Problem med koding i Mirc
Camron
alias pmblock {
 if ($1 == $null) {
   echo -a Commands: on, off, status, blockmsg
 elseif ($1 == on) {
   if (%pmblock == true) {
     echo -a Error: Private Messages already blocked
   else {
     close -m
     set %pmblock true
     echo -a Private Messages are now being blocked
 elseif ($1 == off) {
   if (%pmblock == false) {
     echo -a Error: Private Messages already not blocked
   else {
     set %pmblock false
     echo -a Private Messages are no longer blocked
 elseif ($1 == status) {
     echo -a Current Status: ENABLED
   elseif (%pmblock == false) {
     echo -a Current Status: DISABLED
   else {
     echo -a Current Status: UNKNOWN
 elseif ($1 == blockmsg) {
   if (!$2) { echo -a Commands: set, show, default }
   elseif ($2 == set) { set %pmblock.msg $3- | echo -a PM Blocking Message Set to " $+ $3- $+ " }
   elseif ($2 == show) { echo -a PMBLOCK MESSAGE: %pmblock.msg }
   elseif ($2 == default) { set %pmblock.msg [PMBLOCK] Private Messages are currently being blocked | echo -a PM Blocking Message Set to "[PMBLOCK] Private Messages are currently being blocked" }
on *:START: {
 if (%pmblock.msg == $null) { set %pmblock.msg [PMBLOCK] Private Messages are currently being blocked }
on *:UNLOAD: unset %pmblock*
on *:OPEN:?:*: {
   closemsg $nick
   .notice $nick %pmblock.msg
menu channel,query,menubar {
 PM Blocker
 .Block Private Messages:pmblock on
 .Unblock Private Messages:pmblock off
 .Set PM Blocker Block Message:pmblock blockmsg $?="What Block Message?"
Jeg skal altså stenge for all PM. Jeg vet ikke helt hvor jeg skal putte inn denne koden for at det skal funke. Noen som vet?
EDIT; Forresten, jeg fant kodingen her:
http://www.hawkee.com/snippet/2551/
Endret av Camron
