Mobilbruk i utlandet
Skal på ferie i Brasil i en måned og ser at Mobyson (som er min operatør) tar den nette pris av 35kr pr min. for å ringe til Norge. Det er jo helt horribelt.
Mitt spørsmål er: hva er den beste løsningen med tanke på pris hvis man er i utlandet (Brasil) og trenger å ringe endel til Norge i løpet av reisen?
Den helt klart beste løsningen om du skal oppholde deg i utlandet mer enn 1 dag eller 2 og behøver å ringe er å kjøpe seg et lokalt kontantkort.
8946777[/snapback]
If your cell is locked to a Norwegian operator, isn't there's a high chance it will reject Brasilian cards?
Klikk for å se/fjerne innholdet nedenfor
8946777[/snapback]
8953743[/snapback]
True. But if thats the case just use an old phone you have lying around, or buy a cheap non-locket phone.
Paying the fee to your operator for unlocking the phone will most likely be cheaper than paying the bill for using your phone abroad anyway. :cry:
Edit: To illustrate:
Using telenor in Brazil would cost you with the cheapest operator (TIM cellular):
6,67 a minute national and 15,57 a minute to Norway
and the most expensive (nextel brazil):
17,11 a minute national and 27,13 a minute to Norway
You wouldn't have to call very long before unlocking your phone would be cheaper.
Of course the cheapest would be to have a phone that supports WLAN, and a good SIP-phone deal. But then you would be limited to places you have access to WLAN.
Endret av cyclo
8946777[/snapback]
8953743[/snapback]
8953797[/snapback]
Point taken, and it's probably wiser to take an older phone to Brazil anyway.
