EX-adrin Skrevet 25. juni 2007 Del Skrevet 25. juni 2007 (endret) Jeg driver og skal sette opp en nettbutikk side for et firma. Men jeg står litt fast med at jeg får endel errors på siden. sessions.php (se vedlegg) er den store synderen. butikksytemet jeg skal bruke til og sette opp siden med hetter osCommerce. link til siden: Butikk system med feilen Klikk for å se/fjerne innholdet nedenfor <?php/* $Id: sessions.php,v 1.19 2003/07/02 22:10:34 hpdl Exp $ osCommerce, Open Source E-Commerce Solutions http://www.oscommerce.com Copyright © 2003 osCommerce Released under the GNU General Public License */ if (STORE_SESSIONS == 'mysql') { if (!$SESS_LIFE = get_cfg_var('session.gc_maxlifetime')) { $SESS_LIFE = 1440; } function _sess_open($save_path, $session_name) { return true; } function _sess_close() { return true; } function _sess_read($key) { $value_query = tep_db_query("select value from " . TABLE_SESSIONS . " where sesskey = '" . tep_db_input($key) . "' and expiry > '" . time() . "'"); $value = tep_db_fetch_array($value_query); if (isset($value['value'])) { return $value['value']; } return false; } function _sess_write($key, $val) { global $SESS_LIFE; $expiry = time() + $SESS_LIFE; $value = $val; $check_query = tep_db_query("select count(*) as total from " . TABLE_SESSIONS . " where sesskey = '" . tep_db_input($key) . "'"); $check = tep_db_fetch_array($check_query); if ($check['total'] > 0) { return tep_db_query("update " . TABLE_SESSIONS . " set expiry = '" . tep_db_input($expiry) . "', value = '" . tep_db_input($value) . "' where sesskey = '" . tep_db_input($key) . "'"); } else { return tep_db_query("insert into " . TABLE_SESSIONS . " values ('" . tep_db_input($key) . "', '" . tep_db_input($expiry) . "', '" . tep_db_input($value) . "')"); } } function _sess_destroy($key) { return tep_db_query("delete from " . TABLE_SESSIONS . " where sesskey = '" . tep_db_input($key) . "'"); } function _sess_gc($maxlifetime) { tep_db_query("delete from " . TABLE_SESSIONS . " where expiry < '" . time() . "'"); return true; } session_set_save_handler('_sess_open', '_sess_close', '_sess_read', '_sess_write', '_sess_destroy', '_sess_gc'); } function tep_session_start() { global $HTTP_GET_VARS, $HTTP_POST_VARS, $HTTP_COOKIE_VARS; $sane_session_id = true; if (isset($HTTP_GET_VARS[tep_session_name()])) { if (preg_match('/^[a-zA-Z0-9]+$/', $HTTP_GET_VARS[tep_session_name()]) == false) { unset($HTTP_GET_VARS[tep_session_name()]); $sane_session_id = false; } } elseif (isset($HTTP_POST_VARS[tep_session_name()])) { if (preg_match('/^[a-zA-Z0-9]+$/', $HTTP_POST_VARS[tep_session_name()]) == false) { unset($HTTP_POST_VARS[tep_session_name()]); $sane_session_id = false; } } elseif (isset($HTTP_COOKIE_VARS[tep_session_name()])) { if (preg_match('/^[a-zA-Z0-9]+$/', $HTTP_COOKIE_VARS[tep_session_name()]) == false) { $session_data = session_get_cookie_params(); setcookie(tep_session_name(), '', time()-42000, $session_data['path'], $session_data['domain']); $sane_session_id = false; } } if ($sane_session_id == false) { tep_redirect(tep_href_link(FILENAME_DEFAULT, '', 'NONSSL', false)); } return session_start(); } function tep_session_register($variable) { global $session_started; if ($session_started == true) { return session_register($variable); } else { return false; } } function tep_session_is_registered($variable) { return session_is_registered($variable); } function tep_session_unregister($variable) { return session_unregister($variable); } function tep_session_id($sessid = '') { if (!empty($sessid)) { return session_id($sessid); } else { return session_id(); } } function tep_session_name($name = '') { if (!empty($name)) { return session_name($name); } else { return session_name(); } } function tep_session_close() { if (PHP_VERSION >= '4.0.4') { return session_write_close(); } elseif (function_exists('session_close')) { return session_close(); } } function tep_session_destroy() { return session_destroy(); } function tep_session_save_path($path = '') { if (!empty($path)) { return session_save_path($path); } else { return session_save_path(); } } function tep_session_recreate() { if (PHP_VERSION >= 4.1) { $session_backup = $_SESSION; unset($_COOKIE[tep_session_name()]); tep_session_destroy(); if (STORE_SESSIONS == 'mysql') { session_set_save_handler('_sess_open', '_sess_close', '_sess_read', '_sess_write', '_sess_destroy', '_sess_gc'); } tep_session_start(); $_SESSION = $session_backup; unset($session_backup); } } ?> Endret 26. juni 2007 av EX-adrin Lenke til kommentar
Gjest Slettet+142 Skrevet 25. juni 2007 Del Skrevet 25. juni 2007 Det ser ut som om hosten din kjører PHP i SafeMode... Lenke til kommentar
EX-adrin Skrevet 25. juni 2007 Forfatter Del Skrevet 25. juni 2007 det kan stemma. for tror ikkje eg hukka av for enebel SSL Lenke til kommentar
itsmebth Skrevet 25. juni 2007 Del Skrevet 25. juni 2007 SSL har ikke mye å gjøre med safe_mode. Lenke til kommentar
EX-adrin Skrevet 25. juni 2007 Forfatter Del Skrevet 25. juni 2007 begynne og bli litt trøtt nå å stressa pga detta probleme Lenke til kommentar
Achelous Skrevet 27. september 2007 Del Skrevet 27. september 2007 jeg sitter å prøver å sette opp en webshop nå, og får samme problemet som du hadde tror jeg... Dette kommer opp med meg: Warning: session_save_path() [function.session-save-path]: SAFE MODE Restriction in effect. The script whose uid/gid is 1106/80 is not allowed to access /tmp owned by uid/gid 0/0 in /usr/home/web/wno214305/shop/catalog/includes/functions/sessions.php on line 162 Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at /usr/home/web/wno214305/shop/catalog/includes/functions/sessions.php:162) in /usr/home/web/wno214305/shop/catalog/includes/functions/sessions.php on line 97 har du en løsning på dette ? Lenke til kommentar
Runar Skrevet 28. september 2007 Del Skrevet 28. september 2007 fant ut nå! 9590648[/snapback] Da deler du løsningen med oss andre Lenke til kommentar
