Problemer med å kompilere driver
Hei! Sitter å prøver å kompilere en driver til et IO-kort på en Ubuntu Feisty
maskin. Har kun funnet disse eksperimentelle driverene til kortet mitt:
https://sourceforge.net/project/showfiles.p...ckage_id=113802
Problemet er at jeg får en haug med errors, har fått rettet noen, men
står igjen med dette:
Klikk for å se/fjerne innholdet nedenfor
# make
gcc -D__KERNEL__ -DMODULE -Wall -Wstrict-prototypes -O2 -I/usr/src/linux-headers-2.6.20-15-386/include -DMODVERSIONS -include /usr/src/linux-headers-2.6.20-15-386/include/config/modversions.h -c ./dt340.c
In file included from /usr/src/linux-headers-2.6.20-15-386/include/asm/thread_info.h:16,
from /usr/src/linux-headers-2.6.20-15-386/include/linux/thread_info.h:21,
from /usr/src/linux-headers-2.6.20-15-386/include/linux/preempt.h:9,
from /usr/src/linux-headers-2.6.20-15-386/include/linux/spinlock.h:49,
from /usr/src/linux-headers-2.6.20-15-386/include/linux/module.h:9,
from ./dt340.c:21:
/usr/src/linux-headers-2.6.20-15-386/include/asm/processor.h:82: error: ‘CONFIG_X86_L1_CACHE_SHIFT’ undeclared here (not in a function)
/usr/src/linux-headers-2.6.20-15-386/include/asm/processor.h:82: error: requested alignment is not a constant
/usr/src/linux-headers-2.6.20-15-386/include/asm/processor.h: In function ‘cpuid_count’:
/usr/src/linux-headers-2.6.20-15-386/include/asm/processor.h:611: warning: pointer targets in passing argument 1 of ‘native_cpuid’ differ in signedness
/usr/src/linux-headers-2.6.20-15-386/include/asm/processor.h:611: warning: pointer targets in passing argument 2 of ‘native_cpuid’ differ in signedness
/usr/src/linux-headers-2.6.20-15-386/include/asm/processor.h:611: warning: pointer targets in passing argument 3 of ‘native_cpuid’ differ in signedness
/usr/src/linux-headers-2.6.20-15-386/include/asm/processor.h:611: warning: pointer targets in passing argument 4 of ‘native_cpuid’ differ in signedness
In file included from /usr/src/linux-headers-2.6.20-15-386/include/linux/sched.h:51,
from /usr/src/linux-headers-2.6.20-15-386/include/linux/utsname.h:35,
from /usr/src/linux-headers-2.6.20-15-386/include/asm/elf.h:12,
from /usr/src/linux-headers-2.6.20-15-386/include/linux/elf.h:7,
from /usr/src/linux-headers-2.6.20-15-386/include/linux/module.h:15,
from ./dt340.c:21:
/usr/src/linux-headers-2.6.20-15-386/include/linux/jiffies.h:33:3: error: #error You lose.
/usr/src/linux-headers-2.6.20-15-386/include/linux/jiffies.h:225:31: error: division by zero in #if
/usr/src/linux-headers-2.6.20-15-386/include/linux/jiffies.h:269:46: error: division by zero in #if
from ./dt340.c:21:
/usr/src/linux-headers-2.6.20-15-386/include/linux/jiffies.h: In function ‘jiffies_to_msecs’:
/usr/src/linux-headers-2.6.20-15-386/include/linux/jiffies.h:274: error: ‘CONFIG_HZ’ undeclared (first use in this function)
/usr/src/linux-headers-2.6.20-15-386/include/linux/jiffies.h:274: error: (Each undeclared identifier is reported only once
/usr/src/linux-headers-2.6.20-15-386/include/linux/jiffies.h:274: error: for each function it appears in.)
