Python - Visual Basic.NET konverter?
Det er ganske mange filer med kode, men jeg kan jo poste den ene da.. :)
#!/usr/bin/python
#Boa:App:BoaApp
# Name:        ClamWin.py
# Product:     ClamWin Free Antivirus
# Author:      alch [alch at users dot sourceforge dot net]
# Created:     2004/19/03
# Copyright:   Copyright alch (c) 2004
# Licence:
#   This program is free software; you can redistribute it and/or modify
#   it under the terms of the GNU General Public License as published by
#   the Free Software Foundation; either version 2 of the License, or
#   (at your option) any later version.
#   This program is distributed in the hope that it will be useful,
#   but WITHOUT ANY WARRANTY; without even the implied warranty of
#   MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
#   GNU General Public License for more details.
#   You should have received a copy of the GNU General Public License
#   along with this program; if not, write to the Free Software
#   Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA.
import SetUnicode
import sys, os, locale
import RedirectStd
from wxPython.wx import *
import wxFrameMain, Utils, wxDialogUtils
import Config
modules ={'ClamTray': [0, '', 'ClamTray.py'],
'CloseWindows': [0, '', 'CloseWindows.py'],
'Config': [0, '', 'Config.py'],
'EmailAlert': [0, '', 'EmailAlert.py'],
'ExplorerShell': [0, '', 'ExplorerShell.py'],
'MsgBox': [0, '', 'MsgBox.py'],
'OlAddin': [0, '', 'OlAddin.py'],
'Process': [0, '', 'Process.py'],
'RedirectStd': [0, '', 'RedirectStd.py'],
'Scheduler': [0, '', 'Scheduler.py'],
'SplashScreen': [0, '', 'SplashScreen.py'],
'Utils': [0, '', 'Utils.py'],
'wxDialogAbout': [0, '', 'wxDialogAbout.py'],
'wxDialogCheckUpdate': [0, '', 'wxDialogCheckUpdate.py'],
'wxDialogLogViewer': [0, '', 'wxDialogLogViewer.py'],
'wxDialogPreferences': [0, '', 'wxDialogPreferences.py'],
'wxDialogScheduledScan': [0, '', 'wxDialogScheduledScan.py'],
'wxDialogStatus': [0, '', 'wxDialogStatus.py'],
'wxDialogUtils': [0, '', 'wxDialogUtils.py'],
'wxFrameMain': [1, 'Main frame of Application', 'wxFrameMain.py']}
class BoaApp(wxApp):
   def __init__(self, params, config, mode='main', autoClose=False, path=''):
       self.config = config
       self.mode = mode
       self.path = path
       self.autoClose = autoClose
       self.exit_code = 0
       wxApp.__init__(self, params)
   def OnInit(self):
       wxInitAllImageHandlers()
       if self.mode == 'scanner':
           self.exit_code = wxDialogUtils.wxScan(parent=None, config=self.config, path=self.path, autoClose=self.autoClose)
       elif self.mode == 'update':
           self.exit_code = wxDialogUtils.wxUpdateVirDB(parent=None, config=self.config, autoClose=self.autoClose)
       elif self.mode == 'configure':
           wxDialogUtils.wxConfigure(parent=None, config=self.config)
       elif self.mode == 'configure_schedule':
           wxDialogUtils.wxConfigure(parent=None, config=self.config, switchToSchedule=True)
       elif self.mode == 'about':
           wxDialogUtils.wxAbout(parent=None, config=self.config)
       elif self.mode == 'viewlog':
           wxDialogUtils.wxShowLog(parent=None, logfile=self.path.strip('"'))
       elif self.mode == 'checkversion':
           wxDialogUtils.wxCheckUpdate(parent=None, config=self.config)
       else: #  mode == 'main'
           self.main = wxFrameMain.create(parent=None, config=self.config)
           self.main.Show()
           #workaround for running in wxProcess
           self.SetTopWindow(self.main)
       return True
def main(config=None, mode='main', autoClose=False, path='', config_file=None):
   currentDir = Utils.GetCurrentDir(True)
   os.chdir(currentDir)
   Utils.CreateProfile()
   if config is None:
       if(config_file is None):
           config_file = os.path.join(Utils.GetProfileDir(True),'ClamWin.conf')
       else:
           config_file = Utils.SafeExpandEnvironmentStrings(config_file)
       config = Config.Settings(config_file)
       b = config.Read()
   app = BoaApp(0, config, mode=mode, autoClose=autoClose, path=path)
   app.MainLoop()
   return app.exit_code
if __name__ == '__main__':
   import locale, codecs, encodings
   print "System Locale:", locale.getdefaultlocale()
   print "Default Encoding:", sys.getdefaultencoding()
   # set C locale, otherwise python and wxpython complain
   locale.setlocale(locale.LC_ALL, 'C')
   close = False
   mode = 'main'
   path = ''
   config_file = None
   for arg in sys.argv[1:]:
       if arg == '--close':
           close = True
       if arg.find('--mode=') == 0:
           mode = arg[len('--mode='):]
       if arg.find('--path=') == 0:
           path += '"' + arg[len('--path='):] + '" '
       if arg.find('--config_file=') == 0:
           config_file = arg[len('--config_file='):]
   print "command line path: %s" % path.strip()
   exit_code = main(mode=mode, autoClose=close, path=path.strip(), config_file=config_file)
   sys.exit(exit_code)
Altså, det er fra et open source antivirus program. Det er mye rot i det jeg lastet ned og jeg skjønner ikke helt hvordan jeg skal finne ting jeg er ute etter.
Endret av AnaXyd
Vil du ha oversatt hele ClamWin til VB?
Du kan ikke være vel bevart.
EDIT: Etter å ha lest noen av dine andre poster i denna biten av forumet, tror jeg det beste jeg kan anbefale deg er å få en viss føring på språket (VB) og rammeverket (.NET) før du prøver å lage noe sånt som en spyware scanner.
Endret av ze5400
Hehe.. :p Ikke hele da, men kanskje litt av den. Nå skjønner jo ikke jeg akkurat python heller, så jeg veit ikke åssen dette er.
Går det ikke an å oversette det jeg postet f.eks?
Men det er fremdeles mulig å oversette hele ClamWin til VB? :)
EDIT:
Mener du det..? Tanken har falt meg før, men jeg syntes det virker veldig spennende med det å lage dette da... Selv om den ikke blir veldig avansert i første runde kan jeg kanskje lære en del av det?
Har du noen andre ideer som kanskje kan være enklere for meg å lage da? :)
Endret av AnaXyd
