P2-233 MHz ALL ALL
P2-266 MHz ALL ALL
P2-300 MHz ALL ALL
P2-333 MHz ALL ALL
P2-350 MHz ALL ALL
P2-400 MHz ALL ALL
P2-450 MHz ALL ALL
P3-450 MHz(slot1) ALL ALL
P3-500 MHz(slot1) ALL ALL
P3-550E MHz(slot1) 1.04 1004
P3-550 MHz(slot1) ALL ALL
P3-550E MHz(socket370 with S370-DL) 1.04 1004
P3-600E MHz(slot1) 1.04 1007.001
P3-600 MHz(slot1) ALL ALL
P3-600E MHz(socket370 with S370-DL) 1.04 1007.001
P3-600 MHz(socket370 with S370-DL) ALL ALL
P3-650 MHz(socket370 with S370-DL) 1.04 1008.001
P3-650 MHz(slot1) 1.04 1008.001
P3-700 MHz(slot1) 1.04 1008.001
P3-700 MHz(socket370 with S370-DL) 1.04 1008.001
P3-750 MHz(socket370 with S370-DL) 1.04 1008.001
P3-750 MHz(slot1) 1.04 1008.001
P3-800 MHz(slot1) 1.04 1008.001
P3-850 MHz(slot1) 1.04 1008.001
P3-900 MHz(slot1) 1.04 1008.001
P3-1.0 GHz(slot1) 1.04 1008.001
en liten forklaring: ALL betyr seff at det er støtte for det.
1.04 betyr at kortet må ha rev 1.04 for at det skal funke, det skal stå nede ved den siste isa/pci porten ellernoe. 1008.001 er hvilken bios du må ha (eller nyere) for og få støtte for dette. håper du fortstår!
mvh Anders
Takker for alle svar!
Men vi kjøpte dette i stedet:
xp1800
128mb ddr pc 2100(kommer mer når det er nok penger)
Asus A7V333-X Hovedkort for Socket A DDR
VIAKT333, ATA/133, ATX, USB2.0, LAN
coolermaster opp til xp1800
gf4 mx440SE 128 mb ram
og en Maxtor 60gb.
Dette er vel en grei pc til en som hadde 4000kr å bruke pluss gamle deler.
xp1800
og en Maxtor 60gb.
Har nesten det samme og er fornøyd.......