/usr/src/linux-headers-2.6.20-15-386/include/linux/jiffies.h:280:46: error: division by zero in #if
/usr/src/linux-headers-2.6.20-15-386/include/linux/jiffies.h: In function ‘jiffies_to_usecs’:
/usr/src/linux-headers-2.6.20-15-386/include/linux/jiffies.h:285: error: ‘CONFIG_HZ’ undeclared (first use in this function)
/usr/src/linux-headers-2.6.20-15-386/include/linux/jiffies.h:293:46: error: division by zero in #if
/usr/src/linux-headers-2.6.20-15-386/include/linux/jiffies.h: In function ‘msecs_to_jiffies’:
/usr/src/linux-headers-2.6.20-15-386/include/linux/jiffies.h:298: error: ‘CONFIG_HZ’ undeclared (first use in this function)
/usr/src/linux-headers-2.6.20-15-386/include/linux/jiffies.h:306:46: error: division by zero in #if
/usr/src/linux-headers-2.6.20-15-386/include/linux/jiffies.h: In function ‘usecs_to_jiffies’:
/usr/src/linux-headers-2.6.20-15-386/include/linux/jiffies.h:311: error: ‘CONFIG_HZ’ undeclared (first use in this function)
/usr/src/linux-headers-2.6.20-15-386/include/linux/jiffies.h: In function ‘timespec_to_jiffies’:
/usr/src/linux-headers-2.6.20-15-386/include/linux/jiffies.h:330: error: ‘CONFIG_HZ’ undeclared (first use in this function)
/usr/src/linux-headers-2.6.20-15-386/include/linux/jiffies.h:336: error: ‘SHIFT_HZ’ undeclared (first use in this function)
/usr/src/linux-headers-2.6.20-15-386/include/linux/jiffies.h: In function ‘jiffies_to_timespec’:
/usr/src/linux-headers-2.6.20-15-386/include/linux/jiffies.h:349: error: ‘CONFIG_HZ’ undeclared (first use in this function)
/usr/src/linux-headers-2.6.20-15-386/include/linux/jiffies.h: In function ‘timeval_to_jiffies’:
/usr/src/linux-headers-2.6.20-15-386/include/linux/jiffies.h:371: error: ‘CONFIG_HZ’ undeclared (first use in this function)
/usr/src/linux-headers-2.6.20-15-386/include/linux/jiffies.h:375: error: ‘SHIFT_HZ’ undeclared (first use in this function)
/usr/src/linux-headers-2.6.20-15-386/include/linux/jiffies.h: In function ‘jiffies_to_timeval’:
/usr/src/linux-headers-2.6.20-15-386/include/linux/jiffies.h:387: error: ‘CONFIG_HZ’ undeclared (first use in this function)
/usr/src/linux-headers-2.6.20-15-386/include/linux/jiffies.h:400:6: error: division by zero in #if
/usr/src/linux-headers-2.6.20-15-386/include/linux/jiffies.h: In function ‘jiffies_to_clock_t’:
/usr/src/linux-headers-2.6.20-15-386/include/linux/jiffies.h:401: error: ‘CONFIG_HZ’ undeclared (first use in this function)
/usr/src/linux-headers-2.6.20-15-386/include/linux/jiffies.h: In function ‘clock_t_to_jiffies’:
/usr/src/linux-headers-2.6.20-15-386/include/linux/jiffies.h:412: error: ‘CONFIG_HZ’ undeclared (first use in this function)
/usr/src/linux-headers-2.6.20-15-386/include/linux/jiffies.h:431:6: error: division by zero in #if
/usr/src/linux-headers-2.6.20-15-386/include/linux/jiffies.h: In function ‘jiffies_64_to_clock_t’:
/usr/src/linux-headers-2.6.20-15-386/include/linux/jiffies.h:432: error: ‘CONFIG_HZ’ undeclared (first use in this function)
In file included from /usr/src/linux-headers-2.6.20-15-386/include/linux/aio.h:5,
from /usr/src/linux-headers-2.6.20-15-386/include/linux/sched.h:260,
from ./dt340.c:21:
/usr/src/linux-headers-2.6.20-15-386/include/linux/workqueue.h: In function ‘cancel_delayed_work’:
/usr/src/linux-headers-2.6.20-15-386/include/linux/workqueue.h:203: warning: dereferencing type-punned pointer will break strict-aliasing rules
