Passer Linux for meg?
gi oss gjerne også output av glxinfo | grep direct og fps du får i glxgears.
og angående driver fra nvidia's hjemmeside vil jeg ikke si at det er så vanskelig. personlig har aldri slike verktøy fungert for min del.
wget http://us.download.nvidia.com/XFree86/Linu....14.11-pkg2.run
sudo /etc/init.d/gdm stop
[logg inn]
sudo sh NVIDIA-Linux-x86_64-100.14.11-pkg2.run
sudo gdm
bare husk å si ja til at nvidia-xconfig skal sette opp xorg.conf for deg
Endret av hockey500
Merkelig... Kan du åpne en terminal fra Programmer > tilbehør > terminal
Skriv inn i terminalen
cat /etc/X11/xorg.conf
Klipp ut innholdet og lim det inn her.
8962021[/snapback]
# /etc/X11/xorg.conf (xorg X Window System server configuration file)
# This file was generated by dexconf, the Debian X Configuration tool, using
# values from the debconf database.
# Edit this file with caution, and see the xorg.conf(5) manual page.
# (Type "man xorg.conf" at the shell prompt.)
# This file is automatically updated on xserver-xorg package upgrades *only*
# if it has not been modified since the last upgrade of the xserver-xorg
# package.
# If you have edited this file but would like it to be automatically updated
# again, run the following command:
#   sudo dpkg-reconfigure -phigh xserver-xorg
Section "Files"
       Fontpath        "/usr/share/fonts/X11/misc"
       Fontpath        "/usr/share/fonts/X11/cyrillic"
       Fontpath        "/usr/share/fonts/X11/100dpi/:unscaled"
       Fontpath        "/usr/share/fonts/X11/75dpi/:unscaled"
       Fontpath        "/usr/share/fonts/X11/Type1"
       Fontpath        "/usr/share/fonts/X11/100dpi"
       Fontpath        "/usr/share/fonts/X11/75dpi"
       # path to defoma fonts
       Fontpath        "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType"
EndSection
Section "Module"
       Load            "i2c"
       Load            "bitmap"
       Load            "ddc"
       Load            "extmod"
       Load            "freetype"
       Load            "glx"
       Load            "int10"
       Load            "vbe"
EndSection
Section "InputDevice"
       Identifier      "Generic Keyboard"
       Driver          "kbd"
       Option          "CoreKeyboard"
       Option          "XkbRules"      "xorg"
       Option          "XkbModel"      "pc105"
       Option          "XkbLayout"     "no"
EndSection
       Identifier      "Configured Mouse"
       Driver          "mouse"
       Option          "CorePointer"
       Option          "Device"        "/dev/input/mice"
       Option          "Protocol"      "ImPS/2"
       Option          "ZAxisMapping"  "4 5"
       Option          "Emulate3Buttons"       "true"
EndSection
       Driver          "wacom"
       Identifier      "stylus"
       Option          "Device"        "/dev/input/wacom"
       Option          "Type"  "stylus"
       Option          "ForceDevice"   "ISDV4"# Tablet PC ONLY
EndSection
       Driver          "wacom"
       Identifier      "eraser"
       Option          "Type"  "eraser"
EndSection
       Driver          "wacom"
       Identifier      "cursor"
       Option          "Type"  "cursor"
EndSection
Section "Device"
       Identifier      "nVidia Corporation G70 [GeForce 7800 GTX]"
       Driver          "vesa"
       Busid           "PCI:1:0:0"
       Option          "AddARGBVisuals"        "True"
       Option          "AddARGBGLXVisuals"     "True"
       Option          "NoLogo"        "True"
EndSection
Section "Monitor"
       Identifier      "DELL E177FP"
       Option          "DPMS"
EndSection
Section "Screen"
       Identifier      "Default Screen"
       Device          "nVidia Corporation G70 [GeForce 7800 GTX]"
       Monitor         "DELL E177FP"
       Defaultdepth    24
       SubSection "Display"
               Depth   1
               Modes           "1280x1024"     "1152x864"      "1024x768"     "800x600"        "720x400"       "640x480"
       EndSubSection
               Depth   4
       EndSubSection
               Depth   8
       EndSubSection
               Depth   15
       EndSubSection
               Depth   16
       EndSubSection
               Depth   24
       EndSubSection
EndSection
Section "ServerLayout"
       Identifier      "Default Layout"
 screen "Default Screen"
       Inputdevice     "Generic Keyboard"
       Inputdevice     "Configured Mouse"
       Inputdevice     "stylus"        "SendCoreEvents"
       Inputdevice     "cursor"        "SendCoreEvents"
       Inputdevice     "eraser"        "SendCoreEvents"
EndSection
Section "DRI"
       Mode    0666
Trenger fortsatt hjelp med NVIDIA drivere, jeg tror jeg prøvde etter tips fra en av dere i starten av posten om laste ned og legge inn Envy og videre, det gikk bra men så gikk det dårlig på veien og under automatisk config at en fil om NVIDIA etc, så trykte jeg jess, yes og det stoppa, måtte slå av pc'en.
