Kan ikke velge høyere oppløsning enn 1024x768
I Windows bruker jeg 1280x1024, men i Ubuntu kommer ikke dette valget opp. Skjermkortdriveren er tilsynelatende riktig innstallert, iallfall så langt jeg kan se. Er ikke dette mulig eller er det noe jeg har gjort feil, evnt ikke gjort?
lspci:
Klikk for å se/fjerne innholdet nedenfor
erlend@erlend-desktop:~$ lspci
00:00.0 Host bridge: Silicon Integrated Systems [siS] 661FX/M661FX/M661MX Host (rev 11)
00:01.0 PCI bridge: Silicon Integrated Systems [siS] SiS AGP Port (virtual PCI-to-PCI bridge)
00:02.0 ISA bridge: Silicon Integrated Systems [siS] SiS964 [MuTIOL Media IO] (rev 36)
00:02.5 IDE interface: Silicon Integrated Systems [siS] 5513 [iDE] (rev 01)
00:02.7 Multimedia audio controller: Silicon Integrated Systems [siS] AC'97 Sound Controller (rev a0)
00:03.0 USB Controller: Silicon Integrated Systems [siS] USB 1.0 Controller (rev 0f)
00:03.1 USB Controller: Silicon Integrated Systems [siS] USB 1.0 Controller (rev 0f)
00:03.2 USB Controller: Silicon Integrated Systems [siS] USB 1.0 Controller (rev 0f)
00:03.3 USB Controller: Silicon Integrated Systems [siS] USB 2.0 Controller
00:04.0 Ethernet controller: Silicon Integrated Systems [siS] SiS900 PCI Fast Ethernet (rev 91)
00:05.0 IDE interface: Silicon Integrated Systems [siS] RAID bus controller 180 SATA/PATA [siS] (rev 01)
00:07.0 FireWire (IEEE 1394): VIA Technologies, Inc. IEEE 1394 Host Controller (rev 46)
01:00.0 VGA compatible controller: ATI Technologies Inc RV410 [Radeon X700 (PCIE)]
01:00.1 Display controller: ATI Technologies Inc RV410 [Radeon X700 (PCIE)] (Secondary)
cat /etc/X11/xorg.conf:
erlend@erlend-desktop:~$ cat /etc/X11/xorg.conf
# /etc/X11/xorg.conf (xorg X Window System server configuration file)
# This file was generated by dexconf, the Debian X Configuration tool, using
# values from the debconf database.
# Edit this file with caution, and see the xorg.conf(5) manual page.
# (Type "man xorg.conf" at the shell prompt.)
# This file is automatically updated on xserver-xorg package upgrades *only*
# if it has not been modified since the last upgrade of the xserver-xorg
# package.
# If you have edited this file but would like it to be automatically updated
# again, run the following command:
# sudo dpkg-reconfigure -phigh xserver-xorg
Section "Files"
Fontpath "/usr/share/fonts/X11/misc"
Fontpath "/usr/share/fonts/X11/cyrillic"
Fontpath "/usr/share/fonts/X11/100dpi/:unscaled"
Fontpath "/usr/share/fonts/X11/75dpi/:unscaled"
Fontpath "/usr/share/fonts/X11/Type1"
Fontpath "/usr/share/fonts/X11/100dpi"
Fontpath "/usr/share/fonts/X11/75dpi"
# path to defoma fonts
Fontpath "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType"
EndSection
Section "Module"
Load "i2c"
Load "bitmap"
Load "ddc"
Load "dri"
Load "extmod"
Load "freetype"
Load "glx"
Load "int10"
Load "vbe"
EndSection
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "kbd"
Option "CoreKeyboard"
Option "XkbRules" "xorg"
Option "XkbModel" "pc105"
Option "XkbLayout" "no"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
Option "CorePointer"
Option "Device" "/dev/input/mice"
Option "Protocol" "ImPS/2"
Option "ZAxisMapping" "4 5"
Option "Emulate3Buttons" "true"
EndSection
Driver "wacom"
Identifier "stylus"
Option "Device" "/dev/input/wacom"
Option "Type" "stylus"
Option "ForceDevice" "ISDV4"# Tablet PC ONLY
EndSection
Driver "wacom"
Identifier "eraser"
Option "Type" "eraser"
EndSection
Driver "wacom"
Identifier "cursor"
Option "Type" "cursor"
EndSection
Section "Device"
Identifier "ATI Technologies Inc RV410 [Radeon X700 (PCIE)]"
Driver "fglrx"
Busid "PCI:1:0:0"
EndSection
Section "Monitor"
Identifier "Generic Monitor"
Option "DPMS"
Horizsync 28-51
Vertrefresh 43-60
EndSection
Section "Screen"
