C2D E6750 Announced
Posted by Hilbert Hagedoorn on June 26, 2007 - 2:37 AM
The NDA of the upcoming 1333 MHz front-side bus Core 2 Duo E6750 has been lifted today for the first product of its Core 2 Duo E6x50-sequence lineup—the Core 2 Duo E6750. Intel clocks the Core 2 Duo E6750 at 2.66 GHz, identical to the E6700 yet has a faster 1333 MHz front-side bus to match the new Bearlake chipset-family, including the new P35 Express.
Intel Core 2 Duo
Model Frequency L2 Cache FSB July 22nd
Pricing
E6850 3.00 GHz 4MB 1333 MHz $266
E6750 2.66 GHz 4MB 1333 MHz $183
E6550 2.33 GHz 4MB 1333 MHz $163
E6540 2.33 GHz 4MB 1333 MHz $163
The new Core 2 Duo E6750 has an identical feature set to the E6700 including 4MB of shared L2 cache. Other Core 2 Duo E6x50-sequence processors have the same shared 4MB L2 cache configuration and Intel has no plans of releasing a 1333 MHz front-side bus processor with 2MB of L2 cache.
Intel Virtualization, Enhanced Intel SpeedStep, Intel 64 and Execute Disable Bit technologies make a return on the Core 2 Duo E6750 and E6x50-sequence processors. Intel Trusted Execution Technology, formerly known as La Grande, sneaks its way into the new Core 2 Duo E6750 and E6x50-sequence processors.
Expect a hard launch of the Core 2 Duo E6750 and E6x50-sequence processors in the coming weeks. Intel plans to launch four Core 2 Duo E6x50-sequence processors with speeds varying from 2.33 GHz to 3.0 GHz.
Source: Intel
Link til "The Guru Of 3D" her
Tro hva prisene blir her hjemme da?
Dollaren er jo under 6,- for tida :thumbup:
Ahh....drømmer om 3Ghz og 1333mhz fsb :dribble:
Endret av Rastafari475
Det går som regel greit å gange dollarprisen med rundt 8, da får man norske priser. (det har stemt greit før i alle fall).
Og du bør endre på trådtittelen, Caps Lock er "no-no" her.
8945439[/snapback]
Endret tittel uten caps-lock.
Skal like å se at den cpu`en på 3Ghz lander på 2100-2200,- :thumbup:
Åsså er det jo IKKE mange teite regler på forumet heller :!:
2200,- er nok en realistisk pris ja, blir spennende og se hva det blir til med ytelsen på disse. noen som vet? 5-10%....`?
8945559[/snapback]
Jeg er enig med Smirnoff, gang prisen med 8 så er du ikke langt ifra. Et annet alternativ er Q6600 som også blir priset til 266 dollar etter 22. juli. Om du ikke bare skal optimere for spilling på kort sikt er vel det et enda bedre alternativ
