Thoroughbred A og B
toreide
..og alle xp1700 og 1800 har A kjerne (pr. i dag vil jeg tro, i alle fall hos nettbutikkene i noreg), har kjøpt xp1800a og den er mye kaldere enn xp1600 palmino. hadde ca.50 idle før, har 36 idle nå, bruker kun en papst 12dB vifte, ingen kab.vifter og en radeon 8500 uten vifte (det kommer en del varme fra gpu som øker temp i kabinettet)
Leser du denne posten så kan du se på kodene hvilken CPU det er:
http://www.amdforums.com/showthread.php?th...threadid=170363
Which Codes Mean What
To make this easy, what you need to know is listed by processor speed.
The OPN information is printed somewhere on every AMD CPU. For all Palominos, if you're looking at one, the OPN is the first code printed on the core of the CPU located in the middle of the processor. For all Thoroughbreds, the OPN the first code printed on the black area on one edge of the CPU.
1700+
Palominos: If the website you're ordering from shows an order code of AX1700DMT3C, that's a Palomino.
TBredA: If the website you're ordering from shows an order code of AXDA1700DLT3C, that's a Throughbred A.
1800+
Palominos: If the website you're ordering from shows an order code of AX1800DMT3C, that's a Palomino.
TBredA: If the website you're ordering from shows an order code of AXDA1800DLT3C, that's a Throughbred A.
TBredB: If the website you're ordering from shows an order code of AXDA1800DUT3C, that's a Throughbred B.
1900+
Palominos: If the website you're ordering from shows an order code of AX1900DMT3C, that's a Palomino.
TBredA: If the website you're ordering from shows an order code of AXDA1900DLT3C, that's a Throughbred A.
2000+
Palominos: If the website you're ordering from shows an order code of AX2000DMT3C, that's a Palomino.
TBredA: If the website you're ordering from shows an order code of AXDA2000DKT3C, that's a Throughbred A.
TBredA/B: If the website you're ordering from shows an order code of AXDA2000DUT3C, that could be either a Thoroughbred A or Thoroughbred B. The only way to distinguish between the two is by the stepping code. A TBred A will have a stepping code like "AIRGA." A TBred B will have a stepping code like "AIUAB".
P.S. There's two listed TBredA types in the AMD techdoc. One uses 1.6V, the other uses 1.65V. The TBredB is solely 1.6V.
2100+
Palominos: If the website you're ordering from shows an order code of AX2100DMT3C, that's a Palomino.
TBredA/B: If the website you're ordering from shows an order code of AXDA2000DUT3C, that could be either a Thoroughbred A or Thoroughbred B. The only way to distinguish between the two is by the stepping code. A TBred A will have a stepping code like "AIRGA." A TBred B will have a stepping code like "AIUAB.
2200+
TBredA: If the website you're ordering from shows an order code of AXDA2200DKV3C, that's a Throughbred A.
TBredB: If the website you're ordering from shows an order code of AXDA2200DUV3C, that's a Throughbred B.
2400+
They're all TBredBs, and they'll have an order code of AXDA2400DKV3C.
Edit: Egentlig samme info som Robin B refererer til...
Thoroughbred B kjerne er ikke dyrere nei, når den kommer ut på XP1800 så koster den like mye som T-bred A og palomino.
Thoroughbred B er blitt solgt i butikker i Tyskland og Hellas. (ikke webshopper)
Forhåpentligvis tar det ikke lange tiden før den kommer til Norge også.
Komplett.no har tømt lagrene for XP1700/1800 palomino og selger nå bare XP1700/1800 T-bred A.
Vil tippe at T-bred B er i salg i Norge neste måned.
Hvor mye kan det være mulig og overklokke av xp2400+ med hovedkortet som jeg har i signatur til?
Spørs åssen kjøling du har, men vil tippe du kan få den opp i noe rundt 2,2-2,5 Ghz. Spørs vel litt på hvilken stepping og kjøling du har.
Jeg har Thermaltake Volcano 9, den burde vel holde et lite stykke oppover?
Stepping? Hvor står det? Sry, men har lite peil når det kommer til overklokking...
Stepping står på prosessoren din.. men siden du sikkert ikke gidder å ta av kjøler så kan det være det samme. Det er ikke så viktig.. Er bare å klokke til det enten blir for varmt, eller at du ikke kommer lengre det.
vil du sjekke steppinga på CPU'en din kan du bare ta ned wcpuid fra nettet. Der får du det svart på hvitt..
feil. Her snakker vi om steppingen på prosessoren, og den står direkte på CPU, og på eldre AMD prosessore på core.
Du finner ikke steppingen i wcpuid.
f.eks jeg har ANDA stepping på min duron, men står ikke noe om ANDA i wcpuid.