Under sytemverktøy nå står Envy og NVIDIA settings som ikke funker, hvordan fjerner jeg dette? Vikke ha det der nå vel? :s
Har du prøvd
sudo nvidia-xconfig
Hvis du har det å det ikke funka prøv i terminalen med
sudo aptitude install nvidia-glx
og en restart.
Kanskje du må prøve en
etter restart hvis ting ikke vil virke nå heller. Og da velge nvidia driveren.
Har du prøvd
sudo nvidia-xconfig
og en restart.
8963660[/snapback]
Nå installerer den og sur etter jeg skrev det supo aptitude install men jeg er inlogget som mitt brukernavn, sant? Det jeg lagde når installerte. Skrev passord når jeg skrev linja.
Og nå bare masse greier, laster ned noe nå.
Ser ut som det gikk bra, tok en restart.
Jeg kan gå på Systemverktøy og på NVIDIA Settings, men et annet problem.
BIG PROBLEMO! Desktop effects could not be enabled, og jeg har NVIDIA GeForce 7800GTX kort, tror ikke det skal være problem!?
HJELPE MEG! :O Går aldri bra jo!
nei, når man ikke vet hva man driver med er det å installere linux-drivere noe skikkelig herk. Jeg er på nippet til å be deg sette opp en ssh-server, så kan noen av oss installere det for deg.
Ellers, hvis du har gjort det du har fått beskjed om skulle det fungert. har du prøvd å bruke Restricted Drivers Manager? for å få desktop effekts til å fungere må du bruke Driver "nvidia" i /etc/X11/xorg.conf. gjør du ikke det kan du se langt etter fancy effekter. men prøv med Restricted Drivers Manager, restart maskinen når den ber deg gjøre det, og sats på at alt fungerer.
Du har ikke aktivert composite extension
Trykk alt - F2 og lim inn
gksudo gedit /etc/X11/xorg.conf
Lim denne linjen inn nederts i fila
Section "Extensions"
   Option         "Composite" "Enable"
EndSection
Da tror jeg ting skal funke
Edit : står det driver "nvidia" under device seksjonen nå?
Edit enda en gang : Ikke glem å restarte xserver med ctrl - alt - bckspace først eller så vil det ikke bli noen forskjell.
Endret av rocknrolf77
rocknrolf77, jeg gjorde det du sa nå. Men jeg skal ta en restart, kanskje det trengs nå. Håper det fungerer, straks tilbake. Føler jeg tar litt med meg nå da som dere forteller meg hva jeg kan, skal gjøre, prøve på! Dere er til stor hjelp! :D Håper det går nå, restarter og ser.
Veit ikke hva som går galt. Alle disse tingene har funka helt fint på mitt 7660GT.
Kanskje noen kommer etterhvert som kan forstå hva som er galt.
Du kan alternativt prøve å laste ned og installere linux mint 3.0. Den er bygd på ubuntu men inkluderer codecs og diverse. Så den er 100% kompatibel med ubuntu 7.04. http://linuxmint.com
Samme installasjonen så det burde ikke by på noen problemer siden du fint klarte ubuntu. Har opplevd at mint har funka og ikke ubuntu.
Du burde også kikke innom http://psychocats.net/ubuntu og http://ubuntuguide.org
Hvis du er stødig i engelsk så er det kanskje lurt å ta en tur over på http://ubuntuforums.org å spørre om noen veit grunnen der. Eller rett og slett bare søke der. 99% sikkert at noen har hatt det samme problemet der ;)
Kanskje noen som kommer innom her etterhvert som veit hva som er galt.
Edit : Angående nvidia driveren og sånn. Det blir ikke rot. Ubuntu/linux rydder opp i sånne ting på egenhånd. Det er det som er fint med pakkebehandler.
Jeg prøver meg på Ubuntuforums.org nå, ser om jeg får noe svar og hjelp.
Tusen takk rocknrolf77 for du tok deg tid til og prøve hjelpe meg! :)
Setter pris på det.
Men jeg gir ikke opp, dette skal fikses, he he.
Men altså ting rydder av seg selv? For som jeg er vant i Windows kan det bli et jævlig rot etter du har prøvd og installere ditt og datten, masse dritt som ligger igjen her og der.