Identifier "Default Screen"
Device "ATI Technologies Inc RV410 [Radeon X700 (PCIE)]"
Monitor "Generic Monitor"
Defaultdepth 24
SubSection "Display"
Depth 1
Modes "1024x768" "800x600" "640x480"
EndSubSection
Depth 4
EndSubSection
Depth 8
EndSubSection
Depth 15
EndSubSection
Depth 16
EndSubSection
Depth 24
EndSubSection
EndSection
Section "ServerLayout"
Identifier "Default Layout"
screen "Default Screen"
Inputdevice "Generic Keyboard"
Inputdevice "Configured Mouse"
Inputdevice "stylus" "SendCoreEvents"
Inputdevice "cursor" "SendCoreEvents"
Inputdevice "eraser" "SendCoreEvents"
EndSection
Section "DRI"
Mode 0666
EndSection
Section "Extensions"
Option "Composite" "0"
EndSection
Endret av Atald
gå inn i xorg.conf, erstatt
Section "Screen"
Defaultdepth 24
Depth 1
EndSubSection
Depth 4
EndSubSection
Depth 8
EndSubSection
Depth 15
EndSubSection
Depth 16
EndSubSection
Depth 24
EndSubSection
EndSection
med
Section "Screen"
Defaultdepth 24
Depth 24
Modes "1280x1024"
EndSubSection
EndSection
Funker ikke det bør du kanskje kjøre sudo dpkg-reconfigure -phigh xserver-xorg
Endret av hockey500
Ett annen alternativ løsning, i alle fall i Fedora, er System -> Administrasjon -> Skjerm -> Maskinvare
Så endrer man skjermtype til en skjerm som støtter den oppløsningen man ønsker. Da skal det være flerer oppløsninger tilgjengelig i Innstillinger fanen.
Så må man restarte X, trykk Ctrl+Alt+Back Space (utviskning)
Da vil alle oppløsningene være tilgjengelig for bruk under System -> Brukervalg -> Skjermoppløsning
Velg oppløsning og trykk på bruk. Spretter så opp en boks om du vil beholde den nye oppløsningen eller gå tilbake til den andre.
Endret av crowly
Høres merkelig ut om man må velge skjerm manuelt, X pleier jo å hente slik info rett fra skjermen om det ikke er oppgitt.
Selv har jeg forøvrig motsatt "problem", X starter alltid opp i 2048x1536 etter en "fresh install", som er det høyeste skjermen min klarer. Er ikke fremmed for å rote i xorg.conf, og får satt den ned litt uten problemer, men litt rart at den velger absolutt høyeste mulige oppløsning på en CRT-skjerm.
Endret av Sokkalf^
Jeg kjører på Fedora Core 6, har hatt litt forskjellig erfaring. På LCD skjermen min så blir rett skjermtype oppdaget og 1280x1024 satt som oppløsning. Mens på CRT skjermen så blir det satt til genetic 1024. Edit: Tror oppløsningen ble satt til 800x600 en gang også, derfor var dette en av de førte tingene jeg måtte lære meg i Linux/Fedora.
Men det er jo greit å vite hva man kan gjøre hvis ting ikke er som man ønsker ;)
Endret av crowly
Man kan bruke ctrl+alt+pluss og ctrl+alt+minus for å rotere blant oppløsningene i listen (man kan ha en eller flere oppløsninger på samme linja) i xorg.conf. (Men om den ønskede oppløsningen ikke står der, eller skjermen ikke tåler den, så hjelper det jo ikke).
Endret av kommers
Eg har det samme problemet. eg veit ikkje eingogn korleis ein kjem inn i xorg.conf fila. Eg får åpna den i consolen men korleis ein ska gå vidare veit eg ikkje. Eg har dreve med windows veldig lenge og eg bestemte meg i går for å prøve ubuntu. men det va det med skjermoppløsninga som er eit irritasjons moment.
Redigert. Eg fant ut korleis ein åpna xorg.conf fila. men får ikkje lagra forandringan. korleis får ein fram den sudo greia då?
Redigert2. Eg fann det ut. eg kopierte greia fra forumet her og la inn i consolen. Men det ser ut som det er eit uklart bilete. Eg har invidia gforce 8400gs grafikk kort med 128 mb ram p[.
Endret av Tobak30
sudo dpkg-reconfigure -phigh xserver-xorg Ser ikkje ut til aa virke. Kva skal ein gjere faar at det skal virke. Eg kom meg inn der og etter aa ha installert drivarene for nvidia kortet og deretter valgt nvidia og 1280ganger1024 saa skjedde det ingenting.
