Menylinjene har forsvunnet etter Compiz Fusion
hei!
Etter en innstalasjon av compiz fusion(merk, compiz fusion, ikke beryl) fikk jeg et problem jeg ser mange andre pA forumet og har.
Menylinjene har forsvunnet!
Har prøvd alle råd som er blitt gitt pA forumet, inkl dette, men da fikk jeg bare den screenen som viser i bildet på screenshotten overfår.(altså bilde i bilde.)
Endret xorg.conf'en tilbake enable til 0, og slapp problemet. Men menylinjene kom aldri opp.
En annen ting er at menyene har blitt "gråe"(lignene Windows Classic)
Info:
Ubuntu 7.04 x86_64
Compiz Fusion (innstalerings-guide)
XGL Session - Ati kort, med virkende drivere
EDIT:
Her er min xorg.conf:
Klikk for å se/fjerne innholdet nedenfor
# /etc/X11/xorg.conf (xorg X Window System server configuration file)
# This file was generated by dexconf, the Debian X Configuration tool, using
# values from the debconf database.
# Edit this file with caution, and see the xorg.conf(5) manual page.
# (Type "man xorg.conf" at the shell prompt.)
# This file is automatically updated on xserver-xorg package upgrades *only*
# if it has not been modified since the last upgrade of the xserver-xorg
# package.
# If you have edited this file but would like it to be automatically updated
# again, run the following command:
# sudo dpkg-reconfigure -phigh xserver-xorg
Section "Files"
Fontpath "/usr/share/fonts/X11/misc"
Fontpath "/usr/share/fonts/X11/cyrillic"
Fontpath "/usr/share/fonts/X11/100dpi/:unscaled"
Fontpath "/usr/share/fonts/X11/75dpi/:unscaled"
Fontpath "/usr/share/fonts/X11/Type1"
Fontpath "/usr/share/fonts/X11/100dpi"
Fontpath "/usr/share/fonts/X11/75dpi"
# path to defoma fonts
Fontpath "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType"
EndSection
Section "Module"
Load "i2c"
Load "bitmap"
Load "ddc"
Load "dri"
Load "extmod"
Load "freetype"
Load "glx"
Load "int10"
Load "vbe"
EndSection
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "kbd"
Option "CoreKeyboard"
Option "XkbRules" "xorg"
Option "XkbModel" "pc105"
Option "XkbLayout" "us"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
Option "CorePointer"
Option "Device" "/dev/input/mice"
Option "Protocol" "ImPS/2"
Option "ZAxisMapping" "4 5"
Option "Emulate3Buttons" "true"
EndSection
Driver "wacom"
Identifier "stylus"
Option "Device" "/dev/input/wacom"
Option "Type" "stylus"
Option "ForceDevice" "ISDV4"# Tablet PC ONLY
EndSection
Driver "wacom"
Identifier "eraser"
Option "Type" "eraser"
EndSection
Driver "wacom"
Identifier "cursor"
Option "Type" "cursor"
EndSection
Section "Device"
Identifier "Generic Video Card"
Driver "fglrx"
Busid "PCI:1:0:0"
Option "AllowGLXWithComposite" "true"
EndSection
Section "Monitor"
Identifier "SyncMaster"
Option "DPMS"
EndSection
Section "Screen"
Identifier "Default Screen"
Device "Generic Video Card"
Monitor "SyncMaster"
Defaultdepth 24
Option "AddARGBGLXVisuals" "True"
SubSection "Display"
Depth 1
Modes "1280x1024" "1152x864" "1024x768" "832x624" "800x600" "720x400" "640x480"
EndSubSection
Depth 4
EndSubSection
Depth 8
EndSubSection
Depth 15
EndSubSection
Depth 16
EndSubSection
Depth 24
EndSubSection
EndSection
Section "ServerLayout"
Identifier "Default Layout"
screen "Default Screen"
Inputdevice "Generic Keyboard"
Inputdevice "Configured Mouse"
Inputdevice "stylus" "SendCoreEvents"
Inputdevice "cursor" "SendCoreEvents"
Inputdevice "eraser" "SendCoreEvents"
EndSection
Section "DRI"
Mode 0666
EndSection
Section "Extensions"
Option "Composite" "0"
EndSection
Endret av todda7
Det var ihvertfall versonkonflikt imellom compiz og compizdekorasjonene hos meg. Kjør compiz ---replace i terminal for å se på feilmeldingen.
8953578[/snapback]
brukernavn@maskinnavn-desktop:~$ compiz --replace
/bin/sh: gtk-window-decorator: not found
inotify_add_watch: No such file or directory
ringer noen bjeller?
EDIT: Har prøvd å google litt, men fant ingen svar..
Endret av todda7
Jeg er ikke helt sikker på hvordan dette fungerer jeg heller. Jeg hadde Beryl fra før av men nå kjører jeg bare compiz fusion uten å kjøre Beryl-manager i det hele tatt. Det som er veldig rart er at jeg har vindusdekorasjonene til Beryl enda uten da å kjøre noe som heter beryl i det hele tatt.
Kjører du beryl fra før av?
8957185[/snapback]
Nope, hadde beryl før men avinstalerte det fullstendig.
Hadde btw samme problem med Beryl.
EDIT: Hvilken guide brukte du til innstalasjon av fusion?
Tror jeg skal formatere Ubuntu disken, å innstalere 32bit's versionen istedenfor.
Endret av todda7
Brukte denne: http://forums.opencompositing.org/viewtopic.php?f=14&t=131
Men det var konflikter i compiz-kjernen ettersom den kommer ferdig innstallert med ubuntu 7.04. Bare fjerna alt av compiz som lå inne fra før å la inn de nye pakkene fra pakkebrønnen som det refereres til i den guiden. Tror heller ikke du er 100% avhengig av beryl for å kjøre det. Jeg klarte å kjøre det med metacity-themet. Det blir vel en årdning på dette etterhvert når utviklerne har blitt enige om hvordan ting skal gjøres.
