holmium Skrevet 28. juni 2007 Del Skrevet 28. juni 2007 Hei. Håper noen kan hjelpe med et problem. Skal brenne noen bilder på DVD, men får følgende feilmelding: 0 | 1 | 1 | 0x41 | 1896928 | 0 | 0x00 1896928 | lead-out | 1 | 0x41 | 0 | 0 | 0x00 22:12:10 #11 Text 0 File SCSIPTICommands.cpp, Line 215 SPTILockVolume - completed successfully for FSCTL_LOCK_VOLUME 22:12:10 #12 Text 0 File Burncd.cpp, Line 4294 Caching options: cache CDRom or Network-Yes, small files-Yes (<64KB) 22:12:10 #13 Phase 24 File dlgbrnst.cpp, Line 1762 Caching of files started 22:12:24 #14 Text 0 File Burncd.cpp, Line 4413 Cache writing successful. 22:12:24 #15 Phase 25 File dlgbrnst.cpp, Line 1762 Caching of files completed 22:12:24 #16 Phase 36 File dlgbrnst.cpp, Line 1762 Burn process started at 4x (5 540 KB/s) 22:12:24 #17 Text 0 File ThreadedTransferInterface.cpp, Line 2721 Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0 22:12:24 #18 SPTI -1066 File SCSIPassThrough.cpp, Line 179 CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1066) Sense Key: 0x05 (KEY_ILLEGAL_REQUEST) Sense Code: 0x24 Sense Qual: 0x00 CDB Data: 0xAD 00 00 00 00 00 00 00 08 04 00 00 Sense Area: 0x70 00 05 00 00 00 00 0C 00 00 00 00 24 Buffer x0a597a40: Len x804 22:12:24 #19 SPTI -1066 File SCSIPassThrough.cpp, Line 179 CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1066) Sense Key: 0x05 (KEY_ILLEGAL_REQUEST) Sense Code: 0x24 Sense Qual: 0x00 CDB Data: 0xF9 15 01 FF 00 00 00 00 00 00 00 00 Sense Area: 0x70 00 05 00 00 00 00 0C 00 00 00 00 24 22:12:24 #20 Text 0 File DVDR.cpp, Line 7402 Drive: DVD+RW RW8165 Book Type request [gen]: DVD-ROM, write to EEPROM Changing the Book Type was finished successfully, return code 0 22:12:24 #21 CDR -1207 File DVDR.cpp, Line 6477 Book Type automatically set to: DVD-ROM 22:12:24 #22 Text 0 File DVDPlusRW.cpp, Line 675 Start write address at LBA 0 DVD high compatibility mode: Yes 22:12:24 #23 Text 0 File ThreadedTransfer.cpp, Line 269 Pipe memory size 40868800 22:12:54 #24 SPTI -1046 File SCSIPassThrough.cpp, Line 179 CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1046) Sense Key: 0x05 (KEY_ILLEGAL_REQUEST) Sense Code: 0x30 Sense Qual: 0x05 CDB Data: 0x2A 00 00 00 00 00 00 00 20 00 00 00 Sense Area: 0x70 00 05 00 00 00 00 0C 00 00 00 00 30 05 Buffer x0ac90040: Len x10000 0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 22:12:54 #25 CDR -1046 File Writer.cpp, Line 303 Illegal disc D: DVD+RW RW8165 22:12:55 #26 SPTI -1066 File SCSIPassThrough.cpp, Line 179 CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1066) Sense Key: 0x05 (KEY_ILLEGAL_REQUEST) Sense Code: 0x24 Sense Qual: 0x00 CDB Data: 0x00 00 00 00 00 00 00 00 00 00 00 00 Sense Area: 0x71 00 05 00 00 00 00 0C 00 00 00 00 24 22:12:55 #27 Phase 127 File dlgbrnst.cpp, Line 1762 Generating DVD high compatibility borders 22:12:56 #28 Text 0 File DVDPlusRW.cpp, Line 935 EndDAO: Last written address 0 22:12:56 #29 SPTI -1066 File SCSIPassThrough.cpp, Line 179 CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1066) Sense Key: 0x05 (KEY_ILLEGAL_REQUEST) Sense Code: 0x24 Sense Qual: 0x00 CDB Data: 0xF9 15 A1 02 00 00 00 00 00 00 00 00 Sense Area: 0x70 00 05 00 00 00 00 0C 00 00 00 00 24 22:12:56 #30 Text 0 File DVDR.cpp, Line 7402 Drive: DVD+RW RW8165 Book Type request [gen]: DVD+R, write to EEPROM Changing the Book Type was finished successfully, return code 0 22:12:56 #31 CDR -1066 File WriterStatus.cpp, Line 162 Invalid field in command D: DVD+RW RW8165 22:12:56 #32 TRANSFER -24 File WriterStatus.cpp, Line 162 Could not perform end of Disc-at-once 22:12:57 #33 Phase 38 File dlgbrnst.cpp, Line 1762 Burn process failed at 4x (5 540 KB/s) 22:12:57 #34 Text 0 File SCSIPTICommands.cpp, Line 261 SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME 22:13:01 #35 Text 0 File Cdrdrv.cpp, Line 11185 DriveLocker: UnLockVolume completed 22:13:01 #36 Text 0 File SCSIPTICommands.cpp, Line 424 UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL Existing drivers: Registry Keys: HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option) Skal brenne bilder (bare bilder) som ligger samlet i diverse mapper med undermapper. Har prøvd følgende: Programvare: Nero 6, deretter oppgradert til Nero 7. Brennere: Både den interne på PC'en (tar kun DVD+R) og en ekstern Sony via USB (tar både DVD-R og DVD+R). Får feilmelding og avbrutt brenning med en gang. På norsk sier feilmeldingen noe som at discen er ugyldig. Husker ikke nøyaktig. Setter jeg inn en DVD-R i den interne så får jeg ikke velge brenn, kun brenn image. Så jeg aner ikke hvorfor jeg får denne feilmeldingen. Noen som vet eller kan tyde noe ut fra feilmeldingen? Brenning av CD-R går helt fint. Lenke til kommentar
Largie Skrevet 28. juni 2007 Del Skrevet 28. juni 2007 Hvis du har en iso-fil kan du prøve å brenne med http://www.imgburn.com/ Hvis du trenger å få laget en ISO-fil av bildene dine, ta en titt på http://lars.werner.no/sizeme/ Lenke til kommentar