In file included from /usr/src/linux-headers-2.6.20-15-386/include/linux/utsname.h:35,
from ./dt340.c:21:
/usr/src/linux-headers-2.6.20-15-386/include/linux/sched.h: In function ‘dequeue_signal_lock’:
/usr/src/linux-headers-2.6.20-15-386/include/linux/sched.h:1309: warning: implicit declaration of function ‘local_irq_save’
/usr/src/linux-headers-2.6.20-15-386/include/linux/sched.h:1311: warning: implicit declaration of function ‘local_irq_restore’
In file included from /usr/src/linux-headers-2.6.20-15-386/include/linux/module.h:21,
from ./dt340.c:21:
/usr/src/linux-headers-2.6.20-15-386/include/asm/module.h:62:2: error: #error unknown processor family
In file included from /usr/src/linux-headers-2.6.20-15-386/include/asm/pci.h:6,
from /usr/src/linux-headers-2.6.20-15-386/include/linux/pci.h:746,
from ./dt340.h:60,
from ./dt340.c:28:
/usr/src/linux-headers-2.6.20-15-386/include/linux/mm.h: In function ‘lowmem_page_address’:
/usr/src/linux-headers-2.6.20-15-386/include/linux/mm.h:539: warning: implicit declaration of function ‘__page_to_pfn’
/usr/src/linux-headers-2.6.20-15-386/include/linux/mm.h:539: error: ‘CONFIG_PAGE_OFFSET’ undeclared (first use in this function)
In file included from /usr/src/linux-headers-2.6.20-15-386/include/asm/pci.h:41,
from ./dt340.h:60,
from ./dt340.c:28:
/usr/src/linux-headers-2.6.20-15-386/include/asm/io.h: In function ‘virt_to_phys’:
/usr/src/linux-headers-2.6.20-15-386/include/asm/io.h:77: error: ‘CONFIG_PAGE_OFFSET’ undeclared (first use in this function)
/usr/src/linux-headers-2.6.20-15-386/include/asm/io.h: In function ‘phys_to_virt’:
/usr/src/linux-headers-2.6.20-15-386/include/asm/io.h:95: error: ‘CONFIG_PAGE_OFFSET’ undeclared (first use in this function)
In file included from /usr/src/linux-headers-2.6.20-15-386/include/linux/pci.h:746,
from ./dt340.h:60,
from ./dt340.c:28:
/usr/src/linux-headers-2.6.20-15-386/include/asm/pci.h: In function ‘pci_dac_dma_to_page’:
/usr/src/linux-headers-2.6.20-15-386/include/asm/pci.h:72: warning: implicit declaration of function ‘__pfn_to_page’
/usr/src/linux-headers-2.6.20-15-386/include/asm/pci.h:72: warning: return makes pointer from integer without a cast
./dt340.c:36:2: error: #error "This driver requires that PCI support be configured in the Kernel"
./dt340.c: In function ‘dt340_init_one’:
./dt340.c:1872: warning: implicit declaration of function ‘request_irq’
./dt340.c:1873: error: ‘SA_SHIRQ’ undeclared (first use in this function)
./dt340.c:1873: error: ‘SA_INTERRUPT’ undeclared (first use in this function)
./dt340.c: In function ‘dt340_remove_one’:
./dt340.c:1923: warning: implicit declaration of function ‘free_irq’
make: *** [dt340.o] Error 1
Hadde satt kjempepris på om noen hadde hatt noen ideer om hva jeg skal
gjøre videre!
Takker for raskt svar!
Dessverre så er dette den eneste jeg finner, ser også at det
den er versjon 0.0. Eneste produsenten gir ut er Windows og Mac
drivere. Mulig å kjøre en eldre kjerne? Alt denne pc´en egentlig
skal gjøre er å kjøre noe overvåking via kortet.
Vet ikke helt hvordan det er å kjøre en eldre kjerne på en ny distro, det kan muligens føre til litt problemer.
Det du kan prøve, er å legge inn en gammel distro fra rundt 2004. Dette forutsetter imidlertid at hardwaren i PCen du legger det inn på er gammel nok til at det finnes drivere til alt.
